Please more help!
seatrump
Please more help!
Post by seatrump »
I had to switch our wireless access points. I thought I could be clever and just rename the new one the same as the old one and everything would work but MBPro comes up with No Network Found. OK, Factory Reset, connect, make sure all the settings are correct, yes. Still No Network Found on MBPro.
Can anyone suggest what to try other than to make sure the password etc. are correct?
MeteoOudkarspel
Re: Please more help!
Post by MeteoOudkarspel »
One question you have the LAN port on the Meteobridge Pro have you ever tried it?
Usually you'll be there again and again to your WiFi reset.
I hope you will succeed.
Sincerely,
When you connect to your LAN via Ethernet cable and select "REBOOT LAN DHCP CLIENT" on the reset menu it should come up fine. Being there you can again start WiFi configuration.
