No Weather Underground Summary / Hi / Lows. **solved**
treeshelter
Post by treeshelter »
I posted this in the vantage sub forum with no love. I've not had any support from anyone via email or here. This is my last shot before I return this item as not working and try another route. In a nutshell....
I just received my meteorbrigde and am frustrated beyond words. All that is being pushed to wunderground and other services is rapid fire or "current conditions". I am not seeing any history, no hi or low as it related to temperature, wind speed / gusts anything on any service I'm pushing to yet the live data has good history to work from. I do no understand what is going on.
http://www.wunderground.com/weatherstat ... =KNJMIDDL2 is not working.
http://www.pwsweather.com/obs/KNJMIDDL2.html is working.
Can someone tell me what my issue might be? My logs looks ok, my setup and system is not returning any error messages of any kind. I have tried 2 different consoles with 2 different data loggers and the results are the same so I'm pretty sure (but not 100%) certain the issue is not with the weather hardware but something on the meteobridge side.
wnetd (04.10.2016 00:23:45): process started.
system (04.10.2016 00:23:45): start of logging process initiated.
logger (04.10.2016 00:23:45): Historical data loaded (19 records).
logger (04.10.2016 00:23:45): data logger (version 5.0r, build 10417) started.
logger (04.10.2016 00:23:47): connect station 0 (Vantage via USB serial).
logger (04.10.2016 00:23:47): wakeup sent.
logger (04.10.2016 00:23:47): internal logger activated.
logger (04.10.2016 00:23:47): syncing.
logger (04.10.2016 00:23:57): gettime request sent.
logger (04.10.2016 00:24:07): gettime request sent.
logger (04.10.2016 00:24:07): time offset of Vantage: -15 minutes
logger (04.10.2016 00:24:07): eeprom request sent.
logger (04.10.2016 00:24:07): rain collector size 0.01 inch per tick.
logger (04.10.2016 00:24:07): transmitter 1 active as station type (#0) "ISS".
logger (04.10.2016 00:24:07): transmitter 2 active as station type (#4) "Wind".
logger (04.10.2016 00:24:07): firmware version request sent.
logger (04.10.2016 00:24:07): firmware version 1.70
logger (04.10.2016 00:24:07): no reading of Vantage's internal logger.
http://stockimages.me/livedata.png
I have since re synced the time on my weather envoy but that has not made a difference. My time zone and baud rates are ok. I am at a loss and if I can't figure this out this device is going to be returned as this really isn't (and shouldn't) be this hard.
Anyone have any guidance?
Davis Vantage pro
Serial logger.
triplite serial to usb adapters,
usb 2.0 hub to Meteobridge.
weeramateur
Re: No Weather Underground Summary / Hi / Lows.
Post by weeramateur »
treeshelter
Nope! My highs and lows worked for about 1/2 a day. Today it's no longer reporting once again. I think I'm just going to return this appliance. I've found a number of problems.
#1 The highs and lows do not sent reliably. So far 1 of the 3 days has actually worked.
#2 Inconsistent display of rapid fire results. It supposed to upload ever 5 seconds and I suppose that happens but WU show it as 5 seconds then the next update say 4 mins and 5 seconds later is say 7 seconds then 5 seconds then it says 2 mins. If you sit parked on my page I would expect the display to continue to update like it always did with my last appliance but it does not... my data just stops.
I am confident in my network and my setup. This thing just does not seem ready for prime time.
treeshelter wrote:I posted this in the vantage sub forum with no love. I've not had any support from anyone via email or here. This is my last shot before I return this item as not working and try another route.
Your email has been answered on October 4, same day you did send it to me. So please get your communication working before complaining.
When you inspect data on WU at (https://www.wunderground.com/personal-w ... 006/mdaily) you see that data is uploaded fine. The problem you are facing here is that the WU widgets doe not work properly. Please address your issues there. You might have analyzed this yourself, by checking other weather networks that are fed with your Meteobridge which show correct data.
