Minute-resolution data export broken **solved**
chrysnic
Post by chrysnic »
The minute-resolution data export has not worked for the past couple of days. I get all commas on each line (see below for a snippet of the generated text file).
I am not sure if this has to do with the latest fix regarding the increased wait period from 15 to 20 secs to allow uploading to weatherlink.com:
viewtopic.php?f=61&t=10867&start=30
My MB Pro reads the weather data by connecting to a WeatherLink IP through a wired LAN. The MB Pro is configured to upload data to weatherlink.com every minute (this is why I mentioned that this may be related to the issue in the above thread).
This is what the generated TXT file looks like:
# date, time, temperature[C], humidity[%], dew point[C], sealevel pressure[hPa], avg wind speed[m/s], gust speed[m/s], winddir, rainfall[mm]
2016-10-08,17:00,,,,,,,,
2016-10-08,17:01,,,,,,,,
2016-10-08,17:02,,,,,,,,
2016-10-08,17:03,,,,,,,,
2016-10-08,17:04,,,,,,,,
2016-10-08,17:05,,,,,,,,
2016-10-08,17:06,,,,,,,,
2016-10-08,17:07,,,,,,,,
2016-10-08,17:08,,,,,,,,
2016-10-08,17:09,,,,,,,,
2016-10-08,17:10,,,,,,,,
2016-10-08,17:11,,,,,,,,
2016-10-08,17:12,,,,,,,,
2016-10-08,17:13,,,,,,,,
2016-10-08,17:14,,,,,,,,
2016-10-08,17:15,,,,,,,,
2016-10-08,17:16,,,,,,,,
2016-10-08,17:17,,,,,,,,
2016-10-08,17:18,,,,,,,,
2016-10-08,17:19,,,,,,,,
2016-10-08,17:20,,,,,,,,
2016-10-08,17:21,,,,,,,,
2016-10-08,17:22,,,,,,,,
2016-10-08,17:23,,,,,,,,
2016-10-08,17:24,,,,,,,,
2016-10-08,17:25,,,,,,,,
2016-10-08,17:26,,,,,,,,
2016-10-08,17:27,,,,,,,,
2016-10-08,17:28,,,,,,,,
2016-10-08,17:29,,,,,,,,
2016-10-08,17:30,,,,,,,,
2016-10-08,17:31,,,,,,,,
2016-10-08,17:32,,,,,,,,
2016-10-08,17:33,,,,,,,,
2016-10-08,17:34,,,,,,,,
2016-10-08,17:35,,,,,,,,
2016-10-08,17:36,,,,,,,,
Any help will be appreciated.
Re: Minute-resolution data export broken
Latest update (October 16) should have this fixed. If not please give me a PM.
