MBPro still has database problems
1fcmrYpC2Nw8
Post by 1fcmrYpC2Nw8 »
My MB Pro internal original storage failed so I used a generic USB drive which worked well but did not fit into the case. My previous data was lost but at least I could start again.
I enquired as to the most reliable replacement and purchased an ATP Nano Dura.
On Wednesday I installed the Nano Dura, it formatted, I restored the database and everything appeared to be working ok.
I now find that no data was being stored on the internal USB and lots of 'database locked' messages are logged
I removed the Nano Dura and swapped back the previous USB. It formatted and appeared to be ok. Same problem as above 'database locked'
At least the MB Pro is sending data reasonably reliably to WU, Metoplug etc however still no internal database.
Since I changed over in May, I've wasted hours fiddling about with my MB Pro, I have huge data holes where, for one reason or other, it has failed to function correctly: WLAN, DNS errors, freezing, database errors, broken internal USB etc. And now, having purchased the recommended replacement, neither it nor the previous temporary USB will save data.
I am completely fed up with the whole thing and feel like throwing it into the sea!
Here are some log entries:
oled (08.10.2016 19:06:57): process started.
database (08.10.2016 22:09:20): process started.
database (08.10.2016 22:09:20): database sync done (0 tables, 0/0 writes)
wnetd (08.10.2016 22:09:22): process started.
system (08.10.2016 22:09:22): start of logging process initiated.
logger (08.10.2016 22:09:23): databases connected. Update interval 3600 seconds.
logger (08.10.2016 22:09:23): Historical data loaded (0 records).
logger (08.10.2016 22:09:23): data logger (version 5.0r, build 10425) started.
logger (08.10.2016 22:09:24): connect station 0 (Meteostick Vantage via USB serial).
logger (08.10.2016 22:09:24): connect station 9 (System Data via Plug-in).
logger (08.10.2016 22:09:26): transmitter 1 registered as ISS
logger (08.10.2016 22:09:26): transmitter 2 registered as Wind
logger (08.10.2016 22:09:26): Meteostick Version 2.4
logger (08.10.2016 22:09:26): debug off
logger (08.10.2016 22:09:26): verbose off
logger (08.10.2016 22:09:26): output raw (8 bytes)
logger (08.10.2016 22:09:26): output raw (10 bytes)
logger (08.10.2016 22:09:26): filter on
logger (08.10.2016 22:09:26): rx threshold set to -90db
logger (08.10.2016 22:09:26): listening to transmitter 1 2
logger (08.10.2016 22:09:26): bandwidth narrow
logger (08.10.2016 22:09:26): chip authentication ok: 14
logger (08.10.2016 22:09:26): frequency band 868MHz (EU)
logger (08.10.2016 22:11:25): wind1 data incomplete (missing outdoor temp for windchill)
logger (08.10.2016 22:11:28): wind1 data incomplete (missing outdoor temp for windchill)
logger (08.10.2016 22:11:30): wind1 data incomplete (missing outdoor temp for windchill)
logger (08.10.2016 22:11:41): wind1 data incomplete (missing outdoor temp for windchill)
logger (08.10.2016 22:11:48): wind1 data incomplete (missing outdoor temp for windchill)
logger (08.10.2016 22:11:51): wind1 data incomplete (missing outdoor temp for windchill)
database (08.10.2016 22:13:10): cannot commit RAM (after 100 tries in 9035ms): database is locked
database (08.10.2016 22:13:19): cannot insert into data10num_hour RAM (after 100 tries in 9130ms): database is locked
database (08.10.2016 22:13:19): rollback on insert forced (min): data10num
database (08.10.2016 22:13:28): cannot commit RAM (after 100 tries in 9019ms): database is locked
database (08.10.2016 22:13:37): cannot insert into data10num_hour RAM (after 100 tries in 9255ms): database is locked
database (08.10.2016 22:13:37): rollback on insert forced (min): data10num
database (08.10.2016 22:13:46): cannot commit RAM (after 100 tries in 9016ms): database is locked
database (08.10.2016 22:13:56): cannot insert into data10num_hour RAM (after 100 tries in 9123ms): database is locked
database (08.10.2016 22:13:56): rollback on insert forced (min): data10num
database (08.10.2016 22:14:05): cannot commit RAM (after 100 tries in 9018ms): database is locked
database (08.10.2016 22:14:14): cannot insert into data10num_hour RAM (after 100 tries in 9130ms): database is locked
database (08.10.2016 22:14:14): rollback on insert forced (min): data10num
database (08.10.2016 22:14:23): cannot commit RAM (after 100 tries in 9021ms): database is locked
database (08.10.2016 22:14:32): cannot insert into data10num_hour RAM (after 100 tries in 9138ms): database is locked
database (08.10.2016 22:14:32): rollback on insert forced (min): data10num
database (08.10.2016 22:14:41): cannot commit RAM (after 100 tries in 9014ms): database is locked
database (08.10.2016 22:14:50): cannot insert into data10num_hour RAM (after 100 tries in 9131ms): database is locked
database (08.10.2016 22:14:50): rollback on insert forced (min): data10num
database (08.10.2016 22:15:00): cannot commit RAM (after 100 tries in 9014ms): database is locked
database (08.10.2016 22:15:09): cannot insert into data10num_hour RAM (after 100 tries in 9132ms): database is locked
database (08.10.2016 22:15:09): rollback on insert forced (min): data10num
database (08.10.2016 22:15:18): cannot commit RAM (after 100 tries in 9014ms): database is locked
database (08.10.2016 22:15:27): cannot insert into data10num_hour RAM (after 100 tries in 9016ms): database is locked
database (08.10.2016 22:15:27): rollback on insert forced (min): data10num
database (08.10.2016 22:15:36): cannot commit RAM (after 100 tries in 9016ms): database is locked
database (08.10.2016 22:15:45): cannot insert into data10num_hour RAM (after 100 tries in 9177ms): database is locked
database (08.10.2016 22:15:45): rollback on insert forced (min): data10num
database (08.10.2016 22:15:54): cannot commit RAM (after 100 tries in 9026ms): database is locked
database (08.10.2016 22:16:03): cannot insert into data10num_hour RAM (after 100 tries in 9141ms): database is locked
database (08.10.2016 22:16:03): rollback on insert forced (min): data10num
database (08.10.2016 22:16:13): cannot commit RAM (after 100 tries in 9016ms): database is locked
database (08.10.2016 22:16:22): cannot insert into data10num_hour RAM (after 100 tries in 9135ms): database is locked
database (08.10.2016 22:16:22): rollback on insert forced (min): data10num
database (08.10.2016 22:16:31): cannot commit RAM (after 100 tries in 9043ms): database is locked
backup (08.10.2016 22:16:31): no target media found.
database (08.10.2016 22:16:40): cannot insert into data10num_hour RAM (after 100 tries in 9123ms): database is locked
database (08.10.2016 22:16:40): rollback on insert forced (min): data10num
database (08.10.2016 22:16:49): cannot commit RAM (after 100 tries in 9014ms): database is locked
database (08.10.2016 22:16:58): cannot insert into data10num_hour RAM (after 100 tries in 9122ms): database is locked
database (08.10.2016 22:16:58): rollback on insert forced (min): data10num
database (08.10.2016 22:17:07): cannot commit RAM (after 100 tries in 9025ms): database is locked
database (08.10.2016 22:17:17): cannot insert into data10num_hour RAM (after 100 tries in 9126ms): database is locked
database (08.10.2016 22:17:17): rollback on insert forced (min): data10num
database (08.10.2016 22:17:26): cannot commit RAM (after 100 tries in 9024ms): database is locked
database (08.10.2016 22:17:35): cannot insert into data10num_hour RAM (after 100 tries in 9126ms): database is locked
database (08.10.2016 22:17:35): rollback on insert forced (min): data10num
database (08.10.2016 22:17:44): cannot commit RAM (after 100 tries in 9015ms): database is locked
database (08.10.2016 22:17:53): cannot insert into data10num_hour RAM (after 100 tries in 9122ms): database is locked
database (08.10.2016 22:17:53): rollback on insert forced (min): data10num
database (08.10.2016 22:18:02): cannot commit RAM (after 100 tries in 9015ms): database is locked
database (08.10.2016 22:18:11): cannot insert into data10num_hour RAM (after 100 tries in 9199ms): database is locked
database (08.10.2016 22:18:11): rollback on insert forced (min): data10num
database (08.10.2016 22:18:21): cannot commit RAM (after 100 tries in 9019ms): database is locked
database (08.10.2016 22:18:30): cannot insert into data10num_hour RAM (after 100 tries in 9122ms): database is locked
database (08.10.2016 22:18:30): rollback on insert forced (min): data10num
database (08.10.2016 22:18:39): cannot commit RAM (after 100 tries in 9022ms): database is locked
database (08.10.2016 22:18:48): cannot insert into data10num_hour RAM (after 100 tries in 9124ms): database is locked
database (08.10.2016 22:18:48): rollback on insert forced (min): data10num
database (08.10.2016 22:18:57): cannot commit RAM (after 100 tries in 9014ms): database is locked
database (08.10.2016 22:19:06): cannot insert into data10num_hour RAM (after 100 tries in 9133ms): database is locked
database (08.10.2016 22:19:06): rollback on insert forced (min): data10num
database (08.10.2016 22:19:15): cannot commit RAM (after 100 tries in 9022ms): database is locked
database (08.10.2016 22:19:25): cannot insert into data10num_hour RAM (after 100 tries in 9766ms): database is locked
database (08.10.2016 22:19:25): rollback on insert forced (min): data10num
database (08.10.2016 22:19:34): cannot commit RAM (after 100 tries in 9014ms): database is locked
database (08.10.2016 22:19:43): cannot insert into data10num_hour RAM (after 100 tries in 9124ms): database is locked
database (08.10.2016 22:19:43): rollback on insert forced (min): data10num
database (08.10.2016 22:19:53): cannot commit RAM (after 100 tries in 9015ms): database is locked
database (08.10.2016 22:20:02): cannot insert into data10num_hour RAM (after 100 tries in 9133ms): database is locked
database (08.10.2016 22:20:02): rollback on insert forced (min): data10num
database (08.10.2016 22:20:11): cannot commit RAM (after 100 tries in 9014ms): database is locked
database (08.10.2016 22:20:20): cannot insert into data10num_hour RAM (after 100 tries in 9125ms): database is locked
database (08.10.2016 22:20:20): rollback on insert forced (min): data10num
database (08.10.2016 22:20:29): cannot commit RAM (after 100 tries in 9249ms): database is locked
database (08.10.2016 22:20:39): cannot insert into data10num_hour RAM (after 100 tries in 9197ms): database is locked
database (08.10.2016 22:20:39): rollback on insert forced (min): data10num
database (08.10.2016 22:20:48): cannot commit RAM (after 100 tries in 9026ms): database is locked
database (08.10.2016 22:20:57): cannot insert into data10num_hour RAM (after 100 tries in 9123ms): database is locked
database (08.10.2016 22:20:57): rollback on insert forced (min): data10num
database (08.10.2016 22:21:06): cannot commit RAM (after 100 tries in 9028ms): database is locked
database (08.10.2016 22:21:15): cannot insert into data10num_hour RAM (after 100 tries in 9133ms): database is locked
database (08.10.2016 22:21:15): rollback on insert forced (min): data10num
database (08.10.2016 22:21:24): cannot commit RAM (after 100 tries in 9014ms): database is locked
database (08.10.2016 22:21:33): cannot insert into data10num_hour RAM (after 100 tries in 9123ms): database is locked
database (08.10.2016 22:21:33): rollback on insert forced (min): data10num
database (08.10.2016 22:21:43): cannot commit RAM (after 100 tries in 9014ms): database is locked
database (08.10.2016 22:21:52): cannot insert into data10num_hour RAM (after 100 tries in 9129ms): database is locked
database (08.10.2016 22:21:52): rollback on insert forced (min): data10num
database (08.10.2016 22:22:01): cannot commit RAM (after 100 tries in 9018ms): database is locked
database (08.10.2016 22:22:10): cannot insert into data10num_hour RAM (after 100 tries in 9124ms): database is locked
database (08.10.2016 22:22:10): rollback on insert forced (min): data10num
database (08.10.2016 22:22:19): cannot commit RAM (after 100 tries in 9173ms): database is locked
database (08.10.2016 22:22:28): cannot insert into data10num_hour RAM (after 100 tries in 9156ms): database is locked
database (08.10.2016 22:22:28): rollback on insert forced (min): data10num
database (08.10.2016 22:22:38): cannot commit RAM (after 100 tries in 9026ms): database is locked
database (08.10.2016 22:22:47): cannot insert into data10num_hour RAM (after 100 tries in 9154ms): database is locked
database (08.10.2016 22:22:47): rollback on insert forced (min): data10num
database (08.10.2016 22:22:56): cannot commit RAM (after 100 tries in 9015ms): database is locked
database (08.10.2016 22:23:05): cannot insert into data10num_hour RAM (after 100 tries in 8841ms): database is locked
database (08.10.2016 22:23:05): rollback on insert forced (min): data10num
database (08.10.2016 22:23:14): cannot commit RAM (after 100 tries in 9014ms): database is locked
database (08.10.2016 22:23:23): cannot insert into data10num_hour RAM (after 100 tries in 9123ms): database is locked
database (08.10.2016 22:23:23): rollback on insert forced (min): data10num
database (08.10.2016 22:23:32): cannot commit RAM (after 100 tries in 9016ms): database is locked
database (08.10.2016 22:23:41): cannot insert into data10num_hour RAM (after 100 tries in 9126ms): database is locked
database (08.10.2016 22:23:41): rollback on insert forced (min): data10num
database (08.10.2016 22:23:50): cannot commit RAM (after 100 tries in 9014ms): database is locked
database (08.10.2016 22:24:00): cannot insert into data10num_hour RAM (after 100 tries in 9122ms): database is locked
database (08.10.2016 22:24:00): rollback on insert forced (min): data10num
database (08.10.2016 22:24:09): cannot commit RAM (after 100 tries in 9022ms): database is locked
database (08.10.2016 22:24:18): cannot insert into data10num_hour RAM (after 100 tries in 9123ms): database is locked
database (08.10.2016 22:24:18): rollback on insert forced (min): data10num
database (08.10.2016 22:24:27): cannot commit RAM (after 100 tries in 9016ms): database is locked
database (08.10.2016 22:24:36): cannot insert into data10num_hour RAM (after 100 tries in 9142ms): database is locked
database (08.10.2016 22:24:36): rollback on insert forced (min): data10num
database (08.10.2016 22:24:45): cannot commit RAM (after 100 tries in 9026ms): database is locked
database (08.10.2016 22:24:54): cannot insert into data10num_hour RAM (after 100 tries in 9121ms): database is locked
database (08.10.2016 22:24:54): rollback on insert forced (min): data10num
database (08.10.2016 22:25:04): cannot commit RAM (after 100 tries in 9017ms): database is locked
database (08.10.2016 22:25:13): cannot insert into data10num_hour RAM (after 100 tries in 9145ms): database is locked
database (08.10.2016 22:25:13): rollback on insert forced (min): data10num
system (08.10.2016 22:25:21): stop of logging process initiated.
logger (08.10.2016 22:25:21): parent process received termination signal (15).
logger (08.10.2016 22:25:21): child process received termination signal (15).
system (08.10.2016 22:25:21): start of logging process initiated.
logger (08.10.2016 22:25:21): databases connected. Update interval 3600 seconds.
logger (08.10.2016 22:25:21): Historical data loaded (0 records).
logger (08.10.2016 22:25:21): data logger (version 5.0r, build 10425) started.
logger (08.10.2016 22:25:23): connect station 0 (Meteostick Vantage via USB serial).
logger (08.10.2016 22:25:23): connect station 9 (System Data via Plug-in).
logger (08.10.2016 22:25:23): transmitter 1 registered as ISS
logger (08.10.2016 22:25:23): transmitter 2 registered as Wind
logger (08.10.2016 22:25:23): Meteostick Version 2.4
logger (08.10.2016 22:25:23): debug off
logger (08.10.2016 22:25:23): verbose off
logger (08.10.2016 22:25:23): output raw (8 bytes)
logger (08.10.2016 22:25:23): output raw (10 bytes)
logger (08.10.2016 22:25:23): filter on
logger (08.10.2016 22:25:23): rx threshold set to -90db
logger (08.10.2016 22:25:23): listening to transmitter 1 2
logger (08.10.2016 22:25:23): bandwidth narrow
logger (08.10.2016 22:25:23): chip authentication ok: 14
logger (08.10.2016 22:25:23): frequency band 868MHz (EU)
oled (08.10.2016 19:31:11): process started.
database (08.10.2016 22:34:17): process started.
database (08.10.2016 22:34:17): database sync done (0 tables, 0/0 writes)
wnetd (08.10.2016 22:34:19): process started.
system (08.10.2016 22:34:19): start of logging process initiated.
logger (08.10.2016 22:34:19): databases connected. Update interval 3600 seconds.
logger (08.10.2016 22:34:19): Historical data loaded (0 records).
logger (08.10.2016 22:34:19): data logger (version 5.0r, build 10425) started.
logger (08.10.2016 22:34:21): connect station 0 (Meteostick Vantage via USB serial).
logger (08.10.2016 22:34:21): connect station 9 (System Data via Plug-in).
logger (08.10.2016 22:34:23): transmitter 1 registered as ISS
logger (08.10.2016 22:34:23): transmitter 2 registered as Wind
logger (08.10.2016 22:34:23): Meteostick Version 2.4
logger (08.10.2016 22:34:23): debug off
logger (08.10.2016 22:34:23): verbose off
logger (08.10.2016 22:34:23): output raw (8 bytes)
logger (08.10.2016 22:34:23): output raw (10 bytes)
logger (08.10.2016 22:34:23): filter on
logger (08.10.2016 22:34:23): rx threshold set to -90db
logger (08.10.2016 22:34:23): listening to transmitter 1 2
logger (08.10.2016 22:34:23): bandwidth narrow
logger (08.10.2016 22:34:23): chip authentication ok: 14
logger (08.10.2016 22:34:23): frequency band 868MHz (EU)
database (08.10.2016 22:37:33): cannot commit RAM (after 100 tries in 9054ms): database is locked
database (08.10.2016 22:37:42): cannot insert into thb0temp_hour RAM (after 100 tries in 9132ms): database is locked
database (08.10.2016 22:37:42): rollback on insert forced (min): thb0temp
database (08.10.2016 22:37:51): cannot commit RAM (after 100 tries in 9025ms): database is locked
database (08.10.2016 22:38:00): cannot insert into thb0temp_hour RAM (after 100 tries in 9122ms): database is locked
database (08.10.2016 22:38:00): rollback on insert forced (min): thb0temp
backup (08.10.2016 22:38:02): no target media found.
database (08.10.2016 22:38:10): cannot commit RAM (after 100 tries in 9026ms): database is locked
database (08.10.2016 22:38:19): cannot insert into thb0temp_hour RAM (after 100 tries in 9156ms): database is locked
database (08.10.2016 22:38:19): rollback on insert forced (min): thb0temp
database (08.10.2016 22:38:28): cannot commit RAM (after 100 tries in 9015ms): database is locked
database (08.10.2016 22:38:37): cannot insert into thb0temp_hour RAM (after 100 tries in 9127ms): database is locked
database (08.10.2016 22:38:37): rollback on insert forced (min): thb0temp
database (08.10.2016 22:38:46): cannot commit RAM (after 100 tries in 9016ms): database is locked
database (08.10.2016 22:38:55): cannot insert into thb0temp_hour RAM (after 100 tries in 9164ms): database is locked
database (08.10.2016 22:38:55): rollback on insert forced (min): thb0temp
database (08.10.2016 22:39:05): cannot commit RAM (after 100 tries in 9015ms): database is locked
database (08.10.2016 22:39:14): cannot insert into thb0temp_hour RAM (after 100 tries in 9267ms): database is locked
database (08.10.2016 22:39:14): rollback on insert forced (min): thb0temp
database (08.10.2016 22:39:23): cannot commit RAM (after 100 tries in 9016ms): database is locked
database (08.10.2016 22:39:32): cannot insert into thb0temp_hour RAM (after 100 tries in 9135ms): database is locked
database (08.10.2016 22:39:32): rollback on insert forced (min): thb0temp
backup (08.10.2016 22:39:41): no target media found.
database (08.10.2016 22:39:41): cannot commit RAM (after 100 tries in 9027ms): database is locked
database (08.10.2016 22:39:50): cannot insert into thb0temp_hour RAM (after 100 tries in 9134ms): database is locked
database (08.10.2016 22:39:50): rollback on insert forced (min): thb0temp
database (08.10.2016 22:40:00): cannot commit RAM (after 100 tries in 9016ms): database is locked
database (08.10.2016 22:40:09): cannot insert into thb0temp_hour RAM (after 100 tries in 9136ms): database is locked
database (08.10.2016 22:40:09): rollback on insert forced (min): thb0temp
database (08.10.2016 22:40:18): cannot commit RAM (after 100 tries in 8891ms): database is locked
oled (08.10.2016 19:39:38): process started.
database (08.10.2016 22:45:59): process started.
database (08.10.2016 22:45:59): database sync done (0 tables, 0/0 writes)
wnetd (08.10.2016 22:46:01): process started.
system (08.10.2016 22:46:01): start of logging process initiated.
logger (08.10.2016 22:46:02): databases connected. Update interval 3600 seconds.
logger (08.10.2016 22:46:02): Historical data loaded (0 records).
logger (08.10.2016 22:46:02): data logger (version 5.0r, build 10425) started.
logger (08.10.2016 22:46:04): connect station 0 (Meteostick Vantage via USB serial).
logger (08.10.2016 22:46:04): connect station 9 (System Data via Plug-in).
logger (08.10.2016 22:46:06): transmitter 1 registered as ISS
logger (08.10.2016 22:46:06): transmitter 2 registered as Wind
logger (08.10.2016 22:46:06): Meteostick Version 2.4
logger (08.10.2016 22:46:06): debug off
logger (08.10.2016 22:46:06): verbose off
logger (08.10.2016 22:46:06): output raw (8 bytes)
logger (08.10.2016 22:46:06): output raw (10 bytes)
logger (08.10.2016 22:46:06): filter on
logger (08.10.2016 22:46:06): rx threshold set to -90db
logger (08.10.2016 22:46:06): listening to transmitter 1 2
logger (08.10.2016 22:46:06): bandwidth narrow
logger (08.10.2016 22:46:06): chip authentication ok: 14
logger (08.10.2016 22:46:06): frequency band 868MHz (EU)
database (08.10.2016 22:48:13): cannot create table (after 100 tries in 12341ms): database is locked
database (08.10.2016 22:48:13): cannot prepare insert into data10num_min RAM (after 0 tries in 31ms): no such table: data10num_min (1)
database (08.10.2016 22:48:13): rollback on insert forced (min RAM): data10num
database (08.10.2016 22:48:13): cannot prepare insert into data10num_min RAM (after 0 tries in 1ms): no such table: data10num_min (1)
database (08.10.2016 22:48:14): cannot prepare insert into data10num_min RAM (after 0 tries in 1ms): no such table: data10num_min (1)
database (08.10.2016 22:48:14): rollback on insert forced (min RAM): data10num
database (08.10.2016 22:48:15): cannot prepare insert into data10num_min RAM (after 0 tries in 1ms): no such table: data10num_min (1)
database (08.10.2016 22:48:15): rollback on insert forced (min RAM): data10num
database (08.10.2016 22:48:16): cannot prepare insert into data10num_min RAM (after 0 tries in 1ms): no such table: data10num_min (1)
database (08.10.2016 22:48:16): rollback on insert forced (min RAM): data10num
database (08.10.2016 22:48:17): cannot prepare insert into data10num_min RAM (after 0 tries in 1ms): no such table: data10num_min (1)
database (08.10.2016 22:48:17): rollback on insert forced (min RAM): data10num
database (08.10.2016 22:48:18): cannot prepare insert into data10num_min RAM (after 0 tries in 1ms): no such table: data10num_min (1)
database (08.10.2016 22:48:18): rollback on insert forced (min RAM): data10num
database (08.10.2016 22:48:18): cannot prepare insert into data10num_min RAM (after 0 tries in 5ms): no such table: data10num_min (1)
database (08.10.2016 22:48:19): cannot prepare insert into data10num_min RAM (after 0 tries in 1ms): no such table: data10num_min (1)
database (08.10.2016 22:48:19): rollback on insert forced (min RAM): data10num
database (08.10.2016 22:48:19): cannot prepare insert into data10num_min RAM (after 0 tries in 2ms): no such table: data10num_min (1)
database (08.10.2016 22:48:20): cannot prepare insert into data10num_min RAM (after 0 tries in 1ms): no such table: data10num_min (1)
database (08.10.2016 22:48:20): rollback on insert forced (min RAM): data10num
database (08.10.2016 22:48:21): cannot prepare insert into data10num_min RAM (after 0 tries in 1ms): no such table: data10num_min (1)
database (08.10.2016 22:48:21): rollback on insert forced (min RAM): data10num
database (08.10.2016 22:48:22): cannot prepare insert into data10num_min RAM (after 0 tries in 1ms): no such table: data10num_min (1)
database (08.10.2016 22:48:22): rollback on insert forced (min RAM): data10num
database (08.10.2016 22:48:23): cannot prepare insert into data10num_min RAM (after 0 tries in 1ms): no such table: data10num_min (1)
database (08.10.2016 22:48:23): rollback on insert forced (min RAM): data10num
database (08.10.2016 22:48:24): cannot prepare insert into data10num_min RAM (after 0 tries in 1ms): no such table: data10num_min (1)
database (08.10.2016 22:48:24): rollback on insert forced (min RAM): data10num
database (08.10.2016 22:48:25): cannot prepare insert into data10num_min RAM (after 0 tries in 1ms): no such table: data10num_min (1)
database (08.10.2016 22:48:25): rollback on insert forced (min RAM): data10num
database (08.10.2016 22:48:26): cannot prepare insert into data10num_min RAM (after 0 tries in 1ms): no such table: data10num_min (1)
database (08.10.2016 22:48:26): rollback on insert forced (min RAM): data10num
database (08.10.2016 22:48:27): cannot prepare insert into data10num_min RAM (after 0 tries in 1ms): no such table: data10num_min (1)
database (08.10.2016 22:48:27): rollback on insert forced (min RAM): data10num
database (08.10.2016 22:48:28): cannot prepare insert into data10num_min RAM (after 0 tries in 1ms): no such table: data10num_min (1)
database (08.10.2016 22:48:28): rollback on insert forced (min RAM): data10num
database (08.10.2016 22:48:28): cannot prepare insert into data10num_min RAM (after 0 tries in 13ms): no such table: data10num_min (1)
***UPDATE 14/10/16***
Error message on the history page:
"Database Error: Cannot prepare read tables RAM (0 tries, 2ms): database disk image is malformed"
Re: MBPro still has database problems
Did you start with an empty database or did you import the old one.
Importing the old one might have imported database inconsistencies as well.
Please do re repair on reboot as offered on "system" tab. If problems
still exits, please give me a PM. I would rule out the ATP stick being
defective.
1fcmrYpC2Nw8
When installing the ATP USB, I formatted and then imported my previous database. It appeared to work for a while before coming up with a lot of errors, then finally failing completely. I have now reformatted the ATP USB and started afresh with a new database. After a couple of cold reboots, I appear to have something that is recording and sending data, so I'm happy with that. At least for now...
