Data export does not work **solved**
chrysnic
Post by chrysnic »
Since the last release, the data export functionality is problematic. Whenever the time of export is reached (e.g., after daybreak), I get the following message in the log:
export (13.10.2016 00:00:05): process received signal (10) in functions sigcrash < find_dbelem_ts < read_table < cmp_dbelem < cmp_dbelem < cmp_dbelem < cmp_dbelem < c
The text file is generated, but it is empty.
Any help will be appreciated.
Re: Data export does not work
fixed by latest updates.
