MH not working on Raspberry Pi B+
Astrolorenzo
Post by Astrolorenzo »
Hi
I've spent already too much hours trying to set get Meteohub running on my Raspberry Pi Model B+....
The green LED in the RPi is either blinking or solid green depending on the Version of the Image I tried.
Ver. 5.0p & Ver. 5.0f: Green LED is repetitively blinking 8 times without end (until power off...)
Ver. 5.0: Green LED is solid green....
For writing the image to the SD card I tried both Win32DiskImager and Suse Imagewriter as proposed by the official instruction.
SD card is a Sandisk SDSDQUAN-008G-G4A.
I had also tried an image of raspian jessie lite.........this one booted without a flaw.....
I would really appreciate if somebody here could give me further advise on this issue.
Tomorrow I get my Meteostick which is quite useless without a working Metehub.... :cry:
Best regards
Lorenz
Re: MH not working on Raspberry Pi B+
When you have a linux machine, please setup new card via "dd" command, this always works for me.
dxwilli
Post by dxwilli »
Hi
I was using ImageUSB http://www.chip.de/downloads/ImageUSB_61096110.html to write the image to SD Card.
This was running fine for me.
SD Card is microSDHC from Sandisk, 32GB.
