Meteobridge PRO can now generate interactive graphs
After a weekend of massive coding I now have the first beta release of Meteobridge graphing ready to be tested by you. Please find a short explanation what to expect here: http://meteobridge.com/wiki/index.php/Forum
As said there will for sure still be some quirks. It is highly appreciated if you help me finding those. Wishes and suggestions are also welcome. I hope you will have some fun with this new feature, which has been too long on my "todo" list. I decided not to go with the aged "gnuplot" tools, but used the "amcharts" package in its newest version.
Graph generation is not hard coded in Meteobridge, but is based on chart templates. As a result it will be comparable easy to design more charts and if you have some coding background and make yourself familiar with the amcharts documentation (to be found on "amcharts.com" where you can also see lots of examples what this package can deliver) then you can adapt/design your own graphs. I know that just a fraction of users will do that, but the results of those can be share with the whole Meteobridge PRO community.
Re: Meteobridge PRO can now generate interactive graphs
By default running IE11 so was only getting the spinning spokes on your example, the Graph tab as well as creating a file as a service. Appears to only work with Chrome?
Code has been adapted to support IE versions 11 and below.
primsa
Post by primsa »
Only get spinning wheel on iPhone 7.
Todays update works fine with my iPhone 6 Plus.
http://tau.meteobridge.com/files/allino ... 60000.html
Tried updating several times today but still showing 3.1 Oct 17, 2016 Build 10613 same as per yesterday. Graphs under IE11 still spinning the wheel.
MeteoOudkarspel
Post by MeteoOudkarspel »
Same with me
Sincerely,
Please reboot to get newest version and try again.
Appears to be ok now, will have a more in depth look latter today.
MeteoOudkarspel
It works now, my thanks again
Sincerely,
cphMichael
Post by cphMichael »
At the wiki I can see you have released "Version 3.1 released October 19, 2016"
I have done several reboot but my version is still "Meteobridge 3.1 (Oct 18 2016, build 10615), FW 1.4"
/Michael
MeteoOudkarspel
Same with me
Sincerely,
Just released a new update (Oct 20) fixing some bugs around chart generation and FTP upload..
webcam
Post by webcam »
Would be nice if you could change wind at km/h.
DAP
Post by DAP »
Very nice.
Feature request: I have a 4K monitor, and while the graph autoscales to the width of the screen, it only fits in the top third of the display. Please have it autoscale vertically as well as horizontally.
Whatever you do please do not follow the favorite trend of many web designers and put it in a tiny frame with scroll bars. It is appalling how many web sites appear as a narrow column down the center of my screen, or worse in a tiny, non-resize-able window on my screen.
