Weatherbridge problems
jpk1018
Post by jpk1018 »
Just purchased weatherbridge from ambient weather. My first inclination is to send it back. It constently hangs up sending data to WU and right now Awekas. I have a VP2 pro station and yes I have a usb 2.0 hub between it and WB. I have also pulled power and batteries from my vp2. It might bsend for 2-10 min then just stops. Here is a copy of the msg from WB:
wnetd (22.10.2016 09:01:13): process started.
system (22.10.2016 09:01:13): start of logging process initiated.
logger (22.10.2016 09:01:13): Historical data loaded (24 records).
logger (22.10.2016 09:01:13): data logger (version 5.0r, build 10630) started.
logger (22.10.2016 09:01:14): connect station 0 (Vantage via USB serial).
logger (22.10.2016 09:01:14): wakeup sent.
logger (22.10.2016 09:01:14): internal logger activated.
logger (22.10.2016 09:01:14): syncing.
logger (22.10.2016 09:01:24): gettime request sent.
logger (22.10.2016 09:01:24): no Vantage time offset.
logger (22.10.2016 09:01:24): eeprom request sent.
logger (22.10.2016 09:01:24): rain collector size 0.01 inch per tick.
logger (22.10.2016 09:01:24): transmitter 1 active as station type (#0) "ISS".
logger (22.10.2016 09:01:24): firmware version request sent.
logger (22.10.2016 09:01:24): firmware version 3.15
logger (22.10.2016 09:01:24): no reading of Vantage's internal logger.
logger (22.10.2016 09:10:47): unexpected 0 bytes.
logger (22.10.2016 09:10:47): station 0 (Vantage), can't set attributes of device /dev/ttyMH to former values: Input/output error
logger (22.10.2016 09:10:47): disconnect station 0 (Vantage): response without data
logger (22.10.2016 09:11:17): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (22.10.2016 09:11:47): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (22.10.2016 09:12:17): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
system (22.10.2016 09:12:36): stop of logging process initiated.
logger (22.10.2016 09:12:36): parent process received termination signal (15).
logger (22.10.2016 09:12:36): child process received termination signal (15).
system (22.10.2016 09:12:36): start of logging process initiated.
logger (22.10.2016 09:12:37): Historical data loaded (24 records).
logger (22.10.2016 09:12:37): data logger (version 5.0r, build 10630) started.
logger (22.10.2016 09:12:37): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (22.10.2016 09:13:07): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (22.10.2016 09:13:37): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (22.10.2016 09:14:07): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (22.10.2016 09:14:37): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (22.10.2016 09:15:07): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (22.10.2016 09:15:37): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (22.10.2016 09:16:07): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (22.10.2016 09:16:37): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (22.10.2016 09:17:07): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (22.10.2016 09:17:37): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (22.10.2016 09:18:07): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (22.10.2016 09:18:07): child process received timeout signal (14).
logger (22.10.2016 09:18:08): data logger stopped.
logger (22.10.2016 09:18:08): Historical data loaded (24 records).
logger (22.10.2016 09:18:08): data logger (version 5.0r, build 10630) started.
logger (22.10.2016 09:18:09): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (22.10.2016 09:18:39): connect station 0 (Vantage via USB serial).
logger (22.10.2016 09:18:39): wakeup sent.
logger (22.10.2016 09:18:39): internal logger activated.
logger (22.10.2016 09:18:39): syncing.
logger (22.10.2016 09:18:49): gettime request sent.
logger (22.10.2016 09:18:59): gettime request sent.
logger (22.10.2016 09:19:10): gettime request sent.
logger (22.10.2016 09:19:10): no Vantage time offset.
logger (22.10.2016 09:19:10): eeprom request sent.
logger (22.10.2016 09:19:10): rain collector size 0.01 inch per tick.
logger (22.10.2016 09:19:10): transmitter 1 active as station type (#0) "ISS".
logger (22.10.2016 09:19:10): firmware version request sent.
logger (22.10.2016 09:19:10): firmware version 3.15
logger (22.10.2016 09:19:10): no reading of Vantage's internal logger.
Any help would be appreciated
John
Re: Weatherbridge problems
This looks like a missing USB hub. USB serial port cannot be established by the underlying Linux.
