Wifi network Channel
Jawi
Post by Jawi »
First Time Happy user of the meteobridge pro,. Congratulations on the smale peace of hardware with a lot of potention.
My simpele question in this, i use Channel 13 on the router had the Bridge the this options to?
Could this be changed in a sw update or is this hardware related.
Should this question be answared before, Sorry but please Point me in the Right direction
Greathings from the netherlands.
Re: Wifi network Channel
To my understanding, the access point is defining the channel. As MB PRO is mostly used as WLAN client, it just adapts to you WiFi routers channel selection in that mode of operation. Or are you using MB PRO as an access point?
Jawi
Post by Jawi »
When the router is set to Channel 13, i get the No network found massage.
Setting the router to Channel 9, it is detected An can be used.
Here in the neighberhoud there are a lot of routers that disturbe the lower Channel. Thats why i would like to switch Back to the prevered Channel.
Thanks for reading and info.
