changing primary sensor
Weerman
Post by Weerman »
I have a question about the change of the name of a primary sensor.
we have four leafwet sensors and two temperature sensors.
We have two main stations 1 and 2, each main station has 1 Davis unit 6345,
both are geconfugireerd as leaf station.
Main station 1 has a 6345 Davis with attached two leafwet sensors and two temperature sensors.
Sensor format for leaf-soil-temp station at station 1 in the Meteo Bridge Pro:
leaf temp = th15temp, geconfugireerd as leaf temp # 1 and set as the primary sensor.
leafhum = th15hum, geconfugireerd as soilmoisture # 1 and set as the primary sensor.
Leaf temp = th16temp, geconfugireerd as leaf temp # 2 and set as the primary sensor.
leafhum = th16hum, geconfugireerd as leafwetness # 2 and set as the primary sensor.
Main Station 2. Also has a 6345 Davis attached with only two sensors leafwet
Sensor format for leaf-soil-temp station at station 2 in the Meteo Bridge Pro:
leafhum = th85hum, geconfugireerd as leafwetness # 3 and set as the primary sensor.
leafhum = th86hum, geconfugireerd as leafwetness # 1 and set as the primary sensor.
while setting the two leaf soil temp stations we made some wrong settings.
The confugiratie as shown above needs a change:
How can we change sensor leafhum = th15hum in leafwetness # 1 and primary.
and how can we change sensor leafhum = th86hum in leafwetness # 4 and primary.
What is the procedure we must follow in order to make the correct settings.
