Meteobridge Pro sending bad data? **solved**
bealsc
Post by bealsc »
My Davis VantageVue is sending the correct data to my Davis VantageVue receiver but my Meteobridge is not getting and/or sending the same information to Weather Underground (an internally).
At this moment the temperature (for example) is 61 degF on the VantageVue. The Meteobridge IP page shows the following:
https://drive.google.com/open?id=0B2aVb ... FB5NE1sVGs
Weather Underground shows the following XML:
https://drive.google.com/open?id=0B2aVb ... FIybTZzMXM
The only data that is correct is the Humidity and it is displaying on Weather Underground (see screenshot):
https://drive.google.com/open?id=0B2aVb ... mRfSkdleDA
ANY HELP WOULD BE GREATLY APPRECIATED!!!!
MeteoOudkarspel
Re: Meteobridge Pro sending bad data?
Post by MeteoOudkarspel »
You may have trouble dealing with it too:
viewtopic.php?f=61&t=11418
Sincerely,
You are just referring to the indoor temperatures. Here is is known that the values from the Meteobridge PRO
are way too high because of the case heating up. You can compensate this in "weather station" tab by some calibration.
Please don't give to much on indoor temps, they are irrelevant for weather data observation.
Even original data from Vantage console (which is not sent out via RF) goes up when Davis data logger is attached or background light is activated.
bealsc
Re: Meteobridge Pro sending bad data? **solved**
Post by bealsc »
The data being received by Weather Underground (from Meteobridge) is incorrect, as best I can tell. It shows values like -9999 deg F and other discrepancies. Is this because my signal coming from the instrument to the Meteobridge is too weak? I haven't figured out a way to test it but in my troubleshooting I am thinking this might be an issue?
If so, would an aftermarket RF antenna help?
