tycon power systems pro weather stations TP2700wc
storm2710
Post by storm2710 »
any one know or have tried a tycon pro Tp2700wc weather station with meteobridge it looks like a fine offset station but it uses smartweather software rather than easyweather its unknown weather the meteobridge will be able to work this station or not a lot of the newer stations are using smart weather software rather than the easyweather which both look identical but one will not work with the other is there going to be any additions to meteobridge to work with these weather stations in the future ?
Re: tycon power systems pro weather stations TP2700wc
I can't say. Do you know which station from FineOffset is cloned by this? Knowing that I could give some assumptions.
As long as the USB protocol is the same it is not relevant which PC software is bundled with the station. it is not used anyway ;-)
jimmy
Post by jimmy »
Now Tycon TP2700 has been supported, would you do the same to meteoplug/hub?
yes, will be part of next update.
