I had network issues last night (I think my provider was down). Everything is up and running now, except that the Weatherbridge is not reporting to Weather Underground.
I notice that I have a new firmware of version Meteobridge 3.1 (Nov 19 2016, build 10736), FW 1.1 that downloaded during one of the reboots.
On the Network info, the WAN IP says No Internet Access, and no provider is given.
On the Live Data page, I get 2016-11-20 17:23:33 Error: wget: unable to resolve host address 'weatherstation.wunderground.com' (unlimited more tries).
All of the other services and networks are working.
I have another Weatherbridge with version Meteobridge 3.1 (Oct 30 2016, build 10685), FW 1.4 that is working fine.
David
Meteobridge not Reporting to Weather Underground **solved**
david.delano
- Senior Boarder
david.delano
- Senior Boarder
Re: Meteobridge not Reporting to Weather Underground
I have this fixed, for the time being, but I think there is still an issue with the current firmware.
First, I tried going from WLAN to LAN, but that didn't fix anything.
This morning I had another thought. It appears the problem is with DNS, so I went in and set the device manually, rather than using DHCP.
One big note...a reboot isn't looking like it's doing a reboot. The changes I put in didn't take. I hard rebooted the device, and the manual settings took effect, and now I'm back up on Weather Underground.
However, when I was trying to get the device back up before manually setting the network info, I did several hard reboots that didn't help. So, it's not just the reboot problem that is the issue. Something still seems to be going wrong with DHCP.
David
David
