No such file or directory error **solved**
drummonb
Post by drummonb »
Weather Underground is reporting that my station goes offline at least once every 24 hours. Rebooting Meteobridge solves the problem. I'm running Meteobridge 3.1 in an Airbridge Kit (Airbridge receiver + Weatherbridge for Vantage Vue) from Ambient Weather. Previously, it worked for over a year without issues.
The error message below posts every 30 seconds.
logger (21.11.2016 15:04:01): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
I can provide remote log-in if that's helpful.
Re: No such file or directory error
error message tells that the USB connection has dropped. Please check cables to the meteostick,
may be something has been pulled out a bit over time.
drummonb
Post by drummonb »
I reset all the cables but it continues to go offline with the directory error after it runs successfully for about 25 hours. Ram is consistently about 87%. The Weatherbridge is wireless.
Do you think it's a hardware issue?
I just released an update fixing some RAM usage issues. Please give it a reboot and try again.
Hard to say if HW had failed, especially, when it starts working fine and then drops after a while.
drummonb
Post by drummonb »
I really appreciate your help with this!
I rebooted with build 10756. The new version stopped the 25 hour offline cycle, but the error remains, it just seems to get past it on it's own now. See log below.
logger (08.12.2016 01:43:40): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:44:10): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:44:40): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:45:10): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:45:40): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:46:10): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:46:40): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:47:10): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:47:40): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:48:10): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:48:40): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:49:10): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:49:40): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:50:10): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:50:40): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:51:10): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:51:40): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:52:10): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:52:40): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:53:10): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:53:10): child process received timeout signal (14).
logger (08.12.2016 01:53:10): data logger stopped.
logger (08.12.2016 01:53:10): Historical data loaded (23 records).
logger (08.12.2016 01:53:10): data logger (version 5.0t, build 10756) started.
logger (08.12.2016 01:53:11): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:53:41): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:54:11): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:54:41): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:55:11): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:55:41): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:56:11): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:56:41): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:57:11): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:57:41): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:58:11): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:58:41): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:59:11): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 01:59:41): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:00:11): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:00:41): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:01:11): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:01:41): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:02:11): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:02:41): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:03:11): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:03:41): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:03:41): child process received timeout signal (14).
logger (08.12.2016 02:03:42): data logger stopped.
logger (08.12.2016 02:03:42): Historical data loaded (23 records).
logger (08.12.2016 02:03:42): data logger (version 5.0t, build 10756) started.
logger (08.12.2016 02:03:42): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:04:12): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:04:42): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:05:12): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:05:42): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:06:12): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:06:42): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:07:12): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:07:42): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:08:12): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:08:42): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:09:12): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:09:42): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:10:12): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:10:42): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:11:12): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:11:42): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:12:12): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:12:42): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:13:12): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:13:42): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:14:12): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:14:12): child process received timeout signal (14).
logger (08.12.2016 02:14:13): data logger stopped.
logger (08.12.2016 02:14:13): Historical data loaded (23 records).
logger (08.12.2016 02:14:13): data logger (version 5.0t, build 10756) started.
logger (08.12.2016 02:14:14): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:14:44): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:15:14): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:15:44): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:16:14): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:16:44): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:17:14): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:17:44): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:18:14): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:18:44): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:19:14): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:19:44): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:20:14): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:20:44): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:21:14): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:21:44): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:22:14): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:22:44): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:23:14): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:23:44): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:24:14): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:24:44): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:24:44): child process received timeout signal (14).
logger (08.12.2016 02:24:45): data logger stopped.
logger (08.12.2016 02:24:45): Historical data loaded (23 records).
logger (08.12.2016 02:24:45): data logger (version 5.0t, build 10756) started.
logger (08.12.2016 02:24:45): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:25:15): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:25:45): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:26:15): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:26:45): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:27:15): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:27:45): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:28:15): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:28:45): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:29:15): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:29:45): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:30:15): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:30:45): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:31:15): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:31:45): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:32:15): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:32:45): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:33:15): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:33:45): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:34:15): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:34:45): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:35:15): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:35:15): child process received timeout signal (14).
logger (08.12.2016 02:35:16): data logger stopped.
logger (08.12.2016 02:35:16): Historical data loaded (23 records).
logger (08.12.2016 02:35:16): data logger (version 5.0t, build 10756) started.
logger (08.12.2016 02:35:17): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:35:47): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:36:17): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:36:47): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:37:17): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:37:47): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:38:17): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:38:47): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:39:17): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:39:47): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:40:17): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:40:47): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:41:17): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:41:47): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:42:17): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:42:47): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:43:17): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:43:47): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:44:17): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:44:47): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:45:17): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:45:47): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:45:47): child process received timeout signal (14).
logger (08.12.2016 02:45:48): data logger stopped.
logger (08.12.2016 02:45:48): Historical data loaded (23 records).
logger (08.12.2016 02:45:48): data logger (version 5.0t, build 10756) started.
logger (08.12.2016 02:45:48): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:46:18): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:46:48): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:47:18): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:47:48): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:48:18): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:48:48): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:49:18): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:49:48): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:50:18): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:50:48): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:51:18): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:51:48): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:52:18): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:52:48): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:53:18): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:53:48): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:54:18): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:54:48): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:55:18): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:55:48): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:56:18): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:56:18): child process received timeout signal (14).
logger (08.12.2016 02:56:19): data logger stopped.
logger (08.12.2016 02:56:19): Historical data loaded (23 records).
logger (08.12.2016 02:56:19): data logger (version 5.0t, build 10756) started.
logger (08.12.2016 02:56:20): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (08.12.2016 02:56:50): connect station 0 (Meteostick Vantage via USB serial).
logger (08.12.2016 02:56:51): transmitter 1 registered as ISS
logger (08.12.2016 02:56:51): Meteostick Version 2.1 b3
logger (08.12.2016 02:56:51): debug off
logger (08.12.2016 02:56:51): verbose off
logger (08.12.2016 02:56:51): output raw (8 bytes)
logger (08.12.2016 02:56:51): output raw (10 bytes)
logger (08.12.2016 02:56:51): filter on
logger (08.12.2016 02:56:51): rx threshold set to -90db
logger (08.12.2016 02:56:51): listening to transmitter 1
logger (08.12.2016 02:56:51): bandwidth narrow
logger (08.12.2016 02:56:52): chip authentication ok: 14
logger (08.12.2016 02:56:52): frequency band 915MHz
logger (08.12.2016 02:58:31): wind0 data incomplete (missing outdoor temp for windchill)
logger (08.12.2016 02:58:34): wind0 data incomplete (missing outdoor temp for windchill)
logger (08.12.2016 02:58:37): wind0 data incomplete (missing outdoor temp for windchill)
logger (08.12.2016 02:58:39): wind0 data incomplete (missing outdoor temp for windchill)
logger (08.12.2016 02:58:42): wind0 data incomplete (missing outdoor temp for windchill)
logger (08.12.2016 02:58:44): wind0 data incomplete (missing outdoor temp for windchill)
Last messages indicates that it now works.
As it works fine for all other users, please check your cables, etc.
You don't need a USB hub using Meteostick.
drummonb
Re: No such file or directory error **solved**
Post by drummonb »
I think we solved it, and your first instinct was right. I removed the USB cradle that Ambient Weather supplied for the Meteostick, and plugged the stick directly in to the bridge. I've now gone five days without a data drop. Thank you!!
Usually the cradle improves RF reception significantly. If your cradle is doing
USB connnection drops, the cradle might be defective.
