Spikes in Barometric pressure
frogfoot
Post by frogfoot »
Recently I have been getting occasional zero values in the barometric data stored on my database. all other parameters contain valid data for the same sample .The database is updated with the following SQL
INSERT INTO meteo.alldata (`DateTime`,`T`,`Tmax`,`Tmin`,`WC`,`wcmax`,`wcmin`,`H`,`D`,`W`,`G`,`B`,`RR`,`R`,`RHr`,`P`,`A`,`HI`,`TSIG`,`WSIG`,`RSIG`) VALUES ('[YYYY]-[MM]-[DD] [hh]:[mm]:[ss]','[th0temp-avg5]','[th0temp-max5]','[th0temp-min5]','[wind0chill-avg5]','[wind0chill-max5]','[wind0chill-min5]','[th0hum-avg5]','[th0dew-avg5]','[wind0wind-avg5=mph]','[wind0wind-max5=mph]','[wind0dir-avg5]','[rain0rate-max5]','[rain0total-sumday]','[rain0total-sum60]','[thb0seapress-avg5]','[th0heatindex-avg5]','[th0heatindex-avg5]','[th0signal-act]','[wind0signal-act]','[rain0signal-act]')
The History tab does not display any missing values in the web page. and the log file contains the following
logger (01.12.2016 07:01:34): chip authentication ok: 14
logger (01.12.2016 07:01:34): frequency band 868MHz (EU)
system (01.12.2016 07:05:11): stop of logging process initiated.
logger (01.12.2016 07:05:11): parent process received termination signal (15).
logger (01.12.2016 07:05:11): child process received termination signal (15).
database (01.12.2016 07:05:11): process terminated normally.
test5m (01.12.2016 07:05:12): USB storage remounted: /dev/sda
sdb
database (01.12.2016 07:05:12): process started.
system (01.12.2016 07:05:12): start of logging process initiated.
logger (01.12.2016 07:05:13): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:05:13): Historical data loaded (0 records).
logger (01.12.2016 07:05:13): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:05:13): error while doing bind (port 5551): Address already in use
logger (01.12.2016 07:05:13): killed process "2877/sh" listening to port 5551.
database (01.12.2016 07:05:37): database sync done (40 tables, 206/4100 writes)
logger (01.12.2016 07:05:43): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:05:43): Historical data loaded (0 records).
logger (01.12.2016 07:05:43): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:05:43): error while doing bind (port 5551): Address already in use
logger (01.12.2016 07:05:43): killed process "2878/meteosys" listening to port 5551.
logger (01.12.2016 07:06:13): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:06:13): Historical data loaded (0 records).
logger (01.12.2016 07:06:13): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:06:13): connect station 0 (Meteostick Vantage via USB serial).
logger (01.12.2016 07:06:13): connect station 9 (System Data via Plug-in).
logger (01.12.2016 07:06:13): transmitter 1 registered as ISS
logger (01.12.2016 07:06:13): Meteostick Version 2.4
logger (01.12.2016 07:06:14): debug off
logger (01.12.2016 07:06:14): verbose off
logger (01.12.2016 07:06:14): output raw (8 bytes)
logger (01.12.2016 07:06:14): output raw (10 bytes)
logger (01.12.2016 07:06:14): filter on
logger (01.12.2016 07:06:14): rx threshold set to -75db
logger (01.12.2016 07:06:14): listening to transmitter 1
logger (01.12.2016 07:06:14): bandwidth narrow
logger (01.12.2016 07:06:14): chip authentication ok: 14
logger (01.12.2016 07:06:14): frequency band 868MHz (EU)
system (01.12.2016 07:10:21): stop of logging process initiated.
logger (01.12.2016 07:10:21): parent process received termination signal (15).
logger (01.12.2016 07:10:21): child process received termination signal (15).
database (01.12.2016 07:10:21): process terminated normally.
test5m (01.12.2016 07:10:22): USB storage remounted: /dev/sda
sdb
database (01.12.2016 07:10:22): process started.
system (01.12.2016 07:10:22): start of logging process initiated.
logger (01.12.2016 07:10:23): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:10:23): Historical data loaded (0 records).
logger (01.12.2016 07:10:23): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:10:23): error while doing bind (port 5551): Address already in use
logger (01.12.2016 07:10:23): killed process "3382/sh" listening to port 5551.
database (01.12.2016 07:10:47): database sync done (40 tables, 179/4100 writes)
logger (01.12.2016 07:10:53): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:10:53): Historical data loaded (0 records).
logger (01.12.2016 07:10:53): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:10:53): error while doing bind (port 5551): Address already in use
logger (01.12.2016 07:10:53): killed process "3383/meteosys" listening to port 5551.
logger (01.12.2016 07:11:23): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:11:23): Historical data loaded (0 records).
logger (01.12.2016 07:11:23): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:11:23): connect station 0 (Meteostick Vantage via USB serial).
logger (01.12.2016 07:11:23): connect station 9 (System Data via Plug-in).
logger (01.12.2016 07:11:24): transmitter 1 registered as ISS
logger (01.12.2016 07:11:24): Meteostick Version 2.4
logger (01.12.2016 07:11:24): debug off
logger (01.12.2016 07:11:24): verbose off
logger (01.12.2016 07:11:24): output raw (8 bytes)
logger (01.12.2016 07:11:24): output raw (10 bytes)
logger (01.12.2016 07:11:24): filter on
logger (01.12.2016 07:11:24): rx threshold set to -75db
logger (01.12.2016 07:11:24): listening to transmitter 1
logger (01.12.2016 07:11:24): bandwidth narrow
logger (01.12.2016 07:11:24): chip authentication ok: 14
logger (01.12.2016 07:11:24): frequency band 868MHz (EU)
system (01.12.2016 07:15:15): stop of logging process initiated.
logger (01.12.2016 07:15:15): parent process received termination signal (15).
logger (01.12.2016 07:15:15): child process received termination signal (15).
database (01.12.2016 07:15:15): process terminated normally.
test5m (01.12.2016 07:15:16): USB storage remounted: /dev/sda
sdb
database (01.12.2016 07:15:16): process started.
system (01.12.2016 07:15:16): start of logging process initiated.
logger (01.12.2016 07:15:17): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:15:17): Historical data loaded (0 records).
logger (01.12.2016 07:15:17): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:15:17): error while doing bind (port 5551): Address already in use
logger (01.12.2016 07:15:17): killed process "3897/sh" listening to port 5551.
database (01.12.2016 07:15:41): database sync done (40 tables, 212/4100 writes)
logger (01.12.2016 07:15:47): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:15:47): Historical data loaded (0 records).
logger (01.12.2016 07:15:47): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:15:47): error while doing bind (port 5551): Address already in use
logger (01.12.2016 07:15:47): killed process "3898/meteosys" listening to port 5551.
logger (01.12.2016 07:16:17): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:16:17): Historical data loaded (0 records).
logger (01.12.2016 07:16:17): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:16:17): connect station 0 (Meteostick Vantage via USB serial).
logger (01.12.2016 07:16:17): connect station 9 (System Data via Plug-in).
logger (01.12.2016 07:16:18): transmitter 1 registered as ISS
logger (01.12.2016 07:16:18): Meteostick Version 2.4
logger (01.12.2016 07:16:18): debug off
logger (01.12.2016 07:16:18): verbose off
logger (01.12.2016 07:16:18): output raw (8 bytes)
logger (01.12.2016 07:16:18): output raw (10 bytes)
logger (01.12.2016 07:16:18): filter on
logger (01.12.2016 07:16:18): rx threshold set to -75db
logger (01.12.2016 07:16:18): listening to transmitter 1
logger (01.12.2016 07:16:18): bandwidth narrow
logger (01.12.2016 07:16:18): chip authentication ok: 14
logger (01.12.2016 07:16:18): frequency band 868MHz (EU)
system (01.12.2016 07:21:01): stop of logging process initiated.
logger (01.12.2016 07:21:01): parent process received termination signal (15).
logger (01.12.2016 07:21:01): child process received termination signal (15).
database (01.12.2016 07:21:01): process terminated normally.
test5m (01.12.2016 07:21:02): USB storage remounted: /dev/sda
sdb
database (01.12.2016 07:21:02): process started.
system (01.12.2016 07:21:02): start of logging process initiated.
logger (01.12.2016 07:21:03): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:21:03): Historical data loaded (0 records).
logger (01.12.2016 07:21:03): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:21:03): error while doing bind (port 5551): Address already in use
logger (01.12.2016 07:21:03): killed process "4412/sh" listening to port 5551.
database (01.12.2016 07:21:27): database sync done (40 tables, 207/4100 writes)
logger (01.12.2016 07:21:33): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:21:33): Historical data loaded (0 records).
logger (01.12.2016 07:21:33): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:21:33): error while doing bind (port 5551): Address already in use
logger (01.12.2016 07:21:33): killed process "4413/meteosys" listening to port 5551.
logger (01.12.2016 07:22:03): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:22:03): Historical data loaded (0 records).
logger (01.12.2016 07:22:03): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:22:03): connect station 0 (Meteostick Vantage via USB serial).
logger (01.12.2016 07:22:03): connect station 9 (System Data via Plug-in).
logger (01.12.2016 07:22:04): transmitter 1 registered as ISS
logger (01.12.2016 07:22:04): Meteostick Version 2.4
logger (01.12.2016 07:22:04): debug off
logger (01.12.2016 07:22:04): verbose off
logger (01.12.2016 07:22:04): output raw (8 bytes)
logger (01.12.2016 07:22:04): output raw (10 bytes)
logger (01.12.2016 07:22:04): filter on
logger (01.12.2016 07:22:04): rx threshold set to -75db
logger (01.12.2016 07:22:04): listening to transmitter 1
logger (01.12.2016 07:22:04): bandwidth narrow
logger (01.12.2016 07:22:04): chip authentication ok: 14
logger (01.12.2016 07:22:04): frequency band 868MHz (EU)
system (01.12.2016 07:25:33): stop of logging process initiated.
logger (01.12.2016 07:25:33): parent process received termination signal (15).
logger (01.12.2016 07:25:33): child process received termination signal (15).
database (01.12.2016 07:25:33): process terminated normally.
test5m (01.12.2016 07:25:34): USB storage remounted: /dev/sda
sdb
database (01.12.2016 07:25:34): process started.
system (01.12.2016 07:25:34): start of logging process initiated.
logger (01.12.2016 07:25:35): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:25:35): Historical data loaded (0 records).
logger (01.12.2016 07:25:35): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:25:35): error while doing bind (port 5551): Address already in use
logger (01.12.2016 07:25:35): killed process "4999/sh" listening to port 5551.
database (01.12.2016 07:25:58): database sync done (40 tables, 176/4100 writes)
logger (01.12.2016 07:26:05): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:26:05): Historical data loaded (0 records).
logger (01.12.2016 07:26:05): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:26:05): error while doing bind (port 5551): Address already in use
logger (01.12.2016 07:26:05): killed process "5000/meteosys" listening to port 5551.
logger (01.12.2016 07:26:35): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:26:35): Historical data loaded (0 records).
logger (01.12.2016 07:26:35): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:26:35): connect station 0 (Meteostick Vantage via USB serial).
logger (01.12.2016 07:26:35): connect station 9 (System Data via Plug-in).
logger (01.12.2016 07:26:36): transmitter 1 registered as ISS
logger (01.12.2016 07:26:36): Meteostick Version 2.4
logger (01.12.2016 07:26:36): debug off
logger (01.12.2016 07:26:36): verbose off
logger (01.12.2016 07:26:36): output raw (8 bytes)
logger (01.12.2016 07:26:36): output raw (10 bytes)
logger (01.12.2016 07:26:36): filter on
logger (01.12.2016 07:26:36): rx threshold set to -75db
logger (01.12.2016 07:26:36): listening to transmitter 1
logger (01.12.2016 07:26:36): bandwidth narrow
logger (01.12.2016 07:26:36): chip authentication ok: 14
logger (01.12.2016 07:26:36): frequency band 868MHz (EU)
system (01.12.2016 07:31:28): stop of logging process initiated.
logger (01.12.2016 07:31:28): parent process received termination signal (15).
logger (01.12.2016 07:31:28): child process received termination signal (15).
database (01.12.2016 07:31:28): process terminated normally.
test5m (01.12.2016 07:31:29): USB storage remounted: /dev/sda
sdb
database (01.12.2016 07:31:29): process started.
system (01.12.2016 07:31:29): start of logging process initiated.
logger (01.12.2016 07:31:30): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:31:30): Historical data loaded (0 records).
logger (01.12.2016 07:31:30): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:31:30): error while doing bind (port 5551): Address already in use
logger (01.12.2016 07:31:30): killed process "5471/sh" listening to port 5551.
database (01.12.2016 07:31:54): database sync done (40 tables, 197/4100 writes)
logger (01.12.2016 07:32:00): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:32:00): Historical data loaded (0 records).
logger (01.12.2016 07:32:00): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:32:00): error while doing bind (port 5551): Address already in use
logger (01.12.2016 07:32:00): killed process "5472/meteosys" listening to port 5551.
logger (01.12.2016 07:32:30): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:32:30): Historical data loaded (0 records).
logger (01.12.2016 07:32:30): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:32:30): connect station 0 (Meteostick Vantage via USB serial).
logger (01.12.2016 07:32:30): connect station 9 (System Data via Plug-in).
logger (01.12.2016 07:32:31): transmitter 1 registered as ISS
logger (01.12.2016 07:32:31): Meteostick Version 2.4
logger (01.12.2016 07:32:31): debug off
logger (01.12.2016 07:32:31): verbose off
logger (01.12.2016 07:32:31): output raw (8 bytes)
logger (01.12.2016 07:32:31): output raw (10 bytes)
logger (01.12.2016 07:32:31): filter on
logger (01.12.2016 07:32:31): rx threshold set to -75db
logger (01.12.2016 07:32:31): listening to transmitter 1
logger (01.12.2016 07:32:31): bandwidth narrow
logger (01.12.2016 07:32:31): chip authentication ok: 14
logger (01.12.2016 07:32:31): frequency band 868MHz (EU)
system (01.12.2016 07:35:18): stop of logging process initiated.
logger (01.12.2016 07:35:18): parent process received termination signal (15).
logger (01.12.2016 07:35:18): child process received termination signal (15).
database (01.12.2016 07:35:18): process terminated normally.
test5m (01.12.2016 07:35:19): USB storage remounted: /dev/sda
sdb
database (01.12.2016 07:35:19): process started.
system (01.12.2016 07:35:19): start of logging process initiated.
logger (01.12.2016 07:35:20): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:35:20): Historical data loaded (0 records).
logger (01.12.2016 07:35:20): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:35:20): error while doing bind (port 5551): Address already in use
logger (01.12.2016 07:35:20): killed process "6070/sh" listening to port 5551.
database (01.12.2016 07:35:44): database sync done (40 tables, 159/4100 writes)
logger (01.12.2016 07:35:50): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:35:50): Historical data loaded (0 records).
logger (01.12.2016 07:35:50): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:35:50): error while doing bind (port 5551): Address already in use
logger (01.12.2016 07:35:50): killed process "6071/meteosys" listening to port 5551.
logger (01.12.2016 07:36:20): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:36:20): Historical data loaded (0 records).
logger (01.12.2016 07:36:20): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:36:20): connect station 0 (Meteostick Vantage via USB serial).
logger (01.12.2016 07:36:20): connect station 9 (System Data via Plug-in).
logger (01.12.2016 07:36:21): transmitter 1 registered as ISS
logger (01.12.2016 07:36:21): Meteostick Version 2.4
logger (01.12.2016 07:36:21): debug off
logger (01.12.2016 07:36:21): verbose off
logger (01.12.2016 07:36:21): output raw (8 bytes)
logger (01.12.2016 07:36:21): output raw (10 bytes)
logger (01.12.2016 07:36:21): filter on
logger (01.12.2016 07:36:21): rx threshold set to -75db
logger (01.12.2016 07:36:21): listening to transmitter 1
logger (01.12.2016 07:36:21): bandwidth narrow
logger (01.12.2016 07:36:21): chip authentication ok: 14
logger (01.12.2016 07:36:21): frequency band 868MHz (EU)
system (01.12.2016 07:40:28): stop of logging process initiated.
logger (01.12.2016 07:40:28): parent process received termination signal (15).
logger (01.12.2016 07:40:28): child process received termination signal (15).
database (01.12.2016 07:40:28): process terminated normally.
test5m (01.12.2016 07:40:29): USB storage remounted: /dev/sda
sdb
database (01.12.2016 07:40:29): process started.
system (01.12.2016 07:40:29): start of logging process initiated.
logger (01.12.2016 07:40:30): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:40:30): Historical data loaded (0 records).
logger (01.12.2016 07:40:30): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:40:30): error while doing bind (port 5551): Address already in use
logger (01.12.2016 07:40:30): killed process "6496/sh" listening to port 5551.
database (01.12.2016 07:40:54): database sync done (40 tables, 176/4100 writes)
logger (01.12.2016 07:41:00): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:41:00): Historical data loaded (0 records).
logger (01.12.2016 07:41:00): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:41:00): error while doing bind (port 5551): Address already in use
logger (01.12.2016 07:41:00): killed process "6497/meteosys" listening to port 5551.
logger (01.12.2016 07:41:30): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:41:30): Historical data loaded (0 records).
logger (01.12.2016 07:41:30): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:41:30): connect station 0 (Meteostick Vantage via USB serial).
logger (01.12.2016 07:41:30): connect station 9 (System Data via Plug-in).
logger (01.12.2016 07:41:31): transmitter 1 registered as ISS
logger (01.12.2016 07:41:31): Meteostick Version 2.4
logger (01.12.2016 07:41:31): debug off
logger (01.12.2016 07:41:31): verbose off
logger (01.12.2016 07:41:31): output raw (8 bytes)
logger (01.12.2016 07:41:31): output raw (10 bytes)
logger (01.12.2016 07:41:31): filter on
logger (01.12.2016 07:41:31): rx threshold set to -75db
logger (01.12.2016 07:41:31): listening to transmitter 1
logger (01.12.2016 07:41:31): bandwidth narrow
logger (01.12.2016 07:41:31): chip authentication ok: 14
logger (01.12.2016 07:41:31): frequency band 868MHz (EU)
system (01.12.2016 07:46:16): stop of logging process initiated.
logger (01.12.2016 07:46:16): parent process received termination signal (15).
logger (01.12.2016 07:46:16): child process received termination signal (15).
logger (01.12.2016 07:46:16): disconnect station 0 (Meteostick Vantage): exit
logger (01.12.2016 07:46:16): disconnect station 9 (System Data): exit
logger (01.12.2016 07:46:17): data logger stopped.
logger (01.12.2016 07:46:17): databases disconnected.
database (01.12.2016 07:46:17): process terminated normally.
test5m (01.12.2016 07:46:18): USB storage remounted: /dev/sda
sdb
database (01.12.2016 07:46:18): process started.
system (01.12.2016 07:46:18): start of logging process initiated.
logger (01.12.2016 07:46:19): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:46:19): Historical data loaded (0 records).
logger (01.12.2016 07:46:19): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:46:20): connect station 0 (Meteostick Vantage via USB serial).
logger (01.12.2016 07:46:20): connect station 9 (System Data via Plug-in).
logger (01.12.2016 07:46:20): transmitter 1 registered as ISS
logger (01.12.2016 07:46:20): Meteostick Version 2.4
logger (01.12.2016 07:46:20): debug off
logger (01.12.2016 07:46:20): verbose off
logger (01.12.2016 07:46:20): output raw (8 bytes)
logger (01.12.2016 07:46:20): output raw (10 bytes)
logger (01.12.2016 07:46:20): filter on
logger (01.12.2016 07:46:20): rx threshold set to -75db
logger (01.12.2016 07:46:20): listening to transmitter 1
logger (01.12.2016 07:46:20): bandwidth narrow
logger (01.12.2016 07:46:21): chip authentication ok: 14
logger (01.12.2016 07:46:21): frequency band 868MHz (EU)
database (01.12.2016 07:46:44): database sync done (40 tables, 147/4295 writes)
system (01.12.2016 07:51:13): stop of logging process initiated.
logger (01.12.2016 07:51:13): parent process received termination signal (15).
logger (01.12.2016 07:51:13): child process received termination signal (15).
database (01.12.2016 07:51:13): process terminated normally.
test5m (01.12.2016 07:51:14): USB storage remounted: /dev/sda
sdb
database (01.12.2016 07:51:14): process started.
system (01.12.2016 07:51:14): start of logging process initiated.
logger (01.12.2016 07:51:15): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:51:15): Historical data loaded (0 records).
logger (01.12.2016 07:51:15): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:51:15): error while doing bind (port 5551): Address already in use
logger (01.12.2016 07:51:15): killed process "7599/sh" listening to port 5551.
database (01.12.2016 07:51:40): database sync done (40 tables, 120/4295 writes)
logger (01.12.2016 07:51:45): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:51:45): Historical data loaded (0 records).
logger (01.12.2016 07:51:45): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:51:45): error while doing bind (port 5551): Address already in use
logger (01.12.2016 07:51:45): killed process "7600/meteosys" listening to port 5551.
logger (01.12.2016 07:52:15): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:52:15): Historical data loaded (0 records).
logger (01.12.2016 07:52:15): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:52:15): connect station 0 (Meteostick Vantage via USB serial).
logger (01.12.2016 07:52:15): connect station 9 (System Data via Plug-in).
logger (01.12.2016 07:52:16): transmitter 1 registered as ISS
logger (01.12.2016 07:52:16): Meteostick Version 2.4
logger (01.12.2016 07:52:16): debug off
logger (01.12.2016 07:52:16): verbose off
logger (01.12.2016 07:52:16): output raw (8 bytes)
logger (01.12.2016 07:52:16): output raw (10 bytes)
logger (01.12.2016 07:52:16): filter on
logger (01.12.2016 07:52:16): rx threshold set to -75db
logger (01.12.2016 07:52:16): listening to transmitter 1
logger (01.12.2016 07:52:16): bandwidth narrow
logger (01.12.2016 07:52:16): chip authentication ok: 14
logger (01.12.2016 07:52:16): frequency band 868MHz (EU)
system (01.12.2016 07:56:19): stop of logging process initiated.
logger (01.12.2016 07:56:19): parent process received termination signal (15).
logger (01.12.2016 07:56:19): child process received termination signal (15).
database (01.12.2016 07:56:19): process terminated normally.
test5m (01.12.2016 07:56:20): USB storage remounted: /dev/sda
sdb
database (01.12.2016 07:56:20): process started.
system (01.12.2016 07:56:20): start of logging process initiated.
logger (01.12.2016 07:56:21): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:56:21): Historical data loaded (0 records).
logger (01.12.2016 07:56:21): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:56:21): error while doing bind (port 5551): Address already in use
logger (01.12.2016 07:56:21): killed process "8198/sh" listening to port 5551.
database (01.12.2016 07:56:46): database sync done (40 tables, 126/4295 writes)
logger (01.12.2016 07:56:51): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:56:51): Historical data loaded (0 records).
logger (01.12.2016 07:56:51): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:56:51): error while doing bind (port 5551): Address already in use
logger (01.12.2016 07:56:51): killed process "8199/meteosys" listening to port 5551.
logger (01.12.2016 07:57:21): databases connected. Update interval 3600 seconds.
logger (01.12.2016 07:57:21): Historical data loaded (0 records).
logger (01.12.2016 07:57:21): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 07:57:21): connect station 0 (Meteostick Vantage via USB serial).
logger (01.12.2016 07:57:21): connect station 9 (System Data via Plug-in).
logger (01.12.2016 07:57:22): transmitter 1 registered as ISS
logger (01.12.2016 07:57:22): Meteostick Version 2.4
logger (01.12.2016 07:57:22): debug off
logger (01.12.2016 07:57:22): verbose off
logger (01.12.2016 07:57:22): output raw (8 bytes)
logger (01.12.2016 07:57:22): output raw (10 bytes)
logger (01.12.2016 07:57:22): filter on
logger (01.12.2016 07:57:22): rx threshold set to -75db
logger (01.12.2016 07:57:22): listening to transmitter 1
logger (01.12.2016 07:57:22): bandwidth narrow
logger (01.12.2016 07:57:22): chip authentication ok: 14
logger (01.12.2016 07:57:22): frequency band 868MHz (EU)
system (01.12.2016 08:00:58): stop of logging process initiated.
logger (01.12.2016 08:00:58): parent process received termination signal (15).
logger (01.12.2016 08:00:58): child process received termination signal (15).
database (01.12.2016 08:00:58): process terminated normally.
test5m (01.12.2016 08:00:59): USB storage remounted: /dev/sda
sdb
database (01.12.2016 08:00:59): process started.
system (01.12.2016 08:00:59): start of logging process initiated.
logger (01.12.2016 08:01:00): databases connected. Update interval 3600 seconds.
logger (01.12.2016 08:01:00): Historical data loaded (0 records).
logger (01.12.2016 08:01:00): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 08:01:00): error while doing bind (port 5551): Address already in use
logger (01.12.2016 08:01:00): killed process "8717/sh" listening to port 5551.
database (01.12.2016 08:01:25): database sync done (40 tables, 0/4295 writes)
logger (01.12.2016 08:01:30): databases connected. Update interval 3600 seconds.
logger (01.12.2016 08:01:30): Historical data loaded (0 records).
logger (01.12.2016 08:01:30): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 08:01:30): error while doing bind (port 5551): Address already in use
logger (01.12.2016 08:01:30): killed process "8718/meteosys" listening to port 5551.
logger (01.12.2016 08:02:00): databases connected. Update interval 3600 seconds.
logger (01.12.2016 08:02:00): Historical data loaded (0 records).
logger (01.12.2016 08:02:00): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 08:02:01): connect station 0 (Meteostick Vantage via USB serial).
logger (01.12.2016 08:02:01): connect station 9 (System Data via Plug-in).
logger (01.12.2016 08:02:01): transmitter 1 registered as ISS
logger (01.12.2016 08:02:01): Meteostick Version 2.4
logger (01.12.2016 08:02:01): debug off
logger (01.12.2016 08:02:01): verbose off
logger (01.12.2016 08:02:01): output raw (8 bytes)
logger (01.12.2016 08:02:01): output raw (10 bytes)
logger (01.12.2016 08:02:01): filter on
logger (01.12.2016 08:02:01): rx threshold set to -75db
logger (01.12.2016 08:02:01): listening to transmitter 1
logger (01.12.2016 08:02:01): bandwidth narrow
logger (01.12.2016 08:02:01): chip authentication ok: 14
logger (01.12.2016 08:02:01): frequency band 868MHz (EU)
system (01.12.2016 08:05:56): stop of logging process initiated.
logger (01.12.2016 08:05:56): parent process received termination signal (15).
logger (01.12.2016 08:05:56): child process received termination signal (15).
database (01.12.2016 08:05:56): process terminated normally.
test5m (01.12.2016 08:05:57): USB storage remounted: /dev/sda
sdb
database (01.12.2016 08:05:57): process started.
system (01.12.2016 08:05:57): start of logging process initiated.
logger (01.12.2016 08:05:58): databases connected. Update interval 3600 seconds.
logger (01.12.2016 08:05:58): Historical data loaded (0 records).
logger (01.12.2016 08:05:58): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 08:05:58): error while doing bind (port 5551): Address already in use
logger (01.12.2016 08:05:58): killed process "9219/sh" listening to port 5551.
database (01.12.2016 08:06:23): database sync done (40 tables, 244/4295 writes)
logger (01.12.2016 08:06:28): databases connected. Update interval 3600 seconds.
logger (01.12.2016 08:06:28): Historical data loaded (0 records).
logger (01.12.2016 08:06:28): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 08:06:28): error while doing bind (port 5551): Address already in use
logger (01.12.2016 08:06:28): killed process "9220/meteosys" listening to port 5551.
logger (01.12.2016 08:06:58): databases connected. Update interval 3600 seconds.
logger (01.12.2016 08:06:58): Historical data loaded (0 records).
logger (01.12.2016 08:06:58): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 08:06:58): connect station 0 (Meteostick Vantage via USB serial).
logger (01.12.2016 08:06:58): connect station 9 (System Data via Plug-in).
logger (01.12.2016 08:06:59): transmitter 1 registered as ISS
logger (01.12.2016 08:06:59): Meteostick Version 2.4
logger (01.12.2016 08:06:59): debug off
logger (01.12.2016 08:06:59): verbose off
logger (01.12.2016 08:06:59): output raw (8 bytes)
logger (01.12.2016 08:06:59): output raw (10 bytes)
logger (01.12.2016 08:06:59): filter on
logger (01.12.2016 08:06:59): rx threshold set to -75db
logger (01.12.2016 08:06:59): listening to transmitter 1
logger (01.12.2016 08:06:59): bandwidth narrow
logger (01.12.2016 08:06:59): chip authentication ok: 14
logger (01.12.2016 08:06:59): frequency band 868MHz (EU)
system (01.12.2016 08:10:56): stop of logging process initiated.
logger (01.12.2016 08:10:56): parent process received termination signal (15).
logger (01.12.2016 08:10:56): child process received termination signal (15).
database (01.12.2016 08:10:56): process terminated normally.
test5m (01.12.2016 08:10:57): USB storage remounted: /dev/sda
sdb
database (01.12.2016 08:10:57): process started.
system (01.12.2016 08:10:57): start of logging process initiated.
logger (01.12.2016 08:10:58): databases connected. Update interval 3600 seconds.
logger (01.12.2016 08:10:58): Historical data loaded (0 records).
logger (01.12.2016 08:10:58): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 08:10:58): error while doing bind (port 5551): Address already in use
logger (01.12.2016 08:10:58): killed process "9710/sh" listening to port 5551.
database (01.12.2016 08:11:23): database sync done (40 tables, 182/4295 writes)
logger (01.12.2016 08:11:28): databases connected. Update interval 3600 seconds.
logger (01.12.2016 08:11:28): Historical data loaded (0 records).
logger (01.12.2016 08:11:28): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 08:11:28): error while doing bind (port 5551): Address already in use
logger (01.12.2016 08:11:28): killed process "9711/meteosys" listening to port 5551.
logger (01.12.2016 08:11:58): databases connected. Update interval 3600 seconds.
logger (01.12.2016 08:11:58): Historical data loaded (0 records).
logger (01.12.2016 08:11:58): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 08:11:58): connect station 0 (Meteostick Vantage via USB serial).
logger (01.12.2016 08:11:59): connect station 9 (System Data via Plug-in).
logger (01.12.2016 08:11:59): transmitter 1 registered as ISS
logger (01.12.2016 08:11:59): Meteostick Version 2.4
logger (01.12.2016 08:11:59): debug off
logger (01.12.2016 08:11:59): verbose off
logger (01.12.2016 08:11:59): output raw (8 bytes)
logger (01.12.2016 08:11:59): output raw (10 bytes)
logger (01.12.2016 08:11:59): filter on
logger (01.12.2016 08:11:59): rx threshold set to -75db
logger (01.12.2016 08:11:59): listening to transmitter 1
logger (01.12.2016 08:11:59): bandwidth narrow
logger (01.12.2016 08:11:59): chip authentication ok: 14
logger (01.12.2016 08:11:59): frequency band 868MHz (EU)
system (01.12.2016 08:16:34): stop of logging process initiated.
logger (01.12.2016 08:16:34): parent process received termination signal (15).
logger (01.12.2016 08:16:34): child process received termination signal (15).
database (01.12.2016 08:16:34): process terminated normally.
test5m (01.12.2016 08:16:35): USB storage remounted: /dev/sda
sdb
database (01.12.2016 08:16:35): process started.
system (01.12.2016 08:16:36): start of logging process initiated.
logger (01.12.2016 08:16:36): databases connected. Update interval 3600 seconds.
logger (01.12.2016 08:16:36): Historical data loaded (0 records).
logger (01.12.2016 08:16:36): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 08:16:36): error while doing bind (port 5551): Address already in use
logger (01.12.2016 08:16:36): killed process "10235/sh" listening to port 5551.
database (01.12.2016 08:17:01): database sync done (40 tables, 208/4295 writes)
logger (01.12.2016 08:17:06): databases connected. Update interval 3600 seconds.
logger (01.12.2016 08:17:06): Historical data loaded (0 records).
logger (01.12.2016 08:17:06): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 08:17:06): error while doing bind (port 5551): Address already in use
logger (01.12.2016 08:17:06): killed process "10236/meteosys" listening to port 5551.
logger (01.12.2016 08:17:36): databases connected. Update interval 3600 seconds.
logger (01.12.2016 08:17:36): Historical data loaded (0 records).
logger (01.12.2016 08:17:36): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 08:17:37): connect station 0 (Meteostick Vantage via USB serial).
logger (01.12.2016 08:17:37): connect station 9 (System Data via Plug-in).
logger (01.12.2016 08:17:37): transmitter 1 registered as ISS
logger (01.12.2016 08:17:37): Meteostick Version 2.4
logger (01.12.2016 08:17:37): debug off
logger (01.12.2016 08:17:37): verbose off
logger (01.12.2016 08:17:37): output raw (8 bytes)
logger (01.12.2016 08:17:37): output raw (10 bytes)
logger (01.12.2016 08:17:37): filter on
logger (01.12.2016 08:17:37): rx threshold set to -75db
logger (01.12.2016 08:17:37): listening to transmitter 1
logger (01.12.2016 08:17:37): bandwidth narrow
logger (01.12.2016 08:17:37): chip authentication ok: 14
logger (01.12.2016 08:17:37): frequency band 868MHz (EU)
system (01.12.2016 08:20:06): stop of logging process initiated.
logger (01.12.2016 08:20:06): parent process received termination signal (15).
logger (01.12.2016 08:20:06): child process received termination signal (15).
logger (01.12.2016 08:20:06): disconnect station 0 (Meteostick Vantage): exit
logger (01.12.2016 08:20:06): disconnect station 9 (System Data): exit
logger (01.12.2016 08:20:07): data logger stopped.
logger (01.12.2016 08:20:07): databases disconnected.
database (01.12.2016 08:20:07): process terminated normally.
test5m (01.12.2016 08:20:08): USB storage remounted: /dev/sda
sdb
database (01.12.2016 08:20:09): process started.
system (01.12.2016 08:20:09): start of logging process initiated.
logger (01.12.2016 08:20:09): databases connected. Update interval 3600 seconds.
logger (01.12.2016 08:20:09): Historical data loaded (0 records).
logger (01.12.2016 08:20:09): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 08:20:10): connect station 0 (Meteostick Vantage via USB serial).
logger (01.12.2016 08:20:10): connect station 9 (System Data via Plug-in).
logger (01.12.2016 08:20:11): transmitter 1 registered as ISS
logger (01.12.2016 08:20:11): Meteostick Version 2.4
logger (01.12.2016 08:20:11): debug off
logger (01.12.2016 08:20:11): verbose off
logger (01.12.2016 08:20:11): output raw (8 bytes)
logger (01.12.2016 08:20:11): output raw (10 bytes)
logger (01.12.2016 08:20:11): filter on
logger (01.12.2016 08:20:11): rx threshold set to -75db
logger (01.12.2016 08:20:11): listening to transmitter 1
logger (01.12.2016 08:20:11): bandwidth narrow
logger (01.12.2016 08:20:11): chip authentication ok: 14
logger (01.12.2016 08:20:11): frequency band 868MHz (EU)
database (01.12.2016 08:20:35): database sync done (40 tables, 198/4295 writes)
system (01.12.2016 08:25:13): stop of logging process initiated.
logger (01.12.2016 08:25:13): parent process received termination signal (15).
logger (01.12.2016 08:25:13): child process received termination signal (15).
database (01.12.2016 08:25:13): process terminated normally.
test5m (01.12.2016 08:25:14): USB storage remounted: /dev/sda
sdb
database (01.12.2016 08:25:14): process started.
system (01.12.2016 08:25:14): start of logging process initiated.
logger (01.12.2016 08:25:15): databases connected. Update interval 3600 seconds.
logger (01.12.2016 08:25:15): Historical data loaded (0 records).
logger (01.12.2016 08:25:15): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 08:25:15): error while doing bind (port 5551): Address already in use
logger (01.12.2016 08:25:15): killed process "11399/sh" listening to port 5551.
database (01.12.2016 08:25:40): database sync done (40 tables, 219/4295 writes)
logger (01.12.2016 08:25:45): databases connected. Update interval 3600 seconds.
logger (01.12.2016 08:25:45): Historical data loaded (0 records).
logger (01.12.2016 08:25:45): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 08:25:45): error while doing bind (port 5551): Address already in use
logger (01.12.2016 08:25:45): killed process "11400/meteosys" listening to port 5551.
logger (01.12.2016 08:26:15): databases connected. Update interval 3600 seconds.
logger (01.12.2016 08:26:15): Historical data loaded (0 records).
logger (01.12.2016 08:26:15): data logger (version 5.0s, build 10749) started.
logger (01.12.2016 08:26:15): connect station 0 (Meteostick Vantage via USB serial).
logger (01.12.2016 08:26:16): connect station 9 (System Data via Plug-in).
logger (01.12.2016 08:26:16): transmitter 1 registered as ISS
logger (01.12.2016 08:26:16): Meteostick Version 2.4
logger (01.12.2016 08:26:16): debug off
logger (01.12.2016 08:26:16): verbose off
logger (01.12.2016 08:26:16): output raw (8 bytes)
logger (01.12.2016 08:26:16): output raw (10 bytes)
logger (01.12.2016 08:26:16): filter on
logger (01.12.2016 08:26:16): rx threshold set to -75db
logger (01.12.2016 08:26:16): listening to transmitter 1
logger (01.12.2016 08:26:16): bandwidth narrow
logger (01.12.2016 08:26:16): chip authentication ok: 14
logger (01.12.2016 08:26:16): frequency band 868MHz (EU)
I am storing the database on an external USB drive, as I have already had one failure of the internal memory, and I have tried two different external drives, but the problem persists.
Re: Spikes in Barometric pressure
Can you please send me result of "http://ip-of-my-mbpro/cgi-bin/system.cgi?dmesg" to "info(at)meteobridge.com"?
I would like to rule out that it is a side effect of defective internal USB storage.
frogfoot
Post by frogfoot »
I have sent the results you requested via email. I have noticed that the spikes sometimes seem to occur after I toggle WiFi off on the router (after changing settings for example) or reboot the router. They will continue until I reboot the mbpro.
