Weather Network Status: No weather network traffic
16sail
Post by 16sail »
My weatherbridge stopped uploading data sometime last week.
The weatherbridge is receiving data from the weather station as evidenced by fresh information on the "Live Data" tab. In addition, the weather networks tab shows correct login information for both WeatherForYou and CWOP. However, the "Live Data" tab shows "Weather Network Status: No weather network traffic".
Here are some details from the system tab. Any and all help appreciated.
TL-MR3020 (no USB hub)
RAM: 29364 kB total, 3840 kB free (86% used)
SW Version: Meteobridge 3.1 (Dec 3 2016, build 10756), FW 1.4
Uptime: 0 hours, 15 minutes Buffer:
Network
MAC: <REDACTED>
LAN IP: 192.168.1.26 WLAN IP: --
LAN Mask: 255.255.255.0 WLAN Mask: --
Gateway: 192.168.1.1 TX Traffic: 1.1 MB
DNS: 8.8.8.4 RX Traffic: 4.6 MB
WAN IP: <REDACTED BUT NOT BLANK> Provider: Comcast Cable
Messages
wnetd (07.12.2016 22:13:55): process started.
system (07.12.2016 22:13:55): start of logging process initiated.
logger (07.12.2016 22:13:55): Historical data loaded (23 records).
logger (07.12.2016 22:13:55): data logger (version 5.0t, build 10756) started.
logger (07.12.2016 22:13:56): connect station 0 (Observer-IP via USB HID).
logger (07.12.2016 22:24:27): child process received timeout signal (14).
logger (07.12.2016 22:24:27): disconnect station 0 (Observer-IP): exit
logger (07.12.2016 22:24:28): data logger stopped.
logger (07.12.2016 22:24:28): Historical data loaded (23 records).
logger (07.12.2016 22:24:28): data logger (version 5.0t, build 10756) started.
logger (07.12.2016 22:24:28): connect station 0 (Observer-IP via USB HID).
Re: Weather Network Status: No weather network traffic
This looks very much like your Observer-IP did receive a new IP form
your router and by that the IP given to Meteobridge where to reach
the station does point to nowhere.
Please configure your router to give the Observer-IP a fixed IP
based on its MAC. If you don't do that this trouble will show up
again and again and again.
You can check on live data tab, if data coming in. No data = no upload.
