Suggestion for changing "Messages".
droiddk
Post by droiddk »
Hello
Suggestion:
Change the ”Messages” on the ”System” tab.
Had a break-down today, no connection between logger and Meteobridge and this was all “Messages” gave me:
logger (08.12.2016 12:17:37): 10.10.17.103's 2nd request on port 22222 declined.
logger (08.12.2016 12:17:38): 10.10.17.103's 2nd request on port 22222 declined.
And so on…
The same during normal operation, this is all I can see under messages:
logger (08.12.2016 16:42:49): connection on port 22222 closed.
logger (08.12.2016 16:42:49): 10.10.17.103's request on port 22222 accepted.
And so on...
Maybe another solution when Meteobridge is used as remote-bridge for weathersoftware?
Second, any news about Meteostick and evaporation, sent you (Boris) a email about this some time ago?
droiddk
Re: Suggestion for changing "Messages".
Post by droiddk »
Up.
droiddk
Post by droiddk »
I was hoping this was fixed with the latest release:
"summarizes repeating entries from the logger process in the messages section of "System" tab."
But its not :/
Identical lines generated from logger process following directly one by one should be suppressed now.
Can you please post an example where it is not working that way?
droiddk
Post by droiddk »
admin wrote: Can you please post an example where it is not working that way?
logger (11.02.2017 15:37:04): connection on port 22222 closed.
logger (11.02.2017 15:37:04): 10.10.17.34's request on port 22222 accepted.
logger (11.02.2017 15:37:09): connection on port 22222 closed.
logger (11.02.2017 15:37:09): 10.10.17.34's request on port 22222 accepted.
logger (11.02.2017 15:37:15): connection on port 22222 closed.
logger (11.02.2017 15:37:15): 10.10.17.34's request on port 22222 accepted.
logger (11.02.2017 15:37:20): connection on port 22222 closed.
logger (11.02.2017 15:37:20): 10.10.17.34's request on port 22222 accepted.
YJB
Post by YJB »
I see more or less the same on meteohub with the logger process:
logger (18.12.2016 08:02:55): disconnect station 0 (RFXCOM): response without data
logger (18.12.2016 08:03:25): station 0 (RFXCOM), can't write baud rate toggle word "F025" to device /dev/ttyUSB0: No such device
logger (18.12.2016 08:03:55): station 0 (RFXCOM), can't write baud rate toggle word "F025" to device /dev/ttyUSB0: No such device
logger (18.12.2016 08:04:25): station 0 (RFXCOM), can't write baud rate toggle word "F025" to device /dev/ttyUSB0: No such device
logger (18.12.2016 08:04:55): station 0 (RFXCOM), can't write baud rate toggle word "F025" to device /dev/ttyUSB0: No such device
logger (18.12.2016 08:05:25): station 0 (RFXCOM), can't write baud rate toggle word "F025" to device /dev/ttyUSB0: No such device
logger (18.12.2016 08:05:55): station 0 (RFXCOM), can't write baud rate toggle word "F025" to device /dev/ttyUSB0: No such device
logger (18.12.2016 08:06:25): station 0 (RFXCOM), can't write baud rate toggle word "F025" to device /dev/ttyUSB0: No such device
logger (18.12.2016 08:06:55): station 0 (RFXCOM), can't write baud rate toggle word "F025" to device /dev/ttyUSB0: No such device
It does not filter out that, because it is not two identical lines following each other.
That is how it is designed.
YJB wrote:I see more or less the same on meteohub with the logger process:
So far I did not implement this for Meteohub. These kind of repeats will be suppressed in Meteobridge only.
droiddk
Post by droiddk »
But it should...I only sees that in my messages, warnings are left out. Maybe a option for disabling messages like that? Or another tab.
