Another failure
frogfoot
Another failure
Post by frogfoot »
after running reliably for a period of a few months (apart from the odd zero value in the barometric pressure data) I had a total logging failure today
logger (08.12.2016 16:55:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 16:55:29): Historical data loaded (0 records).
logger (08.12.2016 16:55:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 16:55:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 16:55:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 16:55:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 16:55:59): Historical data loaded (0 records).
logger (08.12.2016 16:55:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 16:55:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 16:55:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 16:56:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 16:56:29): Historical data loaded (0 records).
logger (08.12.2016 16:56:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 16:56:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 16:56:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 16:56:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 16:56:59): Historical data loaded (0 records).
logger (08.12.2016 16:56:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 16:56:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 16:56:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 16:57:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 16:57:29): Historical data loaded (0 records).
logger (08.12.2016 16:57:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 16:57:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 16:57:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 16:57:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 16:57:59): Historical data loaded (0 records).
logger (08.12.2016 16:57:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 16:57:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 16:57:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 16:58:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 16:58:29): Historical data loaded (0 records).
logger (08.12.2016 16:58:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 16:58:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 16:58:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 16:58:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 16:58:59): Historical data loaded (0 records).
logger (08.12.2016 16:58:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 16:58:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 16:58:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 16:59:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 16:59:29): Historical data loaded (0 records).
logger (08.12.2016 16:59:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 16:59:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 16:59:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 16:59:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 16:59:59): Historical data loaded (0 records).
logger (08.12.2016 16:59:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 16:59:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 16:59:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:00:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:00:29): Historical data loaded (0 records).
logger (08.12.2016 17:00:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:00:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:00:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:00:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:00:59): Historical data loaded (0 records).
logger (08.12.2016 17:00:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:00:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:00:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:01:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:01:29): Historical data loaded (0 records).
logger (08.12.2016 17:01:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:01:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:01:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:01:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:01:59): Historical data loaded (0 records).
logger (08.12.2016 17:01:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:01:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:01:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:02:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:02:29): Historical data loaded (0 records).
logger (08.12.2016 17:02:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:02:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:02:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:02:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:02:59): Historical data loaded (0 records).
logger (08.12.2016 17:02:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:02:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:02:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:03:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:03:29): Historical data loaded (0 records).
logger (08.12.2016 17:03:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:03:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:03:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:03:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:03:59): Historical data loaded (0 records).
logger (08.12.2016 17:03:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:03:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:03:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:04:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:04:29): Historical data loaded (0 records).
logger (08.12.2016 17:04:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:04:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:04:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:04:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:04:59): Historical data loaded (0 records).
logger (08.12.2016 17:04:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:04:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:04:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:05:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:05:29): Historical data loaded (0 records).
logger (08.12.2016 17:05:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:05:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:05:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:05:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:05:59): Historical data loaded (0 records).
logger (08.12.2016 17:05:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:05:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:05:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:06:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:06:29): Historical data loaded (0 records).
logger (08.12.2016 17:06:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:06:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:06:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:06:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:06:59): Historical data loaded (0 records).
logger (08.12.2016 17:06:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:06:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:06:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:07:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:07:29): Historical data loaded (0 records).
logger (08.12.2016 17:07:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:07:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:07:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:07:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:07:59): Historical data loaded (0 records).
logger (08.12.2016 17:07:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:07:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:07:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:08:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:08:29): Historical data loaded (0 records).
logger (08.12.2016 17:08:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:08:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:08:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:08:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:08:59): Historical data loaded (0 records).
logger (08.12.2016 17:08:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:08:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:08:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:09:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:09:29): Historical data loaded (0 records).
logger (08.12.2016 17:09:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:09:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:09:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:09:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:09:59): Historical data loaded (0 records).
logger (08.12.2016 17:09:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:09:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:09:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:10:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:10:29): Historical data loaded (0 records).
logger (08.12.2016 17:10:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:10:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:10:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:10:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:10:59): Historical data loaded (0 records).
logger (08.12.2016 17:10:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:10:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:10:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:11:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:11:29): Historical data loaded (0 records).
logger (08.12.2016 17:11:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:11:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:11:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:11:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:11:59): Historical data loaded (0 records).
logger (08.12.2016 17:11:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:11:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:11:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:12:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:12:29): Historical data loaded (0 records).
logger (08.12.2016 17:12:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:12:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:12:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:12:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:12:59): Historical data loaded (0 records).
logger (08.12.2016 17:12:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:12:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:12:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:13:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:13:29): Historical data loaded (0 records).
logger (08.12.2016 17:13:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:13:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:13:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:13:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:13:59): Historical data loaded (0 records).
logger (08.12.2016 17:13:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:13:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:13:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:14:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:14:29): Historical data loaded (0 records).
logger (08.12.2016 17:14:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:14:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:14:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:14:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:14:59): Historical data loaded (0 records).
logger (08.12.2016 17:14:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:14:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:14:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:15:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:15:29): Historical data loaded (0 records).
logger (08.12.2016 17:15:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:15:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:15:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:15:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:15:59): Historical data loaded (0 records).
logger (08.12.2016 17:15:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:15:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:15:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:16:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:16:29): Historical data loaded (0 records).
logger (08.12.2016 17:16:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:16:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:16:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:16:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:16:59): Historical data loaded (0 records).
logger (08.12.2016 17:16:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:16:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:16:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:17:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:17:29): Historical data loaded (0 records).
logger (08.12.2016 17:17:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:17:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:17:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:17:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:17:59): Historical data loaded (0 records).
logger (08.12.2016 17:17:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:17:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:17:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:18:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:18:29): Historical data loaded (0 records).
logger (08.12.2016 17:18:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:18:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:18:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:18:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:18:59): Historical data loaded (0 records).
logger (08.12.2016 17:18:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:18:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:18:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:19:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:19:29): Historical data loaded (0 records).
logger (08.12.2016 17:19:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:19:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:19:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:19:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:19:59): Historical data loaded (0 records).
logger (08.12.2016 17:19:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:19:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:19:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:20:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:20:29): Historical data loaded (0 records).
logger (08.12.2016 17:20:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:20:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:20:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:20:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:20:59): Historical data loaded (0 records).
logger (08.12.2016 17:20:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:20:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:20:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:21:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:21:29): Historical data loaded (0 records).
logger (08.12.2016 17:21:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:21:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:21:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:21:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:21:59): Historical data loaded (0 records).
logger (08.12.2016 17:21:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:21:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:21:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:22:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:22:29): Historical data loaded (0 records).
logger (08.12.2016 17:22:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:22:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:22:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:22:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:22:59): Historical data loaded (0 records).
logger (08.12.2016 17:22:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:22:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:22:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:23:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:23:29): Historical data loaded (0 records).
logger (08.12.2016 17:23:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:23:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:23:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:23:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:23:59): Historical data loaded (0 records).
logger (08.12.2016 17:23:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:23:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:23:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:24:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:24:29): Historical data loaded (0 records).
logger (08.12.2016 17:24:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:24:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:24:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:24:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:24:59): Historical data loaded (0 records).
logger (08.12.2016 17:24:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:24:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:24:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:25:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:25:29): Historical data loaded (0 records).
logger (08.12.2016 17:25:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:25:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:25:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:25:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:25:59): Historical data loaded (0 records).
logger (08.12.2016 17:25:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:25:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:25:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:26:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:26:29): Historical data loaded (0 records).
logger (08.12.2016 17:26:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:26:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:26:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:26:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:26:59): Historical data loaded (0 records).
logger (08.12.2016 17:26:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:26:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:26:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:27:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:27:29): Historical data loaded (0 records).
logger (08.12.2016 17:27:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:27:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:27:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:27:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:27:59): Historical data loaded (0 records).
logger (08.12.2016 17:27:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:27:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:27:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:28:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:28:29): Historical data loaded (0 records).
logger (08.12.2016 17:28:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:28:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:28:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:28:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:28:59): Historical data loaded (0 records).
logger (08.12.2016 17:28:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:28:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:28:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:29:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:29:29): Historical data loaded (0 records).
logger (08.12.2016 17:29:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:29:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:29:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:29:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:29:59): Historical data loaded (0 records).
logger (08.12.2016 17:29:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:29:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:29:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:30:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:30:29): Historical data loaded (0 records).
logger (08.12.2016 17:30:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:30:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:30:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:30:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:30:59): Historical data loaded (0 records).
logger (08.12.2016 17:30:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:30:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:30:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:31:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:31:29): Historical data loaded (0 records).
logger (08.12.2016 17:31:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:31:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:31:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:31:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:31:59): Historical data loaded (0 records).
logger (08.12.2016 17:31:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:31:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:31:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:32:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:32:29): Historical data loaded (0 records).
logger (08.12.2016 17:32:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:32:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:32:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:32:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:32:59): Historical data loaded (0 records).
logger (08.12.2016 17:32:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:32:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:32:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:33:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:33:29): Historical data loaded (0 records).
logger (08.12.2016 17:33:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:33:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:33:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:33:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:33:59): Historical data loaded (0 records).
logger (08.12.2016 17:33:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:33:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:33:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:34:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:34:29): Historical data loaded (0 records).
logger (08.12.2016 17:34:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:34:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:34:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:34:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:34:59): Historical data loaded (0 records).
logger (08.12.2016 17:34:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:34:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:34:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:35:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:35:29): Historical data loaded (0 records).
logger (08.12.2016 17:35:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:35:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:35:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:35:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:35:59): Historical data loaded (0 records).
logger (08.12.2016 17:35:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:35:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:35:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:36:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:36:29): Historical data loaded (0 records).
logger (08.12.2016 17:36:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:36:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:36:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:36:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:36:59): Historical data loaded (0 records).
logger (08.12.2016 17:36:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:36:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:36:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:37:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:37:29): Historical data loaded (0 records).
logger (08.12.2016 17:37:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:37:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:37:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:37:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:37:59): Historical data loaded (0 records).
logger (08.12.2016 17:37:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:37:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:37:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:38:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:38:29): Historical data loaded (0 records).
logger (08.12.2016 17:38:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:38:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:38:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:38:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:38:59): Historical data loaded (0 records).
logger (08.12.2016 17:38:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:38:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:38:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:39:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:39:29): Historical data loaded (0 records).
logger (08.12.2016 17:39:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:39:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:39:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:39:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:39:59): Historical data loaded (0 records).
logger (08.12.2016 17:39:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:39:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:39:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:40:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:40:29): Historical data loaded (0 records).
logger (08.12.2016 17:40:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:40:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:40:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:40:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:40:59): Historical data loaded (0 records).
logger (08.12.2016 17:40:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:40:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:40:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:41:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:41:29): Historical data loaded (0 records).
logger (08.12.2016 17:41:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:41:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:41:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:41:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:41:59): Historical data loaded (0 records).
logger (08.12.2016 17:41:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:41:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:41:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:42:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:42:29): Historical data loaded (0 records).
logger (08.12.2016 17:42:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:42:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:42:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:42:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:42:59): Historical data loaded (0 records).
logger (08.12.2016 17:42:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:42:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:42:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:43:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:43:29): Historical data loaded (0 records).
logger (08.12.2016 17:43:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:43:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:43:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:43:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:43:59): Historical data loaded (0 records).
logger (08.12.2016 17:43:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:43:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:43:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:44:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:44:29): Historical data loaded (0 records).
logger (08.12.2016 17:44:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:44:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:44:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:44:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:44:59): Historical data loaded (0 records).
logger (08.12.2016 17:44:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:44:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:44:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:45:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:45:29): Historical data loaded (0 records).
logger (08.12.2016 17:45:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:45:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:45:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:45:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:45:59): Historical data loaded (0 records).
logger (08.12.2016 17:45:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:45:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:45:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:46:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:46:29): Historical data loaded (0 records).
logger (08.12.2016 17:46:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:46:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:46:29): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:46:59): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:46:59): Historical data loaded (0 records).
logger (08.12.2016 17:46:59): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:46:59): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:46:59): killed process "7157/usbreset" listening to port 5551.
logger (08.12.2016 17:47:29): databases connected. Update interval 3600 seconds.
logger (08.12.2016 17:47:29): Historical data loaded (0 records).
logger (08.12.2016 17:47:29): data logger (version 5.0s, build 10749) started.
logger (08.12.2016 17:47:29): error while doing bind (port 5551): Address already in use
logger (08.12.2016 17:47:29): killed process "7157/usbreset" listening to port 5551.
A reboot seems to have fixed it
Re: Another failure
Seems like the "USB reset" process could not be terminated. I will check for potential reasons.
