I noticed that the calendar date at the bottom of the heatmap-temp-tmp chart for one week (Sunday start) is off by one day. The date shown when the mouse if hovered over the data is correct. Only the axis label at the bottom is off by a day.
See:
https://admin.meteobridge.com/94165b178 ... W1&stop=W0
For example, today (14 Dec 2016) the axis under the current column shows "Dec 13". The data on the mouse hover shows 2016-12-14 along with the temperature data and time.
Greg Hamel
Heatmap axis for date incorrect in weekly chart
Re: Heatmap axis for date incorrect in weekly chart
I tried your link and it works ok. Therefore, I am a bit confused, what exactly does not work for you.
Can you please send a screenshot?
See attached. I also tried the Microsoft Edge browser and got the same result. We are on Eastern Standard Time (America/Detroit), if that has any effect.
The UTC date is ahead of here, so that shouldn't be the problem.
I see your screenshot, but I am still getting the wrong date on the bottom axis. Today is 17 Dec and the axis shows Dec 16 for today.
Greg Hamel
Greg Hamel
- heatmap.png (13.21 KiB) Viewed 4481 times
Strange... can you please send the HTML source code of a false example to "info(at)meteobridge.com"?
When I click onto the link above it always shows data fine.
Email was sent.admin wrote:Strange... can you please send the HTML source code of a false example to "info(at)meteobridge.com"?
Greg
Hint: the Hi/Lo chart (tempminmax-imp) is working properly with the date axis.
Greg
Greg
