Interrupted System Call? ** solved **
Jeffsbach
Post by Jeffsbach »
I'm still trying to get this working. I have a WMR-100 station and it doesn't seem to be interfacing correctly with meteohub. Any pointers would be greatly appreciated. I'm on meteohub version 2.3, but I'm not sure where to look for the letter code (d vs. e).
I receive the following repeated message in the meteohub log:
02.06.2008 09:17:08): error while waiting for data from device /home/meteohub/hid: Interrupted system call
The system process info is as follows:
Weather Data Recomputation: completed
Weather Data Logging: running (last data: never)
SSH Login: running
SMB Shares: running
Time Synchonization: running
Re:Interrupted System Call?
When you have a 2.3e installed (for example) it says \"2.3e\" on the \"system information\" page. If it just says \"2.3\" it is plain 2.3.
There have been improvements on the usb interfacing since 2.3. I would recommend to go to 2.4.
