Database Errors following weird WU Updates.
ucs308
Post by ucs308 »
I have had to turn off Underground updates. The first few minutes of updates went well, then outdoor temp was reported as 100F. A difference of 72'ish degrees. This started happening after I set the compensation factor for the indoor temperature. Since that the MeteoBridge unit has been unstable.
This is a new MeteoBridge Pro.
The error I am getting is : Database Error: Cannot prepare read tables RAM (0 tries, 2ms): database disk image is malformed
Box Info:
Platform: Meteobridge PRO
RAM: 61500 kB total, 14340 kB free (76% used)
Storage ATP: Internal 864 MB total, 857 MB free (1% used)
SW Version: Meteobridge 3.1 (Dec 19 2016, build 10773), FW 1.4
Uptime: 13 hours, 17 minutes Buffer: 0 items (0%)
Power Data: 5.47V 348mA 1.91W (Box Climate: 37.5°C 11%)
A small sample of my database errors.
database (21.12.2016 11:22:22): rollback on insert forced (min RAM): thb0temp
database (21.12.2016 11:22:32): cannot prepare insert into thb0temp_min RAM (after 100 tries in 9124ms): database disk image is malformed (11)
database (21.12.2016 11:22:32): rollback on insert forced (min RAM): thb0temp
database (21.12.2016 11:22:41): cannot prepare insert into thb0temp_min RAM (after 100 tries in 9124ms): database disk image is malformed (11)
database (21.12.2016 11:22:41): rollback on insert forced (min RAM): thb0temp
database (21.12.2016 11:22:50): cannot prepare insert into thb0temp_min RAM (after 100 tries in 9124ms): database disk image is malformed (11)
database (21.12.2016 11:22:50): rollback on insert forced (min RAM): t
ucs308
Re: Database Errors following weird WU Updates.
Post by ucs308 »
Here is the current data going to wunderground:
The ISS is reporting 38F
MeteoBridge Pro is reporting:
Current Conditions Station reported 4 seconds ago
105.8
Feels Like 162.9
2.0 Wind from NW
Humidity: --
Precip Rate: --
Precip Accum: --
Pressure: 30.37 in
UV:2
Solar: --
Soil Moisture: --
Soil Temp: --
Leaf Wetness: --
Please select "force database rebuild on reboot" option on "system" tab and reboot.
