another problem... **solved**
frogfoot
Post by frogfoot »
Yet another problem. I assume this is failed USB storage again.
logger (21.12.2016 19:40:05): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:40:05): Historical data loaded (0 records).
logger (21.12.2016 19:40:05): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:40:05): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:40:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:40:35): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:40:35): Historical data loaded (0 records).
logger (21.12.2016 19:40:35): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:40:35): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:40:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:41:05): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:41:05): Historical data loaded (0 records).
logger (21.12.2016 19:41:05): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:41:05): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:41:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:41:35): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:41:35): Historical data loaded (0 records).
logger (21.12.2016 19:41:35): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:41:35): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:41:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:42:05): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:42:05): Historical data loaded (0 records).
logger (21.12.2016 19:42:05): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:42:05): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:42:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:42:35): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:42:35): Historical data loaded (0 records).
logger (21.12.2016 19:42:35): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:42:35): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:42:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:43:05): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:43:05): Historical data loaded (0 records).
logger (21.12.2016 19:43:05): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:43:05): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:43:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:43:35): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:43:35): Historical data loaded (0 records).
logger (21.12.2016 19:43:35): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:43:35): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:43:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:44:05): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:44:05): Historical data loaded (0 records).
logger (21.12.2016 19:44:05): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:44:05): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:44:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:44:35): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:44:35): Historical data loaded (0 records).
logger (21.12.2016 19:44:35): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:44:35): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:44:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:45:05): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:45:05): Historical data loaded (0 records).
logger (21.12.2016 19:45:05): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:45:05): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:45:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:45:35): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:45:35): Historical data loaded (0 records).
logger (21.12.2016 19:45:35): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:45:35): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:45:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:46:05): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:46:05): Historical data loaded (0 records).
logger (21.12.2016 19:46:05): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:46:05): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:46:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:46:35): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:46:35): Historical data loaded (0 records).
logger (21.12.2016 19:46:35): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:46:35): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:46:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:47:05): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:47:05): Historical data loaded (0 records).
logger (21.12.2016 19:47:05): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:47:05): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:47:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:47:35): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:47:35): Historical data loaded (0 records).
logger (21.12.2016 19:47:35): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:47:35): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:47:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:48:05): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:48:05): Historical data loaded (0 records).
logger (21.12.2016 19:48:05): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:48:05): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:48:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:48:35): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:48:35): Historical data loaded (0 records).
logger (21.12.2016 19:48:35): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:48:35): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:48:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:49:05): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:49:05): Historical data loaded (0 records).
logger (21.12.2016 19:49:05): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:49:05): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:49:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:49:35): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:49:35): Historical data loaded (0 records).
logger (21.12.2016 19:49:35): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:49:35): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:49:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:50:05): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:50:05): Historical data loaded (0 records).
logger (21.12.2016 19:50:05): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:50:05): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:50:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:50:35): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:50:35): Historical data loaded (0 records).
logger (21.12.2016 19:50:35): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:50:35): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:50:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:51:05): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:51:05): Historical data loaded (0 records).
logger (21.12.2016 19:51:05): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:51:05): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:51:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:51:35): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:51:35): Historical data loaded (0 records).
logger (21.12.2016 19:51:35): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:51:35): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:51:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:52:05): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:52:05): Historical data loaded (0 records).
logger (21.12.2016 19:52:05): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:52:05): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:52:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:52:35): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:52:35): Historical data loaded (0 records).
logger (21.12.2016 19:52:35): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:52:35): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:52:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:53:05): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:53:05): Historical data loaded (0 records).
logger (21.12.2016 19:53:05): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:53:05): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:53:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:53:35): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:53:35): Historical data loaded (0 records).
logger (21.12.2016 19:53:35): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:53:35): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:53:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:54:05): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:54:05): Historical data loaded (0 records).
logger (21.12.2016 19:54:05): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:54:05): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:54:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:54:35): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:54:35): Historical data loaded (0 records).
logger (21.12.2016 19:54:35): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:54:35): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:54:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:55:05): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:55:05): Historical data loaded (0 records).
logger (21.12.2016 19:55:05): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:55:05): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:55:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:55:35): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:55:35): Historical data loaded (0 records).
logger (21.12.2016 19:55:35): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:55:35): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:55:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:56:05): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:56:05): Historical data loaded (0 records).
logger (21.12.2016 19:56:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:56:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:56:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:56:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:56:36): Historical data loaded (0 records).
logger (21.12.2016 19:56:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:56:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:56:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:57:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:57:06): Historical data loaded (0 records).
logger (21.12.2016 19:57:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:57:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:57:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:57:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:57:36): Historical data loaded (0 records).
logger (21.12.2016 19:57:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:57:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:57:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:58:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:58:06): Historical data loaded (0 records).
logger (21.12.2016 19:58:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:58:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:58:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:58:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:58:36): Historical data loaded (0 records).
logger (21.12.2016 19:58:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:58:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:58:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:59:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:59:06): Historical data loaded (0 records).
logger (21.12.2016 19:59:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:59:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:59:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 19:59:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 19:59:36): Historical data loaded (0 records).
logger (21.12.2016 19:59:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 19:59:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 19:59:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:00:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:00:06): Historical data loaded (0 records).
logger (21.12.2016 20:00:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:00:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:00:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:00:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:00:36): Historical data loaded (0 records).
logger (21.12.2016 20:00:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:00:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:00:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:01:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:01:06): Historical data loaded (0 records).
logger (21.12.2016 20:01:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:01:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:01:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:01:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:01:36): Historical data loaded (0 records).
logger (21.12.2016 20:01:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:01:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:01:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:02:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:02:06): Historical data loaded (0 records).
logger (21.12.2016 20:02:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:02:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:02:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:02:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:02:36): Historical data loaded (0 records).
logger (21.12.2016 20:02:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:02:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:02:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:03:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:03:06): Historical data loaded (0 records).
logger (21.12.2016 20:03:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:03:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:03:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:03:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:03:36): Historical data loaded (0 records).
logger (21.12.2016 20:03:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:03:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:03:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:04:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:04:06): Historical data loaded (0 records).
logger (21.12.2016 20:04:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:04:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:04:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:04:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:04:36): Historical data loaded (0 records).
logger (21.12.2016 20:04:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:04:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:04:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:05:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:05:06): Historical data loaded (0 records).
logger (21.12.2016 20:05:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:05:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:05:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:05:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:05:36): Historical data loaded (0 records).
logger (21.12.2016 20:05:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:05:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:05:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:06:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:06:06): Historical data loaded (0 records).
logger (21.12.2016 20:06:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:06:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:06:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:06:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:06:36): Historical data loaded (0 records).
logger (21.12.2016 20:06:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:06:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:06:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:07:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:07:06): Historical data loaded (0 records).
logger (21.12.2016 20:07:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:07:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:07:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:07:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:07:36): Historical data loaded (0 records).
logger (21.12.2016 20:07:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:07:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:07:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:08:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:08:06): Historical data loaded (0 records).
logger (21.12.2016 20:08:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:08:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:08:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:08:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:08:36): Historical data loaded (0 records).
logger (21.12.2016 20:08:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:08:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:08:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:09:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:09:06): Historical data loaded (0 records).
logger (21.12.2016 20:09:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:09:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:09:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:09:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:09:36): Historical data loaded (0 records).
logger (21.12.2016 20:09:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:09:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:09:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:10:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:10:06): Historical data loaded (0 records).
logger (21.12.2016 20:10:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:10:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:10:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:10:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:10:36): Historical data loaded (0 records).
logger (21.12.2016 20:10:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:10:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:10:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:11:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:11:06): Historical data loaded (0 records).
logger (21.12.2016 20:11:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:11:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:11:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:11:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:11:36): Historical data loaded (0 records).
logger (21.12.2016 20:11:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:11:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:11:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:12:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:12:06): Historical data loaded (0 records).
logger (21.12.2016 20:12:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:12:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:12:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:12:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:12:36): Historical data loaded (0 records).
logger (21.12.2016 20:12:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:12:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:12:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:13:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:13:06): Historical data loaded (0 records).
logger (21.12.2016 20:13:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:13:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:13:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:13:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:13:36): Historical data loaded (0 records).
logger (21.12.2016 20:13:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:13:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:13:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:14:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:14:06): Historical data loaded (0 records).
logger (21.12.2016 20:14:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:14:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:14:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:14:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:14:36): Historical data loaded (0 records).
logger (21.12.2016 20:14:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:14:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:14:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:15:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:15:06): Historical data loaded (0 records).
logger (21.12.2016 20:15:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:15:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:15:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:15:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:15:36): Historical data loaded (0 records).
logger (21.12.2016 20:15:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:15:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:15:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:16:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:16:06): Historical data loaded (0 records).
logger (21.12.2016 20:16:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:16:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:16:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:16:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:16:36): Historical data loaded (0 records).
logger (21.12.2016 20:16:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:16:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:16:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:17:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:17:06): Historical data loaded (0 records).
logger (21.12.2016 20:17:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:17:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:17:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:17:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:17:36): Historical data loaded (0 records).
logger (21.12.2016 20:17:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:17:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:17:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:18:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:18:06): Historical data loaded (0 records).
logger (21.12.2016 20:18:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:18:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:18:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:18:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:18:36): Historical data loaded (0 records).
logger (21.12.2016 20:18:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:18:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:18:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:19:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:19:06): Historical data loaded (0 records).
logger (21.12.2016 20:19:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:19:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:19:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:19:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:19:36): Historical data loaded (0 records).
logger (21.12.2016 20:19:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:19:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:19:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:20:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:20:06): Historical data loaded (0 records).
logger (21.12.2016 20:20:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:20:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:20:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:20:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:20:36): Historical data loaded (0 records).
logger (21.12.2016 20:20:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:20:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:20:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:21:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:21:06): Historical data loaded (0 records).
logger (21.12.2016 20:21:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:21:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:21:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:21:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:21:36): Historical data loaded (0 records).
logger (21.12.2016 20:21:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:21:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:21:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:22:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:22:06): Historical data loaded (0 records).
logger (21.12.2016 20:22:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:22:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:22:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:22:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:22:36): Historical data loaded (0 records).
logger (21.12.2016 20:22:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:22:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:22:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:23:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:23:06): Historical data loaded (0 records).
logger (21.12.2016 20:23:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:23:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:23:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:23:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:23:36): Historical data loaded (0 records).
logger (21.12.2016 20:23:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:23:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:23:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:24:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:24:06): Historical data loaded (0 records).
logger (21.12.2016 20:24:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:24:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:24:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:24:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:24:36): Historical data loaded (0 records).
logger (21.12.2016 20:24:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:24:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:24:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:25:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:25:06): Historical data loaded (0 records).
logger (21.12.2016 20:25:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:25:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:25:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:25:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:25:36): Historical data loaded (0 records).
logger (21.12.2016 20:25:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:25:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:25:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:26:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:26:06): Historical data loaded (0 records).
logger (21.12.2016 20:26:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:26:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:26:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:26:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:26:36): Historical data loaded (0 records).
logger (21.12.2016 20:26:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:26:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:26:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:27:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:27:06): Historical data loaded (0 records).
logger (21.12.2016 20:27:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:27:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:27:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:27:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:27:36): Historical data loaded (0 records).
logger (21.12.2016 20:27:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:27:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:27:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:28:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:28:06): Historical data loaded (0 records).
logger (21.12.2016 20:28:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:28:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:28:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:28:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:28:36): Historical data loaded (0 records).
logger (21.12.2016 20:28:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:28:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:28:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:29:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:29:06): Historical data loaded (0 records).
logger (21.12.2016 20:29:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:29:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:29:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:29:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:29:36): Historical data loaded (0 records).
logger (21.12.2016 20:29:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:29:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:29:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:30:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:30:06): Historical data loaded (0 records).
logger (21.12.2016 20:30:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:30:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:30:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:30:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:30:36): Historical data loaded (0 records).
logger (21.12.2016 20:30:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:30:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:30:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:31:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:31:06): Historical data loaded (0 records).
logger (21.12.2016 20:31:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:31:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:31:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:31:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:31:36): Historical data loaded (0 records).
logger (21.12.2016 20:31:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:31:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:31:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:32:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:32:06): Historical data loaded (0 records).
logger (21.12.2016 20:32:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:32:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:32:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:32:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:32:36): Historical data loaded (0 records).
logger (21.12.2016 20:32:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:32:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:32:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:33:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:33:06): Historical data loaded (0 records).
logger (21.12.2016 20:33:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:33:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:33:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:33:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:33:36): Historical data loaded (0 records).
logger (21.12.2016 20:33:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:33:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:33:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:34:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:34:06): Historical data loaded (0 records).
logger (21.12.2016 20:34:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:34:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:34:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:34:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:34:36): Historical data loaded (0 records).
logger (21.12.2016 20:34:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:34:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:34:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:35:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:35:06): Historical data loaded (0 records).
logger (21.12.2016 20:35:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:35:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:35:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:35:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:35:36): Historical data loaded (0 records).
logger (21.12.2016 20:35:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:35:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:35:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:36:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:36:06): Historical data loaded (0 records).
logger (21.12.2016 20:36:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:36:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:36:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:36:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:36:36): Historical data loaded (0 records).
logger (21.12.2016 20:36:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:36:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:36:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:37:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:37:06): Historical data loaded (0 records).
logger (21.12.2016 20:37:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:37:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:37:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:37:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:37:36): Historical data loaded (0 records).
logger (21.12.2016 20:37:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:37:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:37:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:38:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:38:06): Historical data loaded (0 records).
logger (21.12.2016 20:38:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:38:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:38:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:38:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:38:36): Historical data loaded (0 records).
logger (21.12.2016 20:38:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:38:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:38:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:39:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:39:06): Historical data loaded (0 records).
logger (21.12.2016 20:39:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:39:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:39:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:39:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:39:36): Historical data loaded (0 records).
logger (21.12.2016 20:39:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:39:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:39:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:40:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:40:06): Historical data loaded (0 records).
logger (21.12.2016 20:40:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:40:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:40:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:40:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:40:36): Historical data loaded (0 records).
logger (21.12.2016 20:40:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:40:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:40:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:41:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:41:06): Historical data loaded (0 records).
logger (21.12.2016 20:41:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:41:06): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:41:06): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:41:36): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:41:36): Historical data loaded (0 records).
logger (21.12.2016 20:41:36): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:41:36): error while doing bind (port 5551): Address already in use
logger (21.12.2016 20:41:36): killed process "27193/usbreset" listening to port 5551.
logger (21.12.2016 20:42:06): databases connected. Update interval 3600 seconds.
logger (21.12.2016 20:42:06): Historical data loaded (0 records).
logger (21.12.2016 20:42:06): data logger (version 5.0t, build 10762) started.
logger (21.12.2016 20:42:06): error while doing bi
internal database completely unusable, and even fails to upload anything to my SQL database or the WU.
A reboot has restored service for the moment.
frogfoot
Re: another problem...
Post by frogfoot »
and again...
logger (23.12.2016 16:40:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:40:03): Historical data loaded (0 records).
logger (23.12.2016 16:40:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:40:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:40:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:40:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:40:33): Historical data loaded (0 records).
logger (23.12.2016 16:40:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:40:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:40:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:41:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:41:03): Historical data loaded (0 records).
logger (23.12.2016 16:41:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:41:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:41:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:41:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:41:33): Historical data loaded (0 records).
logger (23.12.2016 16:41:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:41:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:41:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:42:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:42:03): Historical data loaded (0 records).
logger (23.12.2016 16:42:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:42:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:42:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:42:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:42:33): Historical data loaded (0 records).
logger (23.12.2016 16:42:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:42:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:42:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:43:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:43:03): Historical data loaded (0 records).
logger (23.12.2016 16:43:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:43:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:43:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:43:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:43:33): Historical data loaded (0 records).
logger (23.12.2016 16:43:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:43:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:43:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:44:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:44:03): Historical data loaded (0 records).
logger (23.12.2016 16:44:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:44:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:44:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:44:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:44:33): Historical data loaded (0 records).
logger (23.12.2016 16:44:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:44:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:44:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:45:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:45:03): Historical data loaded (0 records).
logger (23.12.2016 16:45:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:45:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:45:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:45:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:45:33): Historical data loaded (0 records).
logger (23.12.2016 16:45:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:45:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:45:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:46:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:46:03): Historical data loaded (0 records).
logger (23.12.2016 16:46:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:46:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:46:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:46:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:46:33): Historical data loaded (0 records).
logger (23.12.2016 16:46:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:46:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:46:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:47:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:47:03): Historical data loaded (0 records).
logger (23.12.2016 16:47:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:47:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:47:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:47:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:47:33): Historical data loaded (0 records).
logger (23.12.2016 16:47:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:47:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:47:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:48:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:48:03): Historical data loaded (0 records).
logger (23.12.2016 16:48:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:48:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:48:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:48:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:48:33): Historical data loaded (0 records).
logger (23.12.2016 16:48:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:48:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:48:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:49:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:49:03): Historical data loaded (0 records).
logger (23.12.2016 16:49:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:49:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:49:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:49:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:49:33): Historical data loaded (0 records).
logger (23.12.2016 16:49:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:49:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:49:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:50:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:50:03): Historical data loaded (0 records).
logger (23.12.2016 16:50:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:50:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:50:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:50:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:50:33): Historical data loaded (0 records).
logger (23.12.2016 16:50:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:50:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:50:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:51:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:51:03): Historical data loaded (0 records).
logger (23.12.2016 16:51:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:51:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:51:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:51:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:51:33): Historical data loaded (0 records).
logger (23.12.2016 16:51:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:51:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:51:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:52:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:52:03): Historical data loaded (0 records).
logger (23.12.2016 16:52:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:52:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:52:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:52:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:52:33): Historical data loaded (0 records).
logger (23.12.2016 16:52:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:52:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:52:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:53:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:53:03): Historical data loaded (0 records).
logger (23.12.2016 16:53:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:53:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:53:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:53:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:53:33): Historical data loaded (0 records).
logger (23.12.2016 16:53:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:53:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:53:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:54:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:54:03): Historical data loaded (0 records).
logger (23.12.2016 16:54:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:54:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:54:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:54:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:54:33): Historical data loaded (0 records).
logger (23.12.2016 16:54:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:54:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:54:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:55:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:55:03): Historical data loaded (0 records).
logger (23.12.2016 16:55:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:55:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:55:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:55:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:55:33): Historical data loaded (0 records).
logger (23.12.2016 16:55:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:55:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:55:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:56:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:56:03): Historical data loaded (0 records).
logger (23.12.2016 16:56:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:56:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:56:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:56:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:56:33): Historical data loaded (0 records).
logger (23.12.2016 16:56:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:56:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:56:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:57:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:57:03): Historical data loaded (0 records).
logger (23.12.2016 16:57:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:57:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:57:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:57:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:57:33): Historical data loaded (0 records).
logger (23.12.2016 16:57:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:57:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:57:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:58:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:58:03): Historical data loaded (0 records).
logger (23.12.2016 16:58:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:58:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:58:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:58:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:58:33): Historical data loaded (0 records).
logger (23.12.2016 16:58:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:58:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:58:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:59:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:59:03): Historical data loaded (0 records).
logger (23.12.2016 16:59:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:59:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:59:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 16:59:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 16:59:33): Historical data loaded (0 records).
logger (23.12.2016 16:59:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 16:59:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 16:59:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:00:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:00:03): Historical data loaded (0 records).
logger (23.12.2016 17:00:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:00:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:00:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:00:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:00:33): Historical data loaded (0 records).
logger (23.12.2016 17:00:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:00:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:00:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:01:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:01:03): Historical data loaded (0 records).
logger (23.12.2016 17:01:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:01:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:01:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:01:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:01:33): Historical data loaded (0 records).
logger (23.12.2016 17:01:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:01:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:01:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:02:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:02:03): Historical data loaded (0 records).
logger (23.12.2016 17:02:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:02:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:02:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:02:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:02:33): Historical data loaded (0 records).
logger (23.12.2016 17:02:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:02:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:02:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:03:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:03:03): Historical data loaded (0 records).
logger (23.12.2016 17:03:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:03:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:03:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:03:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:03:33): Historical data loaded (0 records).
logger (23.12.2016 17:03:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:03:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:03:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:04:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:04:03): Historical data loaded (0 records).
logger (23.12.2016 17:04:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:04:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:04:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:04:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:04:33): Historical data loaded (0 records).
logger (23.12.2016 17:04:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:04:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:04:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:05:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:05:03): Historical data loaded (0 records).
logger (23.12.2016 17:05:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:05:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:05:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:05:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:05:33): Historical data loaded (0 records).
logger (23.12.2016 17:05:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:05:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:05:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:06:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:06:03): Historical data loaded (0 records).
logger (23.12.2016 17:06:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:06:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:06:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:06:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:06:33): Historical data loaded (0 records).
logger (23.12.2016 17:06:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:06:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:06:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:07:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:07:03): Historical data loaded (0 records).
logger (23.12.2016 17:07:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:07:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:07:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:07:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:07:33): Historical data loaded (0 records).
logger (23.12.2016 17:07:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:07:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:07:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:08:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:08:03): Historical data loaded (0 records).
logger (23.12.2016 17:08:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:08:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:08:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:08:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:08:33): Historical data loaded (0 records).
logger (23.12.2016 17:08:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:08:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:08:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:09:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:09:03): Historical data loaded (0 records).
logger (23.12.2016 17:09:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:09:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:09:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:09:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:09:33): Historical data loaded (0 records).
logger (23.12.2016 17:09:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:09:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:09:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:10:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:10:03): Historical data loaded (0 records).
logger (23.12.2016 17:10:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:10:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:10:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:10:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:10:33): Historical data loaded (0 records).
logger (23.12.2016 17:10:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:10:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:10:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:11:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:11:03): Historical data loaded (0 records).
logger (23.12.2016 17:11:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:11:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:11:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:11:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:11:33): Historical data loaded (0 records).
logger (23.12.2016 17:11:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:11:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:11:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:12:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:12:03): Historical data loaded (0 records).
logger (23.12.2016 17:12:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:12:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:12:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:12:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:12:33): Historical data loaded (0 records).
logger (23.12.2016 17:12:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:12:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:12:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:13:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:13:03): Historical data loaded (0 records).
logger (23.12.2016 17:13:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:13:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:13:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:13:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:13:33): Historical data loaded (0 records).
logger (23.12.2016 17:13:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:13:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:13:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:14:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:14:03): Historical data loaded (0 records).
logger (23.12.2016 17:14:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:14:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:14:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:14:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:14:33): Historical data loaded (0 records).
logger (23.12.2016 17:14:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:14:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:14:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:15:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:15:03): Historical data loaded (0 records).
logger (23.12.2016 17:15:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:15:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:15:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:15:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:15:33): Historical data loaded (0 records).
logger (23.12.2016 17:15:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:15:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:15:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:16:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:16:03): Historical data loaded (0 records).
logger (23.12.2016 17:16:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:16:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:16:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:16:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:16:33): Historical data loaded (0 records).
logger (23.12.2016 17:16:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:16:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:16:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:17:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:17:03): Historical data loaded (0 records).
logger (23.12.2016 17:17:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:17:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:17:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:17:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:17:33): Historical data loaded (0 records).
logger (23.12.2016 17:17:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:17:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:17:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:18:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:18:03): Historical data loaded (0 records).
logger (23.12.2016 17:18:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:18:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:18:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:18:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:18:33): Historical data loaded (0 records).
logger (23.12.2016 17:18:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:18:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:18:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:19:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:19:03): Historical data loaded (0 records).
logger (23.12.2016 17:19:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:19:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:19:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:19:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:19:33): Historical data loaded (0 records).
logger (23.12.2016 17:19:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:19:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:19:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:20:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:20:03): Historical data loaded (0 records).
logger (23.12.2016 17:20:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:20:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:20:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:20:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:20:33): Historical data loaded (0 records).
logger (23.12.2016 17:20:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:20:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:20:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:21:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:21:03): Historical data loaded (0 records).
logger (23.12.2016 17:21:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:21:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:21:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:21:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:21:33): Historical data loaded (0 records).
logger (23.12.2016 17:21:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:21:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:21:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:22:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:22:03): Historical data loaded (0 records).
logger (23.12.2016 17:22:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:22:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:22:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:22:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:22:33): Historical data loaded (0 records).
logger (23.12.2016 17:22:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:22:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:22:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:23:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:23:03): Historical data loaded (0 records).
logger (23.12.2016 17:23:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:23:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:23:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:23:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:23:33): Historical data loaded (0 records).
logger (23.12.2016 17:23:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:23:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:23:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:24:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:24:03): Historical data loaded (0 records).
logger (23.12.2016 17:24:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:24:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:24:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:24:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:24:33): Historical data loaded (0 records).
logger (23.12.2016 17:24:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:24:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:24:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:25:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:25:03): Historical data loaded (0 records).
logger (23.12.2016 17:25:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:25:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:25:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:25:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:25:33): Historical data loaded (0 records).
logger (23.12.2016 17:25:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:25:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:25:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:26:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:26:03): Historical data loaded (0 records).
logger (23.12.2016 17:26:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:26:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:26:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:26:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:26:33): Historical data loaded (0 records).
logger (23.12.2016 17:26:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:26:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:26:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:27:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:27:03): Historical data loaded (0 records).
logger (23.12.2016 17:27:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:27:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:27:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:27:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:27:33): Historical data loaded (0 records).
logger (23.12.2016 17:27:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:27:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:27:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:28:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:28:03): Historical data loaded (0 records).
logger (23.12.2016 17:28:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:28:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:28:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:28:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:28:33): Historical data loaded (0 records).
logger (23.12.2016 17:28:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:28:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:28:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:29:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:29:03): Historical data loaded (0 records).
logger (23.12.2016 17:29:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:29:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:29:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:29:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:29:33): Historical data loaded (0 records).
logger (23.12.2016 17:29:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:29:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:29:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:30:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:30:03): Historical data loaded (0 records).
logger (23.12.2016 17:30:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:30:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:30:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:30:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:30:33): Historical data loaded (0 records).
logger (23.12.2016 17:30:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:30:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:30:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:31:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:31:03): Historical data loaded (0 records).
logger (23.12.2016 17:31:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:31:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:31:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:31:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:31:33): Historical data loaded (0 records).
logger (23.12.2016 17:31:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:31:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:31:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:32:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:32:03): Historical data loaded (0 records).
logger (23.12.2016 17:32:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:32:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:32:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:32:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:32:33): Historical data loaded (0 records).
logger (23.12.2016 17:32:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:32:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:32:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:33:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:33:03): Historical data loaded (0 records).
logger (23.12.2016 17:33:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:33:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:33:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:33:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:33:33): Historical data loaded (0 records).
logger (23.12.2016 17:33:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:33:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:33:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:34:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:34:03): Historical data loaded (0 records).
logger (23.12.2016 17:34:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:34:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:34:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:34:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:34:33): Historical data loaded (0 records).
logger (23.12.2016 17:34:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:34:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:34:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:35:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:35:03): Historical data loaded (0 records).
logger (23.12.2016 17:35:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:35:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:35:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:35:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:35:33): Historical data loaded (0 records).
logger (23.12.2016 17:35:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:35:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:35:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:36:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:36:03): Historical data loaded (0 records).
logger (23.12.2016 17:36:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:36:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:36:03): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:36:33): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:36:33): Historical data loaded (0 records).
logger (23.12.2016 17:36:33): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:36:33): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:36:33): killed process "30659/usbreset" listening to port 5551.
logger (23.12.2016 17:37:03): databases connected. Update interval 3600 seconds.
logger (23.12.2016 17:37:03): Historical data loaded (0 records).
logger (23.12.2016 17:37:03): data logger (version 5.0t, build 10773) started.
logger (23.12.2016 17:37:03): error while doing bind (port 5551): Address already in use
logger (23.12.2016 17:37:03): killed process "30659/usbreset" listening to port 5551.
frogfoot
Post by frogfoot »
and again, dmesg attached
command: dmesg
[    0.000000] Linux version 3.10.49 (boris@mars) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r44550) ) #685 Thu Dec 17 00:17:35 CET 2015
[    0.000000] MyLoader: sysp=22a03bb2, boardp=aaaaaa22, parts=ab2abab2
[    0.000000] bootconsole [early0] enabled
[    0.000000] CPU revision is: 00019374 (MIPS 24Kc)
[    0.000000] SoC: Atheros AR9330 rev 1
[    0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:40.000MHz
[    0.000000] Determined physical RAM map:
[    0.000000]  memory: 04000000 @ 00000000 (usable)
[    0.000000] Initrd not found or empty - disabling initrd
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x00000000-0x03ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x00000000-0x03ffffff]
[    0.000000] On node 0 totalpages: 16384
[    0.000000] free_area_init_node: node 0, pgdat 803109b0, node_mem_map 81000000
[    0.000000]   Normal zone: 128 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 16384 pages, LIFO batch:3
[    0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[    0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
[    0.000000] Kernel command line:  board=CARAMBOLA2 console=ttyATH0,115200 mtdparts=spi0.0:256k(u-boot)ro,64k(u-boot-env)ro,16000k(firmware),64k(art)ro rootfstype=squashfs,jffs2 noinitrd
[    0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Writing ErrCtl register=00000000
[    0.000000] Readback ErrCtl register=00000000
[    0.000000] Memory: 61272k/65536k available (2239k kernel code, 4264k reserved, 603k data, 228k init, 0k highmem)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS:51
[    0.080000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
[    0.080000] pid_max: default: 32768 minimum: 301
[    0.080000] Mount-cache hash table entries: 512
[    0.090000] NET: Registered protocol family 16
[    0.100000] MIPS: machine is 8devices Carambola2 board
[    0.550000] bio: create slab <bio-0> at 0
[    0.560000] Switching to clocksource MIPS
[    0.570000] NET: Registered protocol family 2
[    0.570000] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[    0.570000] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[    0.580000] TCP: Hash tables configured (established 512 bind 512)
[    0.580000] TCP: reno registered
[    0.580000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.590000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.600000] NET: Registered protocol family 1
[    0.600000] PCI: CLS 0 bytes, default 32
[    0.620000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.630000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.640000] msgmni has been set to 119
[    0.640000] io scheduler noop registered
[    0.640000] io scheduler deadline registered (default)
[    0.650000] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[    0.660000] ar933x-uart: ttyATH0 at MMIO 0x18020000 (irq = 11) is a AR933X UART
[    0.660000] console [ttyATH0] enabled, bootconsole disabled
[    0.680000] ath79-spi ath79-spi: master is unqueued, this is deprecated
[    0.680000] m25p80 spi0.0: found w25q128, expected m25p80
[    0.690000] m25p80 spi0.0: w25q128 (16384 Kbytes)
[    0.690000] 4 cmdlinepart partitions found on MTD device spi0.0
[    0.700000] Creating 4 MTD partitions on "spi0.0":
[    0.700000] 0x000000000000-0x000000040000 : "u-boot"
[    0.710000] 0x000000040000-0x000000050000 : "u-boot-env"
[    0.720000] 0x000000050000-0x000000ff0000 : "firmware"
[    0.740000] 2 uimage-fw partitions found on MTD device firmware
[    0.740000] 0x000000050000-0x000000160000 : "kernel"
[    0.750000] 0x000000160000-0x000000ff0000 : "rootfs"
[    0.750000] mtd: device 4 (rootfs) set to be root filesystem
[    0.760000] 1 squashfs-split partitions found on MTD device rootfs
[    0.760000] 0x0000006d0000-0x000000ff0000 : "rootfs_data"
[    0.770000] 0x000000ff0000-0x000001000000 : "art"
[    0.790000] libphy: ag71xx_mdio: probed
[    1.340000] ag71xx-mdio.1: Found an AR7240/AR9330 built-in switch
[    2.380000] eth0: Atheros AG71xx at 0xba000000, irq 5, mode:GMII
[    2.930000] ag71xx ag71xx.0: connected to PHY at ag71xx-mdio.1:04 [uid=004dd041, driver=Generic PHY]
[    2.940000] eth1: Atheros AG71xx at 0xb9000000, irq 4, mode:MII
[    2.950000] TCP: cubic registered
[    2.950000] NET: Registered protocol family 17
[    2.960000] 8021q: 802.1Q VLAN Support v1.8
[    2.970000] VFS: Mounted root (squashfs filesystem) readonly on device 31:4.
[    2.970000] Freeing unused kernel memory: 228K (80327000 - 80360000)
[    6.790000] usbcore: registered new interface driver usbfs
[    6.800000] usbcore: registered new interface driver hub
[    6.800000] usbcore: registered new device driver usb
[    6.860000] SCSI subsystem initialized
[    6.870000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    6.880000] ehci-platform: EHCI generic platform driver
[    6.880000] ehci-platform ehci-platform: EHCI Host Controller
[    6.880000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
[    6.890000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
[    6.920000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
[    6.920000] hub 1-0:1.0: USB hub found
[    6.920000] hub 1-0:1.0: 1 port detected
[    6.930000] usbcore: registered new interface driver usb-storage
[    7.360000] usb 1-1: new high-speed USB device number 2 using ehci-platform
[    7.540000] hub 1-1:1.0: USB hub found
[    7.550000] hub 1-1:1.0: 4 ports detected
[    7.830000] usb 1-1.1: new high-speed USB device number 3 using ehci-platform
[    7.940000] usb-storage 1-1.1:1.0: USB Mass Storage device detected
[    7.950000] scsi0 : usb-storage 1-1.1:1.0
[    8.040000] usb 1-1.3: new full-speed USB device number 4 using ehci-platform
[    8.240000] usb 1-1.4: new high-speed USB device number 5 using ehci-platform
[    8.350000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[    8.360000] scsi1 : usb-storage 1-1.4:1.0
[    8.950000] scsi 0:0:0:0: Direct-Access     TOSHIBA  USB FLASH DRIVE  PMAP PQ: 0 ANSI: 6
[    8.960000] sd 0:0:0:0: [sda] 30240768 512-byte logical blocks: (15.4 GB/14.4 GiB)
[    8.960000] sd 0:0:0:0: [sda] Write Protect is off
[    8.970000] sd 0:0:0:0: [sda] Mode Sense: 45 00 00 00
[    8.970000] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    8.980000]  sda: unknown partition table
[    8.990000] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    9.650000] scsi 1:0:0:0: Direct-Access     Intenso  Premium Line     1100 PQ: 0 ANSI: 6
[    9.670000] sd 1:0:0:0: [sdb] 15720448 512-byte logical blocks: (8.04 GB/7.49 GiB)
[    9.670000] sd 1:0:0:0: [sdb] Write Protect is off
[    9.680000] sd 1:0:0:0: [sdb] Mode Sense: 43 00 00 00
[    9.680000] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    9.690000]  sdb: unknown partition table
[    9.700000] sd 1:0:0:0: [sdb] Attached SCSI removable disk
[   12.490000] jffs2: notice: (353) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (1 unchecked, 0 orphan) and 54 of xref (0 dead, 39 orphan) found.
[   12.500000] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
[   12.510000] block: unable to load configuration (fstab: Entry not found)
[   12.520000] block: attempting to load /tmp/jffs_cfg/etc/config/fstab
[   12.530000] block: extroot: not configured
[   12.620000] jffs2: notice: (350) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (1 unchecked, 0 orphan) and 54 of xref (0 dead, 39 orphan) found.
[   12.960000] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
[   12.960000] block: unable to load configuration (fstab: Entry not found)
[   12.970000] block: attempting to load /tmp/jffs_cfg/etc/config/fstab
[   12.980000] block: extroot: not configured
[   18.610000] NET: Registered protocol family 10
[   18.640000] nf_conntrack version 0.5.0 (960 buckets, 3840 max)
[   18.650000] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   18.680000] hidraw: raw HID events driver (C) Jiri Kosina
[   18.690000] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   18.700000] sd 1:0:0:0: Attached scsi generic sg1 type 0
[   18.710000] Loading modules backported from Linux version master-2014-05-22-0-gf2032ea
[   18.710000] Backport generated by backports.git backports-20140320-37-g5c33da0
[   18.730000] ip_tables: (C) 2000-2006 Netfilter Core Team
[   18.760000] usbcore: registered new interface driver usbhid
[   18.770000] usbhid: USB HID core driver
[   18.780000] usbcore: registered new interface driver usbserial
[   18.790000] usbcore: registered new interface driver usbserial_generic
[   18.790000] usbserial: USB Serial support registered for generic
[   18.820000] xt_time: kernel timezone is -0000
[   18.830000] usbcore: registered new interface driver cdc_ether
[   18.870000] cfg80211: Calling CRDA to update world regulatory domain
[   18.870000] cfg80211: World regulatory domain updated:
[   18.880000] cfg80211:  DFS Master region: unset
[   18.880000] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   18.890000] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   18.900000] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   18.910000] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[   18.910000] cfg80211:   (5170000 KHz - 5250000 KHz @ 160000 KHz), (N/A, 2000 mBm), (N/A)
[   18.920000] cfg80211:   (5250000 KHz - 5330000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[   18.930000] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[   18.940000] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[   18.950000] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[   18.970000] usbcore: registered new interface driver ch341
[   18.970000] usbserial: USB Serial support registered for ch341-uart
[   18.990000] usbcore: registered new interface driver cp210x
[   18.990000] usbserial: USB Serial support registered for cp210x
[   19.010000] usbcore: registered new interface driver ftdi_sio
[   19.010000] usbserial: USB Serial support registered for FTDI USB Serial Device
[   19.020000] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
[   19.050000] usb 1-1.3: Detected FT232RL
[   19.050000] usb 1-1.3: Number of endpoints 2
[   19.050000] usb 1-1.3: Endpoint 1 MaxPacketSize 16384
[   19.060000] usb 1-1.3: Endpoint 2 MaxPacketSize 16384
[   19.060000] usb 1-1.3: Setting MaxPacketSize 64
[   19.090000] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB0
[   19.160000] usbcore: registered new interface driver pl2303
[   19.170000] usbserial: USB Serial support registered for pl2303
[   19.190000] PPP generic driver version 2.4.2
[   19.210000] NET: Registered protocol family 24
[   19.260000] usbcore: registered new interface driver option
[   19.280000] usbserial: USB Serial support registered for GSM modem (1-port)
[   19.320000] ath: EEPROM regdomain: 0x0
[   19.320000] ath: EEPROM indicates default country code should be used
[   19.320000] ath: doing EEPROM country->regdmn map search
[   19.320000] ath: country maps to regdmn code: 0x3a
[   19.320000] ath: Country alpha2 being used: US
[   19.320000] ath: Regpair used: 0x3a
[   19.340000] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[   19.340000] cfg80211: Calling CRDA for country: US
[   19.350000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
[   19.360000] cfg80211: Regulatory domain changed to country: US
[   19.360000] cfg80211:  DFS Master region: FCC
[   19.360000] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   19.370000] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[   19.380000] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 1700 mBm), (N/A)
[   19.390000] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm), (0 s)
[   19.400000] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[   19.410000] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[   19.510000] usb-storage 1-1.1:1.0: USB Mass Storage device detected
[   19.530000] scsi2 : usb-storage 1-1.1:1.0
[   19.530000] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[   19.550000] ftdi_sio 1-1.3:1.0: device disconnected
[   19.550000] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
[   19.570000] usb 1-1.3: Detected FT232RL
[   19.570000] usb 1-1.3: Number of endpoints 2
[   19.570000] usb 1-1.3: Endpoint 1 MaxPacketSize 16384
[   19.580000] usb 1-1.3: Endpoint 2 MaxPacketSize 16384
[   19.580000] usb 1-1.3: Setting MaxPacketSize 64
[   19.600000] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB0
[   20.530000] scsi 2:0:0:0: Direct-Access     TOSHIBA  USB FLASH DRIVE  PMAP PQ: 0 ANSI: 6
[   20.540000] sd 2:0:0:0: Attached scsi generic sg0 type 0
[   20.550000] sd 2:0:0:0: [sda] 30240768 512-byte logical blocks: (15.4 GB/14.4 GiB)
[   20.580000] sd 2:0:0:0: [sda] Write Protect is off
[   20.590000] sd 2:0:0:0: [sda] Mode Sense: 45 00 00 00
[   20.600000] sd 2:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[   20.630000]  sda: unknown partition table
[   20.660000] sd 2:0:0:0: [sda] Attached SCSI removable disk
[   21.670000] i2c /dev entries driver
[   21.720000] Custom GPIO-based I2C driver version 0.1.1
[   21.770000] i2c-gpio i2c-gpio.0: using pins 20 (SDA) and 21 (SCL)
[   35.310000] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   36.900000] cfg80211: Calling CRDA for country: GB
[   36.950000] cfg80211: Regulatory domain changed to country: GB
[   36.950000] cfg80211:  DFS Master region: ETSI
[   36.950000] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   36.960000] cfg80211:   (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   36.970000] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[   36.980000] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm), (0 s)
[   36.990000] cfg80211:   (5490000 KHz - 5710000 KHz @ 80000 KHz), (N/A, 2700 mBm), (0 s)
[   37.000000] cfg80211:   (57240000 KHz - 65880000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[   38.320000] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   41.310000] wlan0: authenticate with 60:03:47:27:9f:5b
[   41.320000] wlan0: send auth to 60:03:47:27:9f:5b (try 1/3)
[   42.050000] wlan0: send auth to 60:03:47:27:9f:5b (try 2/3)
[   42.330000] wlan0: send auth to 60:03:47:27:9f:5b (try 3/3)
[   43.050000] wlan0: authentication with 60:03:47:27:9f:5b timed out
[   43.840000] wlan0: authenticate with 60:03:47:27:9f:5b
[   43.850000] wlan0: send auth to 60:03:47:27:9f:5b (try 1/3)
[   44.860000] wlan0: send auth to 60:03:47:27:9f:5b (try 2/3)
[   45.860000] wlan0: send auth to 60:03:47:27:9f:5b (try 3/3)
[   46.160000] wlan0: authentication with 60:03:47:27:9f:5b timed out
[   47.350000] wlan0: authenticate with 60:03:47:27:9f:5b
[   47.360000] wlan0: send auth to 60:03:47:27:9f:5b (try 1/3)
[   48.050000] wlan0: send auth to 60:03:47:27:9f:5b (try 2/3)
[   48.080000] wlan0: authenticated
[   48.090000] wlan0: associate with 60:03:47:27:9f:5b (try 1/3)
[   48.090000] wlan0: RX AssocResp from 60:03:47:27:9f:5b (capab=0x1411 status=0 aid=2)
[   48.100000] wlan0: associated
[   48.100000] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   50.920000] EXT4-fs (sdb): couldn't mount as ext3 due to feature incompatibilities
[   50.930000] EXT4-fs (sdb): couldn't mount as ext2 due to feature incompatibilities
[   50.960000] EXT4-fs (sdb): mounted filesystem with ordered data mode. Opts: (null)
[   51.770000] EXT4-fs (sdb): couldn't mount as ext3 due to feature incompatibilities
[   51.780000] EXT4-fs (sdb): couldn't mount as ext2 due to feature incompatibilities
[   51.800000] EXT4-fs (sdb): mounted filesystem with ordered data mode. Opts: (null)
[   57.870000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[   57.880000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[   57.940000] EXT4-fs (sda): mounted filesystem with ordered data mode. Opts: (null)
[   77.400000] EXT4-fs (sdb): re-mounted. Opts: data=ordered,commit=60,max_batch_time=1000000,min_batch_time=1000000,errors=remount-ro
[48289.250000] wlan0: authenticate with 60:03:47:27:9f:5b
[48289.260000] wlan0: send auth to 60:03:47:27:9f:5b (try 1/3)
[48289.320000] wlan0: authenticated
[48289.330000] wlan0: associate with 60:03:47:27:9f:5b (try 1/3)
[48289.330000] wlan0: RX AssocResp from 60:03:47:27:9f:5b (capab=0x1411 status=0 aid=2)
[48289.340000] wlan0: associated
[145302.630000] usb 1-1: USB disconnect, device number 2
[145302.630000] usb 1-1.1: USB disconnect, device number 3
[145302.660000] usb 1-1.3: USB disconnect, device number 4
[145302.670000] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[145302.670000] ftdi_sio 1-1.3:1.0: device disconnected
[145302.700000] usb 1-1.4: USB disconnect, device number 5
[145302.740000] sd 1:0:0:0: [sdb] Synchronizing SCSI cache
[145302.760000] EXT4-fs error (device sdb): ext4_find_entry:1309: inode #2: comm databased: reading directory lblock 0
[145302.770000] Aborting journal on device sdb-8.
[145302.780000] JBD2: Error -5 detected when updating journal superblock for sdb-8.
[145302.780000] EXT4-fs (sdb): Remounting filesystem read-only
[145302.820000] sd 1:0:0:0: [sdb]
[145302.820000] Result: hostbyte=0x01 driverbyte=0x00
[145302.830000] EXT4-fs error (device sdb): ext4_find_entry:1309: inode #2: comm databased: reading directory lblock 0
[145536.530000] EXT4-fs error (device sdb): ext4_wait_block_bitmap:466: comm databased: Cannot read block bitmap - block_group = 2, block_bitmap = 483
[145536.540000] EXT4-fs error (device sdb): ext4_discard_preallocations:3942: comm databased: Error reading block bitmap for 2
[145536.560000] EXT4-fs error (device sdb): ext4_put_super:760: Couldn't clean up the journal
[145537.790000] tmpfs: Bad mount option commit
[146147.900000] usb 1-1: new high-speed USB device number 61 using ehci-platform
[146318.880000] usb 1-1: new high-speed USB device number 81 using ehci-platform
[147286.700000] usb 1-1: new high-speed USB device number 69 using ehci-platform
[154608.680000] usb 1-1: new high-speed USB device number 81 using ehci-platform
[155568.330000] usb 1-1: new high-speed USB device number 32 using ehci-platform
[160576.800000] usb 1-1: new high-speed USB device number 115 using ehci-platform
[162706.410000] usb 1-1: new high-speed USB device number 92 using ehci-platform
[163606.870000] usb 1-1: new high-speed USB device number 26 using ehci-platform
[163846.330000] usb 1-1: new high-speed USB device number 105 using ehci-platform
[164147.950000] usb 1-1: new high-speed USB device number 89 using ehci-platform
frogfoot
Re: another problem...
Post by frogfoot »
It's failing several times per day now. a little feedback from the developer as to where the problem lies would be appreciated.
frogfoot
Post by frogfoot »
and some more
database (03.01.2017 13:00:03): rollback on insert forced (min): data10num
database (03.01.2017 13:00:03): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (03.01.2017 13:00:03): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (03.01.2017 13:00:04): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (03.01.2017 13:00:04): rollback on insert forced (min): data10num
database (03.01.2017 13:00:04): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (03.01.2017 13:00:05): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (03.01.2017 13:00:05): rollback on insert forced (min): data10num
database (03.01.2017 13:00:05): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (03.01.2017 13:00:05): cannot insert into data10num_hour  (after 0 tries in 2ms): database or disk is full
database (03.01.2017 13:00:06): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (03.01.2017 13:00:06): rollback on insert forced (min): data10num
database (03.01.2017 13:00:06): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (03.01.2017 13:00:07): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (03.01.2017 13:00:07): rollback on insert forced (min): data10num
database (03.01.2017 13:00:07): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (03.01.2017 13:00:08): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (03.01.2017 13:00:08): rollback on insert forced (min): data10num
database (03.01.2017 13:00:08): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (03.01.2017 13:00:09): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (03.01.2017 13:00:09): rollback on insert forced (min): data10num
database (03.01.2017 13:00:09): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (03.01.2017 13:00:10): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (03.01.2017 13:00:10): rollback on insert forced (min): data10num
database (03.01.2017 13:00:10): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (03.01.2017 13:00:11): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (03.01.2017 13:00:11): rollback on insert forced (min): data10num
database (03.01.2017 13:00:11): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (03.01.2017 13:00:12): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (03.01.2017 13:00:12): rollback on insert forced (min): data10num
database (03.01.2017 13:00:12): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (03.01.2017 13:00:13): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (03.01.2017 13:00:13): rollback on insert forced (min): data10num
database (03.01.2017 13:00:13): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (03.01.2017 13:00:14): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (03.01.2017 13:00:14): rollback on insert forced (min): data10num
database (03.01.2017 13:00:14): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (03.01.2017 13:00:15): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (03.01.2017 13:00:15): rollback on insert forced (min): data10num
database (03.01.2017 13:00:15): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (03.01.2017 13:00:16): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (03.01.2017 13:00:16): rollback on insert forced (min): data10num
database (03.01.2017 13:00:16): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (03.01.2017 13:00:17): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (03.01.2017 13:00:17): rollback on insert forced (min): data10num
database (03.01.2017 13:00:17): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
database (03.01.2017 13:00:18): cannot insert into data10num_hour  (after 0 tries in 1ms): database or disk is full
database (03.01.2017 13:00:18): rollback on insert forced (min): data10num
database (03.01.2017 13:00:18): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active
command: dmesg
[    0.620000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.670000] ath79-spi ath79-spi: master is unqueued, this is deprecated
[    0.710000] 0x000000050000-0x000000ff0000 : "firmware"
[    6.800000] usbcore: registered new interface driver usbfs
[    6.810000] usbcore: registered new device driver usb
[    6.890000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
[    6.900000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
[    7.540000] hub 1-1:1.0: 4 ports detected
[    7.950000] usb-storage 1-1.1:1.0: USB Mass Storage device detected
[    8.960000] scsi 0:0:0:0: Direct-Access     TOSHIBA  USB FLASH DRIVE  PMAP PQ: 0 ANSI: 6
[    8.970000] sd 0:0:0:0: [sda] 30240768 512-byte logical blocks: (15.4 GB/14.4 GiB)
[    8.980000] sd 0:0:0:0: [sda] Write Protect is off
[    8.980000] sd 0:0:0:0: [sda] Mode Sense: 45 00 00 00
[    8.980000] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    9.120000]  sda: unknown partition table
[    9.130000] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    9.660000] scsi 1:0:0:0: Direct-Access     Intenso  Premium Line     1100 PQ: 0 ANSI: 6
[    9.680000] sd 1:0:0:0: [sdb] Write Protect is off
[    9.700000]  sdb: unknown partition table
[   12.490000] jffs2: notice: (353) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (1 unchecked, 0 orphan) and 64 of xref (0 dead, 49 orphan) found.
[   12.510000] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
[   12.540000] block: extroot: not configured
[   12.630000] jffs2: notice: (350) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (1 unchecked, 0 orphan) and 64 of xref (0 dead, 49 orphan) found.
[   12.970000] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
[   12.980000] block: unable to load configuration (fstab: Entry not found)
[   12.990000] block: attempting to load /tmp/jffs_cfg/etc/config/fstab
[   13.000000] block: extroot: not configured
[   18.660000] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   18.690000] hidraw: raw HID events driver (C) Jiri Kosina
[   18.700000] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   18.720000] Backport generated by backports.git backports-20140320-37-g5c33da0
[   18.770000] usbcore: registered new interface driver usbhid
[   18.800000] usbserial: USB Serial support registered for generic
[   18.830000] xt_time: kernel timezone is -0000
[   18.840000] usbcore: registered new interface driver cdc_ether
[   18.880000] cfg80211: Calling CRDA to update world regulatory domain
[   18.880000] cfg80211: World regulatory domain updated:
[   18.890000] cfg80211:  DFS Master region: unset
[   18.890000] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   18.900000] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   18.910000] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   18.920000] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[   18.920000] cfg80211:   (5170000 KHz - 5250000 KHz @ 160000 KHz), (N/A, 2000 mBm), (N/A)
[   18.930000] cfg80211:   (5250000 KHz - 5330000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[   18.940000] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[   18.950000] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[   18.960000] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[   19.030000] usb 1-1.3: Detected FT232RL
[   19.030000] usb 1-1.3: Number of endpoints 2
[   19.030000] usb 1-1.3: Endpoint 1 MaxPacketSize 16384
[   19.040000] usb 1-1.3: Endpoint 2 MaxPacketSize 16384
[   19.040000] usb 1-1.3: Setting MaxPacketSize 64
[   19.060000] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB0
[   19.130000] usbcore: registered new interface driver pl2303
[   19.150000] usbserial: USB Serial support registered for pl2303
[   19.150000] PPP generic driver version 2.4.2
[   19.170000] NET: Registered protocol family 24
[   19.230000] usbcore: registered new interface driver option
[   19.250000] usbserial: USB Serial support registered for GSM modem (1-port)
[   19.290000] ath: EEPROM regdomain: 0x0
[   19.290000] ath: EEPROM indicates default country code should be used
[   19.290000] ath: doing EEPROM country->regdmn map search
[   19.290000] ath: country maps to regdmn code: 0x3a
[   19.290000] ath: Country alpha2 being used: US
[   19.290000] ath: Regpair used: 0x3a
[   19.310000] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[   19.310000] cfg80211: Calling CRDA for country: US
[   19.320000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
[   19.330000] cfg80211: Regulatory domain changed to country: US
[   19.330000] cfg80211:  DFS Master region: FCC
[   19.330000] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   19.340000] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[   19.350000] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 1700 mBm), (N/A)
[   19.360000] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm), (0 s)
[   19.370000] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[   19.380000] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[   19.470000] usb-storage 1-1.1:1.0: USB Mass Storage device detected
[   19.480000] scsi2 : usb-storage 1-1.1:1.0
[   19.480000] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[   19.500000] ftdi_sio 1-1.3:1.0: device disconnected
[   19.500000] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
[   19.520000] usb 1-1.3: Detected FT232RL
[   19.520000] usb 1-1.3: Number of endpoints 2
[   19.520000] usb 1-1.3: Endpoint 1 MaxPacketSize 16384
[   19.530000] usb 1-1.3: Endpoint 2 MaxPacketSize 16384
[   19.530000] usb 1-1.3: Setting MaxPacketSize 64
[   19.560000] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB0
[   20.480000] scsi 2:0:0:0: Direct-Access     TOSHIBA  USB FLASH DRIVE  PMAP PQ: 0 ANSI: 6
[   20.520000] sd 2:0:0:0: Attached scsi generic sg0 type 0
[   20.570000] sd 2:0:0:0: [sda] Write Protect is off
[   20.570000] sd 2:0:0:0: [sda] Mode Sense: 45 00 00 00
[   20.570000] sd 2:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[   20.600000]  sda: unknown partition table
[   20.640000] sd 2:0:0:0: [sda] Attached SCSI removable disk
[   21.640000] i2c /dev entries driver
[   21.730000] i2c-gpio i2c-gpio.0: using pins 20 (SDA) and 21 (SCL)
[   35.300000] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   36.930000] cfg80211: Calling CRDA for country: GB
[   36.930000] cfg80211: Regulatory domain changed to country: GB
[   36.940000] cfg80211:  DFS Master region: ETSI
[   36.940000] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   36.950000] cfg80211:   (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   36.960000] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[   36.970000] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm), (0 s)
[   36.970000] cfg80211:   (5490000 KHz - 5710000 KHz @ 80000 KHz), (N/A, 2700 mBm), (0 s)
[   36.980000] cfg80211:   (57240000 KHz - 65880000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[   38.350000] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   41.450000] wlan0: authenticate with 60:03:47:27:9f:5b
[   41.460000] wlan0: send auth to 60:03:47:27:9f:5b (try 1/3)
[   42.470000] wlan0: send auth to 60:03:47:27:9f:5b (try 3/3)
[   46.860000] wlan0: authentication with 60:03:47:27:9f:5b timed out
[   48.070000] wlan0: authenticate with 60:03:47:27:9f:5b
[   48.080000] wlan0: send auth to 60:03:47:27:9f:5b (try 1/3)
[   49.050000] wlan0: send auth to 60:03:47:27:9f:5b (try 2/3)
[   49.090000] wlan0: send auth to 60:03:47:27:9f:5b (try 3/3)
[   50.050000] wlan0: authentication with 60:03:47:27:9f:5b timed out
[   50.660000] EXT4-fs (sdb): couldn't mount as ext3 due to feature incompatibilities
[   50.670000] EXT4-fs (sdb): couldn't mount as ext2 due to feature incompatibilities
[   51.400000] EXT4-fs (sdb): recovery complete
[   51.410000] EXT4-fs (sdb): mounted filesystem with ordered data mode. Opts: (null)
[   51.750000] wlan0: authenticate with 60:03:47:27:9f:5b
[   51.760000] wlan0: send auth to 60:03:47:27:9f:5b (try 1/3)
[   52.220000] EXT4-fs (sdb): couldn't mount as ext3 due to feature incompatibilities
[   52.240000] EXT4-fs (sdb): couldn't mount as ext2 due to feature incompatibilities
[   52.280000] EXT4-fs (sdb): mounted filesystem with ordered data mode. Opts: (null)
[   52.770000] wlan0: send auth to 60:03:47:27:9f:5b (try 2/3)
[   53.160000] wlan0: authenticated
[   53.170000] wlan0: associate with 60:03:47:27:9f:5b (try 1/3)
[   53.170000] wlan0: RX AssocResp from 60:03:47:27:9f:5b (capab=0x1411 status=0 aid=13)
[   53.180000] wlan0: associated
[   53.180000] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   59.710000] EXT4-fs (sdb): re-mounted. Opts: data=ordered,commit=60,max_batch_time=1000000,min_batch_time=1000000,errors=remount-ro
[14368.240000] wlan0: authenticate with 60:03:47:27:9f:5b
[14368.250000] wlan0: send auth to 60:03:47:27:9f:5b (try 1/3)
[14369.010000] wlan0: send auth to 60:03:47:27:9f:5b (try 2/3)
[14369.260000] wlan0: send auth to 60:03:47:27:9f:5b (try 3/3)
[14370.010000] wlan0: authentication with 60:03:47:27:9f:5b timed out
[14371.200000] wlan0: authenticate with 60:03:47:27:9f:5b
[14371.210000] wlan0: send auth to 60:03:47:27:9f:5b (try 1/3)
[14372.010000] wlan0: send auth to 60:03:47:27:9f:5b (try 2/3)
[14372.220000] wlan0: send auth to 60:03:47:27:9f:5b (try 3/3)
[14373.010000] wlan0: authentication with 60:03:47:27:9f:5b timed out
[14374.700000] wlan0: authenticate with 60:03:47:27:9f:5b
[14374.710000] wlan0: send auth to 60:03:47:27:9f:5b (try 1/3)
[14375.720000] wlan0: send auth to 60:03:47:27:9f:5b (try 2/3)
[14376.720000] wlan0: send auth to 60:03:47:27:9f:5b (try 3/3)
[14377.730000] wlan0: authentication with 60:03:47:27:9f:5b timed out
[14388.500000] wlan0: authenticate with 60:03:47:27:9f:5b
[14388.510000] wlan0: send auth to 60:03:47:27:9f:5b (try 1/3)
[14389.520000] wlan0: send auth to 60:03:47:27:9f:5b (try 2/3)
[14390.520000] wlan0: send auth to 60:03:47:27:9f:5b (try 3/3)
[14391.530000] wlan0: authentication with 60:03:47:27:9f:5b timed out
[14412.360000] wlan0: authenticate with 60:03:47:27:9f:5b
[14412.370000] wlan0: send auth to 60:03:47:27:9f:5b (try 1/3)
[14413.010000] wlan0: send auth to 60:03:47:27:9f:5b (try 2/3)
[14413.380000] wlan0: send auth to 60:03:47:27:9f:5b (try 3/3)
[14414.010000] wlan0: authentication with 60:03:47:27:9f:5b timed out
[14445.000000] wlan0: authenticate with 60:03:47:27:9f:5b
[14445.010000] wlan0: send auth to 60:03:47:27:9f:5b (try 1/3)
[14446.010000] wlan0: send auth to 60:03:47:27:9f:5b (try 2/3)
[14446.020000] wlan0: send auth to 60:03:47:27:9f:5b (try 3/3)
[14447.010000] wlan0: authentication with 60:03:47:27:9f:5b timed out
[14473.110000] usb 1-1: clear tt 1 (9041) error -71
[14473.120000] usb 1-1: clear tt 1 (9041) error -71
[14508.420000] wlan0: authenticate with 60:03:47:27:9f:5b
[14508.430000] wlan0: send auth to 60:03:47:27:9f:5b (try 1/3)
[14509.010000] wlan0: send auth to 60:03:47:27:9f:5b (try 2/3)
[14509.440000] wlan0: send auth to 60:03:47:27:9f:5b (try 3/3)
[14510.010000] wlan0: authentication with 60:03:47:27:9f:5b timed out
[14571.360000] wlan0: authenticate with 60:03:47:27:9f:5b
[14571.370000] wlan0: send auth to 60:03:47:27:9f:5b (try 1/3)
[14572.010000] wlan0: send auth to 60:03:47:27:9f:5b (try 2/3)
[14572.380000] wlan0: send auth to 60:03:47:27:9f:5b (try 3/3)
[14573.010000] wlan0: authentication with 60:03:47:27:9f:5b timed out
[14663.060000] wlan0: authenticate with 60:03:47:27:9f:5b
[14663.070000] wlan0: send auth to 60:03:47:27:9f:5b (try 1/3)
[14664.010000] wlan0: send auth to 60:03:47:27:9f:5b (try 2/3)
[14664.080000] wlan0: send auth to 60:03:47:27:9f:5b (try 3/3)
[14665.010000] wlan0: authentication with 60:03:47:27:9f:5b timed out
[14718.670000] usb 1-1.1: USB disconnect, device number 3
[14718.690000] usb 1-1.3: USB disconnect, device number 4
[14718.690000] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[14718.700000] ftdi_sio 1-1.3:1.0: device disconnected
[14718.750000] usb 1-1.4: USB disconnect, device number 5
[14718.760000] sd 1:0:0:0: [sdb] Synchronizing SCSI cache
[14718.760000] Result: hostbyte=0x01 driverbyte=0x00
[14718.930000] usb 1-1: reset high-speed USB device number 2 using ehci-platform
[14719.440000] usb 1-1.1: new high-speed USB device number 6 using ehci-platform
[14719.990000] usb-storage 1-1.1:1.0: USB Mass Storage device detected
[14719.990000] scsi3 : usb-storage 1-1.1:1.0
[14720.080000] usb 1-1.3: new full-speed USB device number 7 using ehci-platform
[14720.240000] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
[14720.260000] usb 1-1.3: Detected FT232RL
[14720.260000] usb 1-1.3: Number of endpoints 2
[14720.260000] usb 1-1.3: Endpoint 1 MaxPacketSize 16384
[14720.270000] usb 1-1.3: Endpoint 2 MaxPacketSize 16384
[14720.270000] usb 1-1.3: Setting MaxPacketSize 64
[14720.310000] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB1
[14720.430000] usb 1-1.4: new high-speed USB device number 8 using ehci-platform
[14720.550000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[14720.550000] scsi4 : usb-storage 1-1.4:1.0
[14721.010000] scsi 3:0:0:0: Direct-Access     TOSHIBA  USB FLASH DRIVE  PMAP PQ: 0 ANSI: 6
[14721.030000] sd 3:0:0:0: Attached scsi generic sg0 type 0
[14721.030000] sd 3:0:0:0: [sda] 30240768 512-byte logical blocks: (15.4 GB/14.4 GiB)
[14721.050000] sd 3:0:0:0: [sda] Write Protect is off
[14721.050000] sd 3:0:0:0: [sda] Mode Sense: 45 00 00 00
[14721.050000] sd 3:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[14721.080000]  sda: unknown partition table
[14721.100000] sd 3:0:0:0: [sda] Attached SCSI removable disk
[14721.850000] scsi 4:0:0:0: Direct-Access     Intenso  Premium Line     1100 PQ: 0 ANSI: 6
[14721.890000] sd 4:0:0:0: Attached scsi generic sg1 type 0
[14721.890000] sd 4:0:0:0: [sdc] 15720448 512-byte logical blocks: (8.04 GB/7.49 GiB)
[14721.910000] sd 4:0:0:0: [sdc] Write Protect is off
[14721.910000] sd 4:0:0:0: [sdc] Mode Sense: 43 00 00 00
[14721.910000] sd 4:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[14721.940000]  sdc: unknown partition table
[14721.970000] sd 4:0:0:0: [sdc] Attached SCSI removable disk
[14752.390000] usb 1-1: clear tt 1 (9071) error -71
[14752.400000] usb 1-1: clear tt 1 (9071) error -71
[14755.660000] wlan0: authenticate with 60:03:47:27:9f:5b
[14755.670000] wlan0: send auth to 60:03:47:27:9f:5b (try 1/3)
[14756.680000] wlan0: send auth to 60:03:47:27:9f:5b (try 2/3)
[14757.680000] wlan0: send auth to 60:03:47:27:9f:5b (try 3/3)
[14758.680000] wlan0: authentication with 60:03:47:27:9f:5b timed out
[14784.600000] sd 4:0:0:0: [sdc] Synchronizing SCSI cache
[14784.940000] sd 4:0:0:0: [sdc]
[14784.950000] Result: hostbyte=0x07 driverbyte=0x00
[14785.990000] usb 1-1.4: can't set config #1, error -71
[14789.190000] ftdi_sio ttyUSB1: ftdi_set_termios urb failed to set baudrate
[14789.200000] usb 1-1: clear tt 1 (0070) error -71
[14789.210000] ftdi_sio ttyUSB1: urb failed to clear flow control
[14789.220000] usb 1-1: clear tt 1 (0070) error -71
[14789.220000] ftdi_sio ttyUSB1: failed to get modem status: -71
[14789.230000] usb 1-1: clear tt 1 (8070) error -71
[14789.240000] ftdi_sio ttyUSB1: error from flowcontrol urb
[14789.250000] usb 1-1: clear tt 1 (0070) error -71
[14789.260000] usb 1-1: clear tt 1 (0070) error -71
[14789.340000] usb 1-1: clear tt 1 (8070) error -71
[14790.250000] EXT4-fs error (device sdb): ext4_wait_block_bitmap:466: comm databased: Cannot read block bitmap - block_group = 2, block_bitmap = 483
[14790.260000] Aborting journal on device sdb-8.
[14790.260000] Buffer I/O error on device sdb, logical block 557056
[14790.260000] lost page write due to I/O error on sdb
[14790.270000] JBD2: Error -5 detected when updating journal superblock for sdb-8.
[14790.280000] EXT4-fs (sdb): Remounting filesystem read-only
[14790.290000] EXT4-fs error (device sdb): ext4_discard_preallocations:3942: comm databased: Error reading block bitmap for 2
[14790.310000] EXT4-fs error (device sdb): ext4_put_super:760: Couldn't clean up the journal
[14791.250000] tmpfs: Bad mount option commit
[14793.640000] usb 1-1: clear tt 1 (0070) error -71
[14793.650000] ftdi_sio ttyUSB1: ftdi_set_termios FAILED to set databits/stopbits/parity
[14793.660000] usb 1-1: clear tt 1 (0070) error -71
[14793.670000] ftdi_sio ttyUSB1: ftdi_set_termios urb failed to set baudrate
[14793.680000] usb 1-1: clear tt 1 (0070) error -71
[14793.690000] usb 1-1: clear tt 1 (0070) error -71
[14793.690000] ftdi_sio ttyUSB1: urb failed to clear flow control
[14793.700000] usb 1-1: clear tt 1 (0070) error -71
[14793.720000] usb 1-1: clear tt 1 (9071) error -71
[14793.720000] usb 1-1: clear tt 1 (0070) error -71
[14793.730000] ftdi_sio ttyUSB1: ftdi_set_termios urb failed to set baudrate
[14793.750000] usb 1-1: clear tt 1 (9071) error -71
[14793.750000] usb 1-1: clear tt 1 (0070) error -71
[14793.760000] ftdi_sio ttyUSB1: urb failed to clear flow control
[14793.770000] usb 1-1: clear tt 1 (0070) error -71
[14793.780000] ftdi_sio ttyUSB1: failed to get modem status: -71
[14793.790000] usb 1-1: clear tt 1 (8070) error -71
[14793.800000] usb 1-1: clear tt 1 (0070) error -71
[14793.800000] ftdi_sio ttyUSB1: ftdi_set_termios FAILED to set databits/stopbits/parity
[14793.810000] usb 1-1: clear tt 1 (0070) error -71
[14793.830000] ftdi_sio ttyUSB1: ftdi_set_termios urb failed to set baudrate
[14793.830000] usb 1-1: clear tt 1 (0070) error -71
[14793.850000] usb 1-1: clear tt 1 (0070) error -71
[14793.860000] ftdi_sio ttyUSB1: urb failed to clear flow control
[14793.860000] usb 1-1: clear tt 1 (0070) error -71
[14793.880000] usb 1-1: clear tt 1 (9071) error -71
[14793.890000] usb 1-1: clear tt 1 (0070) error -71
[14793.890000] usb 1-1: clear tt 1 (9071) error -71
[14793.910000] usb 1-1: clear tt 1 (1072) error -71
[14848.720000] wlan0: authenticate with 60:03:47:27:9f:5b
[14848.730000] wlan0: send auth to 60:03:47:27:9f:5b (try 1/3)
[14849.390000] wlan0: authenticated
[14849.410000] wlan0: associate with 60:03:47:27:9f:5b (try 1/3)
[14849.530000] wlan0: RX AssocResp from 60:03:47:27:9f:5b (capab=0x1411 status=0 aid=13)
[14849.540000] wlan0: associated
[14997.970000] usb 1-1.1: USB disconnect, device number 6
[14997.990000] usb 1-1.3: USB disconnect, device number 7
[14997.990000] ftdi_sio ttyUSB1: FTDI USB Serial Device converter now disconnected from ttyUSB1
[14998.010000] ftdi_sio 1-1.3:1.0: device disconnected
[14998.020000] usb 1-1.4: USB disconnect, device number 8
[14998.140000] usb 1-1: reset high-speed USB device number 2 using ehci-platform
[14998.590000] usb 1-1.1: new high-speed USB device number 9 using ehci-platform
[14998.710000] usb-storage 1-1.1:1.0: USB Mass Storage device detected
[14998.710000] scsi5 : usb-storage 1-1.1:1.0
[14998.810000] usb 1-1.3: new full-speed USB device number 10 using ehci-platform
[14998.930000] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
[14998.940000] usb 1-1.3: Detected FT232RL
[14998.940000] usb 1-1.3: Number of endpoints 2
[14998.940000] usb 1-1.3: Endpoint 1 MaxPacketSize 16384
[14998.950000] usb 1-1.3: Endpoint 2 MaxPacketSize 16384
[14998.950000] usb 1-1.3: Setting MaxPacketSize 64
[14998.970000] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB0
[14999.080000] usb 1-1.4: new high-speed USB device number 11 using ehci-platform
[14999.200000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[14999.200000] scsi6 : usb-storage 1-1.4:1.0
[14999.730000] scsi 5:0:0:0: Direct-Access     TOSHIBA  USB FLASH DRIVE  PMAP PQ: 0 ANSI: 6
[14999.750000] sd 5:0:0:0: Attached scsi generic sg0 type 0
[14999.750000] sd 5:0:0:0: [sda] 30240768 512-byte logical blocks: (15.4 GB/14.4 GiB)
[14999.780000] sd 5:0:0:0: [sda] Write Protect is off
[14999.780000] sd 5:0:0:0: [sda] Mode Sense: 45 00 00 00
[14999.790000] sd 5:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[14999.800000]  sda: unknown partition table
[14999.810000] sd 5:0:0:0: [sda] Attached SCSI removable disk
[15000.500000] scsi 6:0:0:0: Direct-Access     Intenso  Premium Line     1100 PQ: 0 ANSI: 6
[15000.520000] sd 6:0:0:0: Attached scsi generic sg1 type 0
[15000.520000] sd 6:0:0:0: [sdb] 15720448 512-byte logical blocks: (8.04 GB/7.49 GiB)
[15000.530000] sd 6:0:0:0: [sdb] Write Protect is off
[15000.540000] sd 6:0:0:0: [sdb] Mode Sense: 43 00 00 00
[15000.550000] sd 6:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[15000.560000]  sdb: unknown partition table
[15000.570000] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[86187.920000] wlan0: authenticate with 60:03:47:27:9f:5b
[86187.930000] wlan0: send auth to 60:03:47:27:9f:5b (try 1/3)
[86188.070000] wlan0: authenticated
[86188.080000] wlan0: associate with 60:03:47:27:9f:5b (try 1/3)
[86188.090000] wlan0: RX AssocResp from 60:03:47:27:9f:5b (capab=0x1411 status=0 aid=7)
[86188.090000] wlan0: associated
Yes, looks like the Toshiba USB storage is down. Depending on where
you are on the planet, I can send you a replacement USB stick from ATP
or you can send me the device, so that I do the replacement for you.
