Database problems
Asobig
Database problems
Post by Asobig »
I just setup my new Meteobridge Pro.
Now i am receiving these messages:
database (23.12.2016 15:59:10): cannot commit RAM (after 100 tries in 9090ms): database is locked
database (23.12.2016 15:59:19): cannot insert into data10num_hour RAM (after 100 tries in 9272ms): database is locked
database (23.12.2016 15:59:19): rollback on insert forced (min): data10num
database (23.12.2016 15:59:28): cannot commit RAM (after 100 tries in 9067ms): database is locked
database (23.12.2016 15:59:37): cannot insert into data10num_hour RAM (after 100 tries in 9276ms): database is locked
database (23.12.2016 15:59:37): rollback on insert forced (min): data10num
database (23.12.2016 15:59:47): cannot commit RAM (after 100 tries in 9101ms): database is locked
database (23.12.2016 15:59:56): cannot insert into data10num_hour RAM (after 100 tries in 9201ms): database is locked
database (23.12.2016 15:59:56): rollback on insert forced (min): data10num
database (23.12.2016 16:00:05): cannot commit RAM (after 100 tries in 9052ms): database is locked
database (23.12.2016 16:00:14): cannot insert into data10num_hour RAM (after 100 tries in 9226ms): database is locked
database (23.12.2016 16:00:14): rollback on insert forced (min): data10num
database (23.12.2016 16:00:23): cannot commit RAM (after 100 tries in 9083ms): database is locked
database (23.12.2016 16:00:33): cannot insert into data10num_hour RAM (after 100 tries in 9292ms): database is locked
database (23.12.2016 16:00:33): rollback on insert forced (min): data10num
database (23.12.2016 16:00:42): cannot commit RAM (after 100 tries in 9097ms): database is locked
database (23.12.2016 16:00:51): cannot insert into data10num_hour RAM (after 100 tries in 9247ms): database is locked
database (23.12.2016 16:00:51): rollback on insert forced (min): data10num
database (23.12.2016 16:01:00): cannot commit RAM (after 100 tries in 9050ms): database is locked
database (23.12.2016 16:01:10): cannot insert into data10num_hour RAM (after 100 tries in 9308ms): database is locked
database (23.12.2016 16:01:10): rollback on insert forced (min): data10num
I tried: Force check and Forced rebuild but notthing works.
Help please?
Re: Database problems
If it shows these errors even after setting "force database rebuild" and initiating a reboot after that, then please send
remote login credentials to "info(at)meteobridge.com". I would like to check some things.
Sperber
Post by Sperber »
Hello, same Problem here...
its beginning for 2 days....
I make a force database rebuild on reboot...but the same problem..
Plattform: Meteobridge PRO
RAM: 61500 kB insgesamt, 4680 kB frei (92% verwendet)
Speicher Intenso: Internal 7027 MB total, 6999 MB free (0% used)
SW-Version: Meteobridge 3.1 (Dec 22 2016, build 10776), FW 1.4
Laufzeit: 0 Stunden, 4 Minuten Puffer: 0 Einträge (0%)
Leistungsdaten: 5.48V 297mA 1.63W (Geräteinnenklima: 45.2°C 10%)
oled (25.12.2016 13:19:32): process started.
dbrepair (25.12.2016 14:21:00): database size is 1000.0K
dbrepair (25.12.2016 14:21:00): test integrity of database
dbrepair (25.12.2016 14:21:02): RAM database integrity is fine, nothing to do
dbrepair (25.12.2016 14:21:02): database integrity is fine, but rebuild is forced
dbrepair (25.12.2016 14:21:02): database rebuild started
dbrepair (25.12.2016 14:21:26): database export done, build new database
dbrepair (25.12.2016 14:22:04): database rebuild completed, services restarted
dbrepair (25.12.2016 14:22:04): new database size is 999.0K
database (25.12.2016 14:22:05): process started.
wnetd (25.12.2016 14:22:07): process started.
system (25.12.2016 14:22:07): start of logging process initiated.
logger (25.12.2016 14:22:07): databases connected. Update interval 3600 seconds.
logger (25.12.2016 14:22:07): Historical data loaded (0 records).
logger (25.12.2016 14:22:07): data logger (version 5.0t, build 10776) started.
logger (25.12.2016 14:22:10): connect station 0 (Vantage via USB serial).
logger (25.12.2016 14:22:10): connect station 9 (System Data via Plug-in).
logger (25.12.2016 14:22:10): wakeup sent.
logger (25.12.2016 14:22:11): internal logger activated.
logger (25.12.2016 14:22:11): syncing.
logger (25.12.2016 14:22:21): gettime request sent.
logger (25.12.2016 14:22:21): no Vantage time offset.
logger (25.12.2016 14:22:21): eeprom request sent.
logger (25.12.2016 14:22:21): rain collector size 0.2 mm per tick.
logger (25.12.2016 14:22:21): transmitter 1 active as station type (#0) "ISS".
logger (25.12.2016 14:22:21): transmitter 2 active as station type (#8) "Leaf/Soil".
logger (25.12.2016 14:22:21): firmware version request sent.
logger (25.12.2016 14:22:21): firmware version 1.90
logger (25.12.2016 14:22:21): no reading of Vantage's internal logger.
database (25.12.2016 14:23:22): cannot insert into wind0chill_all RAM (after 100 tries in 9159ms): database is locked
database (25.12.2016 14:23:22): rollback on sync forced (year): wind0chill
database (25.12.2016 14:23:32): cannot commit RAM (after 100 tries in 9019ms): database is locked
database (25.12.2016 14:23:41): cannot insert into thb0temp_day RAM (after 100 tries in 9114ms): database is locked
database (25.12.2016 14:23:41): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:23:50): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:24:00): cannot insert into thb0temp_day RAM (after 100 tries in 9113ms): database is locked
database (25.12.2016 14:24:00): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:24:09): cannot commit RAM (after 100 tries in 9021ms): database is locked
database (25.12.2016 14:24:18): cannot insert into thb0temp_day RAM (after 100 tries in 9138ms): database is locked
database (25.12.2016 14:24:18): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:24:27): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:24:36): cannot insert into thb0temp_day RAM (after 100 tries in 9135ms): database is locked
database (25.12.2016 14:24:36): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:24:45): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:24:54): cannot insert into thb0temp_day RAM (after 100 tries in 9111ms): database is locked
database (25.12.2016 14:24:54): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:25:04): cannot commit RAM (after 100 tries in 9014ms): database is locked
database (25.12.2016 14:25:13): cannot insert into thb0temp_day RAM (after 100 tries in 9124ms): database is locked
database (25.12.2016 14:25:13): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:25:22): cannot commit RAM (after 100 tries in 9019ms): database is locked
database (25.12.2016 14:25:31): cannot insert into thb0temp_day RAM (after 100 tries in 9114ms): database is locked
database (25.12.2016 14:25:31): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:25:40): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:25:49): cannot insert into thb0temp_day RAM (after 100 tries in 9114ms): database is locked
database (25.12.2016 14:25:49): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:25:58): cannot commit RAM (after 100 tries in 9016ms): database is locked
database (25.12.2016 14:26:07): cannot insert into thb0temp_day RAM (after 100 tries in 9115ms): database is locked
database (25.12.2016 14:26:07): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:26:17): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:26:26): cannot insert into thb0temp_day RAM (after 100 tries in 9113ms): database is locked
database (25.12.2016 14:26:26): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:26:35): cannot commit RAM (after 100 tries in 9014ms): database is locked
database (25.12.2016 14:26:44): cannot insert into thb0temp_day RAM (after 100 tries in 9112ms): database is locked
database (25.12.2016 14:26:44): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:26:53): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:27:02): cannot insert into thb0temp_day RAM (after 100 tries in 9114ms): database is locked
database (25.12.2016 14:27:02): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:27:11): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:27:20): cannot insert into thb0temp_day RAM (after 100 tries in 9125ms): database is locked
database (25.12.2016 14:27:20): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:27:30): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:27:39): cannot insert into thb0temp_day RAM (after 100 tries in 9112ms): database is locked
database (25.12.2016 14:27:39): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:27:48): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:27:57): cannot insert into thb0temp_day RAM (after 100 tries in 9112ms): database is locked
database (25.12.2016 14:27:57): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:28:06): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:28:15): cannot insert into thb0temp_day RAM (after 100 tries in 9115ms): database is locked
database (25.12.2016 14:28:15): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:28:24): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:28:34): cannot insert into thb0temp_day RAM (after 100 tries in 9144ms): database is locked
database (25.12.2016 14:28:34): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:28:43): cannot commit RAM (after 100 tries in 9020ms): database is locked
database (25.12.2016 14:28:52): cannot insert into thb0temp_day RAM (after 100 tries in 9112ms): database is locked
database (25.12.2016 14:28:52): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:29:01): cannot commit RAM (after 100 tries in 9014ms): database is locked
database (25.12.2016 14:29:10): cannot insert into thb0temp_day RAM (after 100 tries in 9114ms): database is locked
database (25.12.2016 14:29:10): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:29:19): cannot commit RAM (after 100 tries in 9021ms): database is locked
database (25.12.2016 14:29:28): cannot insert into thb0temp_day RAM (after 100 tries in 9129ms): database is locked
database (25.12.2016 14:29:28): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:29:38): cannot commit RAM (after 100 tries in 9014ms): database is locked
database (25.12.2016 14:29:47): cannot insert into thb0temp_day RAM (after 100 tries in 9114ms): database is locked
database (25.12.2016 14:29:47): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:29:56): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:30:05): cannot insert into thb0temp_day RAM (after 100 tries in 9132ms): database is locked
database (25.12.2016 14:30:05): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:30:14): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:30:23): cannot insert into thb0temp_day RAM (after 100 tries in 9112ms): database is locked
database (25.12.2016 14:30:23): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:30:32): cannot commit RAM (after 100 tries in 9014ms): database is locked
database (25.12.2016 14:30:41): cannot insert into thb0temp_day RAM (after 100 tries in 9113ms): database is locked
database (25.12.2016 14:30:41): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:30:51): cannot commit RAM (after 100 tries in 9020ms): database is locked
database (25.12.2016 14:31:00): cannot insert into thb0temp_day RAM (after 100 tries in 9111ms): database is locked
database (25.12.2016 14:31:00): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:31:09): cannot commit RAM (after 100 tries in 9015ms): database is locked
database (25.12.2016 14:31:18): cannot insert into thb0temp_day RAM (after 100 tries in 9122ms): database is locked
database (25.12.2016 14:31:18): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:31:27): cannot commit RAM (after 100 tries in 9015ms): database is locked
database (25.12.2016 14:31:36): cannot insert into thb0temp_day RAM (after 100 tries in 9123ms): database is locked
database (25.12.2016 14:31:36): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:31:45): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:31:54): cannot insert into thb0temp_day RAM (after 100 tries in 9112ms): database is locked
database (25.12.2016 14:31:54): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:32:04): cannot commit RAM (after 100 tries in 9016ms): database is locked
database (25.12.2016 14:32:13): cannot insert into thb0temp_day RAM (after 100 tries in 9123ms): database is locked
database (25.12.2016 14:32:13): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:32:22): cannot commit RAM (after 100 tries in 9040ms): database is locked
database (25.12.2016 14:32:31): cannot insert into thb0temp_day RAM (after 100 tries in 9111ms): database is locked
database (25.12.2016 14:32:31): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:32:40): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:32:49): cannot insert into thb0temp_day RAM (after 100 tries in 9113ms): database is locked
database (25.12.2016 14:32:49): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:32:58): cannot commit RAM (after 100 tries in 9014ms): database is locked
logger (25.12.2016 14:33:01): unexpected 0 bytes.
logger (25.12.2016 14:33:01): station 0 (Vantage), can't set attributes of device /dev/ttyMH to former values: Input/output error
logger (25.12.2016 14:33:01): disconnect station 0 (Vantage): response without data
database (25.12.2016 14:33:08): cannot insert into thb0temp_day RAM (after 100 tries in 9250ms): database is locked
database (25.12.2016 14:33:08): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:33:17): cannot commit RAM (after 100 tries in 9038ms): database is locked
database (25.12.2016 14:33:26): cannot insert into thb0temp_day RAM (after 100 tries in 9108ms): database is locked
database (25.12.2016 14:33:26): rollback on insert forced (hour): thb0temp
logger (25.12.2016 14:33:31): connect station 0 (Vantage via USB serial).
logger (25.12.2016 14:33:31): wakeup sent.
logger (25.12.2016 14:33:31): internal logger activated.
logger (25.12.2016 14:33:31): syncing.
database (25.12.2016 14:33:35): cannot commit RAM (after 100 tries in 9013ms): database is locked
logger (25.12.2016 14:33:41): gettime request sent.
logger (25.12.2016 14:33:41): no Vantage time offset.
logger (25.12.2016 14:33:41): eeprom request sent.
logger (25.12.2016 14:33:41): rain collector size 0.2 mm per tick.
logger (25.12.2016 14:33:41): transmitter 1 active as station type (#0) "ISS".
logger (25.12.2016 14:33:41): transmitter 2 active as station type (#8) "Leaf/Soil".
logger (25.12.2016 14:33:41): firmware version request sent.
logger (25.12.2016 14:33:41): firmware version 1.90
logger (25.12.2016 14:33:41): no reading of Vantage's internal logger.
database (25.12.2016 14:33:44): cannot insert into thb0temp_day RAM (after 100 tries in 9113ms): database is locked
database (25.12.2016 14:33:44): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:33:53): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:34:03): cannot insert into thb0temp_day RAM (after 100 tries in 9114ms): database is locked
database (25.12.2016 14:34:03): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:34:12): cannot commit RAM (after 100 tries in 9013ms): database is locked
logger (25.12.2016 14:34:14): unexpected 0 bytes.
logger (25.12.2016 14:34:14): station 0 (Vantage), can't set attributes of device /dev/ttyMH to former values: Input/output error
logger (25.12.2016 14:34:14): disconnect station 0 (Vantage): response without data
database (25.12.2016 14:34:21): cannot insert into thb0temp_day RAM (after 100 tries in 9161ms): database is locked
database (25.12.2016 14:34:21): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:34:30): cannot commit RAM (after 100 tries in 9014ms): database is locked
database (25.12.2016 14:34:39): cannot insert into thb0temp_day RAM (after 100 tries in 9107ms): database is locked
database (25.12.2016 14:34:39): rollback on insert forced (hour): thb0temp
logger (25.12.2016 14:34:44): connect station 0 (Vantage via USB serial).
logger (25.12.2016 14:34:44): wakeup sent.
logger (25.12.2016 14:34:44): internal logger activated.
logger (25.12.2016 14:34:44): syncing.
database (25.12.2016 14:34:48): cannot commit RAM (after 100 tries in 9016ms): database is locked
logger (25.12.2016 14:34:54): gettime request sent.
logger (25.12.2016 14:34:54): no Vantage time offset.
logger (25.12.2016 14:34:54): eeprom request sent.
logger (25.12.2016 14:34:54): rain collector size 0.2 mm per tick.
logger (25.12.2016 14:34:54): transmitter 1 active as station type (#0) "ISS".
logger (25.12.2016 14:34:54): transmitter 2 active as station type (#8) "Leaf/Soil".
logger (25.12.2016 14:34:54): firmware version request sent.
logger (25.12.2016 14:34:54): firmware version 1.90
logger (25.12.2016 14:34:54): no reading of Vantage's internal logger.
database (25.12.2016 14:34:57): cannot insert into thb0temp_day RAM (after 100 tries in 9111ms): database is locked
database (25.12.2016 14:34:57): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:35:06): cannot commit RAM (after 100 tries in 9014ms): database is locked
database (25.12.2016 14:35:16): cannot insert into thb0temp_day RAM (after 100 tries in 9113ms): database is locked
database (25.12.2016 14:35:16): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:35:25): cannot commit RAM (after 100 tries in 9019ms): database is locked
database (25.12.2016 14:35:34): cannot insert into thb0temp_day RAM (after 100 tries in 9244ms): database is locked
database (25.12.2016 14:35:34): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:35:43): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:35:52): cannot insert into thb0temp_day RAM (after 100 tries in 9120ms): database is locked
database (25.12.2016 14:35:52): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:36:01): cannot commit RAM (after 100 tries in 9014ms): database is locked
database (25.12.2016 14:36:11): cannot insert into thb0temp_day RAM (after 100 tries in 9141ms): database is locked
database (25.12.2016 14:36:11): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:36:20): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:36:29): cannot insert into thb0temp_day RAM (after 100 tries in 9113ms): database is locked
database (25.12.2016 14:36:29): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:36:38): cannot commit RAM (after 100 tries in 9016ms): database is locked
database (25.12.2016 14:36:47): cannot insert into thb0temp_day RAM (after 100 tries in 9113ms): database is locked
database (25.12.2016 14:36:47): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:36:56): cannot commit RAM (after 100 tries in 9017ms): database is locked
database (25.12.2016 14:37:05): cannot insert into thb0temp_day RAM (after 100 tries in 9112ms): database is locked
database (25.12.2016 14:37:05): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:37:14): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:37:24): cannot insert into thb0temp_day RAM (after 100 tries in 9114ms): database is locked
database (25.12.2016 14:37:24): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:37:33): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:37:42): cannot insert into thb0temp_day RAM (after 100 tries in 9112ms): database is locked
database (25.12.2016 14:37:42): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:37:51): cannot commit RAM (after 100 tries in 9017ms): database is locked
database (25.12.2016 14:38:00): cannot insert into thb0temp_day RAM (after 100 tries in 9112ms): database is locked
database (25.12.2016 14:38:00): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:38:09): cannot commit RAM (after 100 tries in 9014ms): database is locked
database (25.12.2016 14:38:18): cannot insert into thb0temp_day RAM (after 100 tries in 9116ms): database is locked
database (25.12.2016 14:38:18): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:38:28): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:38:37): cannot insert into thb0temp_day RAM (after 100 tries in 9117ms): database is locked
database (25.12.2016 14:38:37): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:38:46): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:38:55): cannot insert into thb0temp_day RAM (after 100 tries in 9113ms): database is locked
database (25.12.2016 14:38:55): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:39:04): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:39:13): cannot insert into thb0temp_day RAM (after 100 tries in 9112ms): database is locked
database (25.12.2016 14:39:13): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:39:22): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:39:31): cannot insert into thb0temp_day RAM (after 100 tries in 9115ms): database is locked
database (25.12.2016 14:39:31): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:39:41): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:39:50): cannot insert into thb0temp_day RAM (after 100 tries in 9119ms): database is locked
database (25.12.2016 14:39:50): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:39:59): cannot commit RAM (after 100 tries in 9015ms): database is locked
database (25.12.2016 14:40:08): cannot insert into thb0temp_day RAM (after 100 tries in 9139ms): database is locked
database (25.12.2016 14:40:08): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:40:17): cannot commit RAM (after 100 tries in 9014ms): database is locked
database (25.12.2016 14:40:26): cannot insert into thb0temp_day RAM (after 100 tries in 9112ms): database is locked
database (25.12.2016 14:40:26): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:40:35): cannot commit RAM (after 100 tries in 9014ms): database is locked
database (25.12.2016 14:40:45): cannot insert into thb0temp_day RAM (after 100 tries in 9122ms): database is locked
database (25.12.2016 14:40:45): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:40:54): cannot commit RAM (after 100 tries in 9015ms): database is locked
database (25.12.2016 14:41:03): cannot insert into thb0temp_day RAM (after 100 tries in 9114ms): database is locked
database (25.12.2016 14:41:03): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:41:12): cannot commit RAM (after 100 tries in 9015ms): database is locked
database (25.12.2016 14:41:21): cannot insert into thb0temp_day RAM (after 100 tries in 9112ms): database is locked
database (25.12.2016 14:41:21): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:41:30): cannot commit RAM (after 100 tries in 9014ms): database is locked
database (25.12.2016 14:41:39): cannot insert into thb0temp_day RAM (after 100 tries in 9113ms): database is locked
database (25.12.2016 14:41:39): rollback on insert forced (hour): thb0temp
database (25.12.2016 14:41:48): cannot commit RAM (after 100 tries in 9013ms): database is locked
database (25.12.2016 14:41:58): cannot insert into thb0temp_day RAM (after 100 tries in 9123ms): database is locked
database (25.12.2016 14:41:58): rollback on insert forced (hour): thb0temp
Asobig
Post by Asobig »
After removing all services and posts to Weather Nets and a reboot with forced rebuild, it's running again. I am now trying to restart the services and the posts to the Weather Nets. The Meteobridge is running for 19 hours without problems. Fingers crossed...
Sperber
Post by Sperber »
Hello Asobig,
i do the same, stop all an make "Forced new building at start" and have the same Problem
but than do "No test / new building at start"
And now is OK :D
@Sperber: When you send me the unit, I can exchange the USB storage with an ATP industrial
stick I am using on the latest production batches.
