Time on Graphs page resets to UTC **solved**
Asobig
Post by Asobig »
I was looking at the Graphs page and noted that the time in the graphs has changed to UTC instead of local time and i can't rememeber that i changed something. Is there a way to get the local time back?
Asobig
Re: Time on Graphs page resets to UTC
Post by Asobig »
After a reboot the time is correct.
shasta_doug
Post by shasta_doug »
I am having this problem now with the latest code 2/4. Rebooting doesn't reset it back to local timezone.
Asobig
Post by Asobig »
You are right. Same problem here.
It was just a bug related to display things. Database has things stored fine in local time.
Just released update should fix this graphing issue.
