Odd behavior for rain total...
DAP
Post by DAP »
I noticed some odd behavior for the rain total on https://www.wunderground.com/personal-w ... 223/mdaily. The rain total for the 23rd went up to 0.58, then dropped to 0.54.
There are no gaps in the data at wunderground, but when I log into the meteobridge pro, I have a 5 hour gap in the data. Also, it is reporting a version of firmware compiled on December 22, but I did not restart it for quite some time, and it is running on a UPS, so it could not have seen any power outages.
Note also that the oled is reporting it started on November 22 where everything else claims to have started on December 23.
oled (22.11.2016 05:33:46): process started.
database (23.12.2016 21:48:13): process started.
wnetd (23.12.2016 21:48:15): process started.
system (23.12.2016 21:48:15): start of logging process initiated.
logger (23.12.2016 21:48:16): databases connected. Update interval 3600 seconds.
logger (23.12.2016 21:48:16): Historical data loaded (0 records).
logger (23.12.2016 21:48:16): data logger (version 5.0t, build 10776) started.
logger (23.12.2016 21:48:18): connect station 0 (Meteostick Vantage via USB serial).
logger (23.12.2016 21:48:18): connect station 9 (System Data via Plug-in).
logger (23.12.2016 21:48:20): transmitter 2 registered as ISS
logger (23.12.2016 21:48:20): Meteostick Version 2.3b3
logger (23.12.2016 21:48:20): debug off
logger (23.12.2016 21:48:20): verbose off
logger (23.12.2016 21:48:20): output raw (8 bytes)
logger (23.12.2016 21:48:20): output raw (10 bytes)
logger (23.12.2016 21:48:20): filter on
logger (23.12.2016 21:48:20): rx threshold set to -70db
logger (23.12.2016 21:48:20): listening to transmitter 2
logger (23.12.2016 21:48:20): bandwidth narrow
logger (23.12.2016 21:48:20): chip authentication ok: 14
logger (23.12.2016 21:48:20): frequency band 915MHz (US)
database (23.12.2016 21:49:50): database sync done (46 tables, 190/8285 writes)
Re: Odd behavior for rain total...
OLED initialization is done when internal MB PRO clock might not already been synchronized with Internet time. So no reason to worry.
That a rain total for a day is decreasing during the course of the day is rather unexpected.
Do you see any silly numbers on "History" tab for the day? If not it might be something
strange with WU.
DAP
Post by DAP »
admin wrote: Do you see any silly numbers on "History" tab for the day? If not it might be something
strange with WU.
Just the 5 hour gap in the local data that does not appear in the WU data.
my Meteobridge Pro has been down for the last 15 hours, and I'm getting "503 Service Unavailable when I try and log in remotely.
DAP
Post by DAP »
When I finally got physical access to the Meteobridge Pro, I found it had locked up hard. I could not access it on the local network, I had to pull power to reset it.
Is there any way to implement a watch dog timer on this thing? This is the second time I have lost data because the Pro has locked up.
