Finding exported data ... continued
MartART
Post by MartART »
I still cannot fine exported data files. Using "\\YourMBpro-IPaddress\data\export"
If I login to the mbpro onsite then //192......./data or //192......./data/export give the message 'file not found'.
I'm probably doing something wrong ... any ideas?
Re: Finding exported data ... continued
Yes you are using // (forward slash) instead of \\ (backslash)
MartART
Post by MartART »
Ah yes, but backslashes are automatically changed to forward slashes by Chrome and Edge. If I try and replace them with %5C it still does not work - message i get is 'No such file or directory'.
Click <Start> in the "Search Programs and files" window (down the bottom) type in \\yourip\data and enter or select from the displayed search box
MartART
Post by MartART »
Excellent, that worked fine, thank you. Admin: would be good to include this in the mb documentation?
Neco
Post by Neco »
I have the exact same problem you had.. could you tell me what i have to do to find my exported data step by step?
Thanks :D
