Plugin needed?
weatheranorak
Plugin needed?
Post by weatheranorak »
Hi, My first post here :oops: I'd like some advice if possible please. I have made an Arduino based weather station using Mysensor wireless sensors all works and currently connects to a home automation system called Domoticz. I'd like Domoticz to output the sensor data i have from my weather sensors into Meteohub either using MQTT or preferably a txt file as the latter will be easier.
I am struggling to understand how i can import or interface Meteohub to read a txt file which will contain 'live' data in Meteohub format (as per the manual for plugin). What i need to know is if i need to write a script to do this or is there an easier way to get the results i need?
I also currently have a very old VP1 station connected to meteohub and i aim to eventually complement and rreplace the VP1 with my newly built system. Help! :?
