no web access when cloning
Jeffsbach
Post by Jeffsbach »
When I place a USB stick in port 1 to clone from port 2 and then power up, the web server is not accessible. I just get the generic \"Firefox can't establish a connection to the server\" message. IPScan and the beeps indicate a consistent IP address. I'm using software v2.4. If I shutdown, remove the port 1 stick, and insert the WS, everything works normally. Any ideas?
Jeff
Re:no web access when cloning
When you boot the system just one usb stick is allowed to be plugged in. It does not matter if in Disk 1 or Disk 2 slot.
Do you have the problem even with just one stick plugged during boot?
