Number of parameters in script execution
Clément
Post by Clément »
Is it possible to use multiple parameters in the script execution feature?
I need 2 parameters to run the script.
WA4OPQ
Location: Tennessee, USA About 40 miles west of Nashville y'all.
Re: Number of parameters in script execution
Post by WA4OPQ »
I had a similar question here:
viewtopic.php?f=56&t=11395
When I look into the code I don't see reason why you should not be able to put multiple parameters separated by a blank into the parameter field. Did you try without success?
What you put into the parameter field is translated to replace template variables. The Result is added to the command as parameters as if you would call the command from the Linux shell.
