Found WLIP not showing
DA270
Post by DA270 »
I successfully flashed a MR3020 and have set it up as a wireless LAN and LAN bridge and have a WLIP connected. The found WLIP drop down option does not show. The WLIP works fine when it's connected directly by ethernet to the cable modem/router and using CumulusMX. I've tried troubleshooting this for many hours; rebooting the VP2 console, MR3020, various Meteobridge settings, but not sure what to try next. Any ideas? TIA
Re: Found WLIP not showing
Did you try just entering the IP of the WLIP?
pfindlay
Post by pfindlay »
Same issue here. I don’t have a router as we are on a 4G mobile network so I got a MB to send the data to the web. Can’t work out how to get an IP address into the console.
It’s as if the lan bridge isn’t working.
