Meteobridge not sending weather data **solved**
JamesTF
Post by JamesTF »
I have been running Meteobridge for a couple of years. My Acurite 5in1 died 8 months ago. Replaced it then the acuhub died. Just replaced it a couple of days ago. When I check on Weather Underground and CWOP neither are showing temp, hum., wind or anything. But both show receiving something from MeteoBridge.
Meteobridge was running 3.2 from Feb 2017 but since I rebooted today it is running 3.2 from March 4th build 10970. Meteobridge does show green check marks by HTTP Upload as well as WU and CWOP. Live data on Meteobridge is populated and accurate.
I am at a loss as what to try or do next. This was working fine before the hub died.
Installed on TPLink 3020Acurite 5in1 with hub.
Oh and acurite hub is sending data to my acurite properly. Temp, hum, wind all is displayed properly.
Thanks in advance.
JamesTF
Re: Meteobridge not sending weather data
Post by JamesTF »
I meant to add that WeatherBug seems to acknowlegdge receipt of data from Meteobridge. Here is what WB reports:
Station Time/Date: 13:44:13 3/4/2017
Location: Wheatland, 95692 (USA) (39.018332°, -121.416943°)
Current
High
Low
Rate
Temperature (F)
140.0
140.0 (13:44)
140.0 (13:44)
0.0
Humidity (%)
5.0
0.0 (0:00)
100.0 (0:00)
0.0
Pressure ("Hg)
30.03
30.03 (13:44)
30.03 (13:44)
0.00
Winds (deg/mph)
291° / 0.0
999° / 999.0 (0:00)
Rain (inches)
0.00"
0.00" (month)
5.72 (rate)
0.00 (max rate)
Click here to ask questions or give feedback.
Status
Station: Success: p20896 : 3/4/2017 4:44:14 PM:QueryString:None:0
System Restart: 4:44:14 PM Saturday, March 04, 2017 / 1.1.1
JamesTF
Post by JamesTF »
To add to the above, I just noticed that the acurite smart hub I replaced is a 09150M as opposed to the old one which is 09150TX. This wouldn't be causing the issue of no data being sent to CWOP or WU would it?
I am really stumped, any help would be appreciated.
Tim
Can you please give me remote access to your meteobridge.
FAQ explains how... please mail credentials to "info(at)meteobridge.com".
JamesTF
Post by JamesTF »
Great! Thank you!
email sent.
Tim
dchamberlain
Post by dchamberlain »
Same problem here. Have an accurite for a couple years and no problems. i upload my data to weather underground. My TP-Link router was rebooted (power cycled) yesterday and since then, no data has uploaded although it says I am connected. On the meteobridge interface, the LIVE Sensor data area at the top is blank although historical data is displayed at the bottom.
doncurtis
Post by doncurtis »
dchamberlain wrote:Same problem here. Have an accurite for a couple years and no problems. i upload my data to weather underground. My TP-Link router was rebooted (power cycled) yesterday and since then, no data has uploaded although it says I am connected. On the meteobridge interface, the LIVE Sensor data area at the top is blank although historical data is displayed at the bottom.
Make sure you are using the password from weatherunderground (station key)
Login, go here : https://www.wunderground.com/personal-w ... tion/mypws
It used to be thst your user password was used but they changed it to the station key now (although in some cases both work)
Don
dchamberlain
Never mind my issue. After messing around for a good few hours, it turned out to be a physical connection issue out of the Accurite device. I guess it was just a coincidence. Sorry for hijacking the thread.
@JamesTF: Thanks for allowing me to login. Root cause was that by changing your equip the sensors appeared with new unique RF identifiers.
Meteobridge was still locked to the old identifiers and watched for data from them, but nothing coming in. New sensors were also detected,
but not recognized as primary sensors to use for reporting to weather networks.
By setting the mark "unlink sensors" on "weather station" tab beside aculink entry and pressing "Save" the locking to the
previous sensor IDs was removed and a fresh binding on the newly detected sensors was done. That solved your issue.
Small thing to change, but with huge effect.
JamesTF
Re: Meteobridge not sending weather data **solved**
Post by JamesTF »
Ah. It never crossed my mind that the sensors had unique IDs. I saw the new sensors populate Mteobridge and assumed that portion was working fine.
Thank you so very much for your help!
