Acurite Smart Hub **solved**
mrsmithmanley
Post by mrsmithmanley »
Hi thanks I just flashed the TP link router today and have everything running ok, just a few questions.
Wu how often should the update be in secs or mins
Also sometimes the WU gets data and sometimes it doesn't. What is the correct setting for the smart hub, I see its sending data which is appearing on WU but sometimes there no update with Temp even though it reported five seconds ago.
I would also like to know if I'm to eave unlink sensors checked ?
thanks for this wonderful software I'm in evaluation mode right now, but it is running good so far
mrsmithmanley
Re: Acurite Smart Hub
well its reporting great with no gaps
mrsmithmanley wrote:I would also like to know if I'm to eave unlink sensors checked ?
Unlink mark needs only be set when batteries of sensor unit were replaced or if you replace sensor hardware.
mrsmithmanley
thanks its working great :)
