MeteoBridge-Archive history issue **solved**
Wolfy007
Post by Wolfy007 »
I am using a Davis Vantage Pro 2+ with Davis USB Data logger, USB 2.0 Hub and Meteobridge (TL-MR3020) v3.2, F/W 1.4.
The Meteobridge sends live data via the WiFi to the Modem and up to Wunderground every minute.
Into the USB Hub I have a 64GB USB stick (FAT32). I have the following parameters set in the Meteobridge:-
Tolerated Age of Data 10 miin
Save Historical Data every 10 min.
Data is being saved to the stick from the Meteobridge, however when it is most needed to send to Wunderground due to loss of internet say over an hour nothing is sent except for live data on reconnect. I even cycled the power on the Meteobridge but still no history was uploaded.
I cannot see any other settings in Meteobridge. Am I doing something wrong or have the wrong concept of how the USB stick files are used.
I assumed this was necessary as the Meteobridge cannot read archived data from the Davis USB data Logger.
Cheers Mike
Re: MeteoBridge-Archive history issue
Meteobridge is not logging all data on the stick. It just stores the current min/max values for day/yesterday/month/year/all every ten minutes.
Wolfy007
Re: MeteoBridge-Sensor Archive f/w upgrade
Post by Wolfy007 »
From your comments I guess meteobridge is part way there then.
The inability to save sensor data to the USB stick a big downfall.
My firmware is installed on a TPLINK TL-MR3020 (plus USB hub)
Admin.. What are the chances of making a new release of meteobridge firmware to save all sensor data to USB stick and upload that data to a weather site after a connection is restored.
Best regards, Mike
not intended.
