BUG: AWEKAS wants Altimeter setting NOT MSLP
doncurtis
Post by doncurtis »
I just did some checking on AWEKAS, my barometer reading have been high. Meteobridge has been sending MSLP to AWEKAS and should be sending Altimeter setting (same as sent to CWOP}.
Here's their text from their website:
Air pressure adjustment:
In AWEKAS altimeter pressure (relative air pressure) is displayed. As some software give the absolute pressure, it is also possible to enter a correction value. This value can be positive or negative. In most case a correction value is NOT necessary. This value can be amended at any time in the user settings.
Don
doncurtis
Re: BUG: AWEKAS wants Altimeter setting NOT MSLP
Post by doncurtis »
In fact, in the US, NOAA (our national weather service) wants ALTITUDE as it is what is commonly used by radio and TV stations and on NOAA's website. MSLP is only used by meterologists in determining weather forecasts.
from: http://www.weather.gov/bou/pressure_definitions
STATION PRESSURE: This is the pressure that is observed at a specific elevation and is the true barometric pressure of a location. It is the pressure exerted by the atmosphere at a point as a result of gravity acting upon the "column" of air that lies directly above the point. Consequently, higher elevations above sea level experience lower pressure since there is less atmosphere on which gravity can act. Put another way, the weight of the atmosphere decreases as one increases in elevation. Consequently then, in general, for every thousand feet of elevation gain, the pressure drops about 1 inch of mercury. For example, locations near 5000 feet (about 1500 meters) above mean sea level normally have pressures on the order of 24 inches of mercury.
ALTIMETER SETTING: This is the pressure reading most commonly heard in radio and television broadcasts. It is not the true barometric pressure at a station. Instead it is the pressure "reduced" to mean sea level using the temperature profile of the "standard" atmosphere, which is representative of average conditions over the United States at 40 degrees north latitude. The altimeter setting is the pressure value to which an aircraft altimeter scale is set so that it will indicate the altitude (above mean sea level) of the aircraft on the ground at the location for which the pressure value was determined. The altimeter setting is an attempt to remove elevation effects from pressure readings using "standard" conditions.
MEAN SEA LEVEL PRESSURE: This is the pressure reading most commonly used by meteorologists to track weather systems at the surface. Like altimeter setting, it is a "reduced" pressure which uses observed conditions rather than "standard" conditions to remove the effects of elevation from pressure readings. This reduction estimates the pressure that would exist at sea level at a point directly below the station using a temperature profile based on temperatures that actually exist at the station. In practice the temperature used in the reduction is a mean temperature for the preceding twelve hours. Mean sea level pressure should be used with caution at high elevations as temperatures can have a very profound effect on the reduced pressures, sometimes giving rise to fictitious pressure patterns and anomalous mean sea level pressure values.
Don
