Bad Sensor Data
SPW55
Bad Sensor Data
Post by SPW55 »
I have noticed this message in the System Message Box data seems to be recording ok and I am currently running (Meteobridge 3.2 (Mar 13 2017, build 10995), FW 1.4)
any Ideas Please
logger (15.03.2017 09:16:01): Bad thb9(9) sensor data, "humidity" (-6) out of range [0:100]
logger (15.03.2017 19:30:30): message above repeats 1209 times.
Re: Bad Sensor Data
Sensor thb9 is a pure pressure/temp sensor but has by itself no humidity information.
Therefore, humidity recorded at the other on-board temp/hum sensor
is calculated to match the thb9 temperature and to be reported as
virtual humidity of thb9.
Looks like this estimation formula does not cap at 0% hum. Will be fixed in
next update but should not have any harm.
