Repeater
This is intended for discussion and information about the rfxcom receiver module
pep@chello.at
Repeater
Post by pep@chello.at »
I'm using the RFXCOM interface with meteohub and different Oregon sensors - WMR100, UV Sensor and the Water Thermo Sensor THWR288.
The signal from the Water Sensor is very weak and I would like to use a repeater for a better signal.
Is there any repeater available whhch works with Oregon sensors?
Thanks for help.
Peter
Re:Repeater
Post by skyewright »
I can't offer repeater suggestions but have you tried adjusting the position of your RFXCOM antenna?
My antenna is high up in our loft space and I occasionally pick up the odd anemometer and rain gauge signal from a neighbour with a WMR928 at a distance of 500m! I don't pick that up regular enough for it to be useable, but it does give some idea of the sensitivity of the RFXCOM receiver!
J.S.
Re:Repeater
Post by J.S. »
Yes there is such a repeater available. Here it is
http://www.meteorologica.co.uk/product. ... es&P_ID=45
Your sensor does not seem to be supported I'm afraid.
