I have Vantage Pro 2 using English units (not the problem). I've noticed that the data in Meteohub shows higher total rain than what my console shows.
After putting the data into a spreadsheet the mm to inches does NOT seem to be the problem. For example the console will shows a daily rain value of 0.11 inches while Meteohub shows 0.14 inches.
What it appears is that some readings are being carried from one minute to the next. I noticed double entries like 0.008 for two consecutive minutes. Unfortunately removing the second entry of each pair isn't the correct solution, since some are legitimate values.
Removing the second entry of each pair works for June 3rd the day with 0.11 inches of rain but on June 4th we had 0.33 inches of rain which Meteohub recorded as 0.421. Removing the double pair takes it down to 0.31.
Any suggestions?
John
Extra rain records recorded
