Rapid Fire not working again on WeatherUnderground
cbhiii
Post by cbhiii »
Rapids fire updatinghas again stopped working for Weather Underground.
What kind of info do you need from me to get this problem fixed? I'm using v2.3e.
Thank you.
Chill
Re:Rapid Fire not working again on WeatherUnderground
Post by Chill »
It works for me, under 2.3e every 30 seconds. May be once or twice a day (and not all days) can't connect at a given time, but next try it works...
Chill
cbhiii
Post by cbhiii »
This has been a problem in past versions as well where it just stops updating and only the normal 5 minute readings are received by Weather Underground.
Before that my Meteohub would update WU every 5 seconds througout the day without a problem except for the occassional no response from WU, which you mentioned. This is a different issue.
