Open Weather Map API
colmeteo
Post by colmeteo »
Open Weather Map provides accurate weather conditions for my region. I see they have a new API in place to send them the station info. With the old POST method, I do not see my station listed, nor can I retrieve information from it. Is there a chance to update the upload to use there API: http://openweathermap.org/stations
Re: Open Weather Map API
So far I don't see much potential in this network focusing at selling weather data. Supporting anything from them is not high on my agenda.
colmeteo
Post by colmeteo »
Understood Boris. Just out of curiosity, why the strong feelings toward OWM when they offer free access to the API with little limitation? I see WU has more restrictions on how to use the info they provide (i.e. logo guidelines) and also have commercial packages.
While WU has always been supportive to developers building upload software, OWM has never been. They focus 100% on their business model of selling weather data and care zero on the upload side. Their API that does not provide any interactive way to register a new station but forces the upload program registering the station with those JSON quirks, does clearly state how less they care about being easy to work with. I recommend not to deal with those, they will change their APIs often without taking care about anything - apart from their data selling business.
But if you want to use their service, you can register your station manually by sending that JSON register data to them. You will get a station ID and then you can configure Meteobridge to send HTTP packets in the needed format by means of a template hosted on your web site. This should work and you can then adapt to whatever idea they will come up in the future.
colmeteo
Post by colmeteo »
Thanks for the clarification. I will look into using another provide.
