Upload to WeatherLink with Meteobridge
captgadget
Post by captgadget »
I have my Davis Vantage Vue connected to my Meteobridge with a USB hub. As I understand I should be able to upload data to WeatherLink. If this is possible would some one please walk me through the necessary steps to make this work?
Re: Upload to WeatherLink with Meteobridge
captgadget wrote:I have my Davis Vantage Vue connected to my Meteobridge with a USB hub. As I understand I should be able to upload data to WeatherLink. If this is possible would some one please walk me through the necessary steps to make this work?
When a Davis USB logger is connected to a Meteobridge, you get an "extra free of charge" IP logger.
You can connect to that logger by the IP-address of your Meteobridge and port 22222.
Davis usb logger => Meteobridge
WL => IP-Meteobridge:22222
Simply tell WL to use an IP-logger at IP-Meteobridge:22222 and WL can work as in the past.
captgadget
Must different for a mac
cschmidt99005
Post by cschmidt99005 »
I assume this only works for the software. I have the software, but I use a Mac and it doesn’t work with MAC. I woild love to be able to log from the meteobridge to weatherlink.com and bypass the software. Weatherlink logs the evapotranspiration and soil moisture data but none of the other weather networks seem to.
