Graph functions failing ** solved **
mattjdalton
Post by mattjdalton »
Hey All,
I seem to have a problem with the graphing functions. No matter what sort of graph I request (even the examples that are preloaded), I end up with an error message that tells me all points y value undefined, like the following:
plot ' ^
"/tmp/meteohPaJTW", line 32: all points y value undefined!
Content-type: image/png
Does any one have some hints on fixing this?
Matt
Re:Graph functions failing
The message \"all points y value undefined!\" indicates that there is no time-compacted data in the requested time resolution and tine frame.
I guess, it will work, if you try it now, as the background processes will have computed the values in the meantime. If not, please start a recomputation manually (maintenance page).
