Is it possible to upload a Davis forecast via twitter?
BrandonBarometer
Post by BrandonBarometer »
Hi all,
Is it possible to do the above, that is, capture the Davis forecast and send it to the twiitersphere?. If so what is the formula? Thanks in advance, having just purchased a pro am looking forwRd to being a regular on here.
Re: Is it possible to upload a Davis forecast via twitter?
Check the text selector in the forecast variables on the template page
http://www.meteobridge.com/wiki/index.php/Templates
If you can incorporate that into a twitter string then should go?
BrandonBarometer
Thanks Matt, Much appreciated. I might be missing something but i can manage to get wind, temp etc to transmit but i can't get a forecast up. What would you put in the text?, that is, what is the formula entered .
Thanks in advance !
[forecast-text]
MB must be connected direct to Davis, MBPro via RF won't do it.
BrandonBarometer
Of course ! The direct connection had escaped me! At least I had the right code. Thanks Matt !
