Why do I need to cycle power so often?
Colin
Post by Colin »
Early June this year and again 1st July Meteobridge seemed to stop working.
Looking at the Live Data tab it says something like 'No http upload activity" and 'No Weather Network'.
Everything else looks okay. I have to turn the power off for a minute or so and turn it back on again.
Meteobridge then does its thing and it all works again.
Very annoying because last June it happened while I was away and could not cycle power for a few days.
I have a Davis Vantage Pro with data logger connected as well as an unpowered USB hub.
Meteobridge is connected via Ethernet.
IS my unit ending its useful life?
Colin
Re: Why do I need to cycle power so often?
Post by Colin »
Stopped again last night. Had to do a factory reset and set it all up again.
Hope it works now. Pity support will not offer suggestions.
sjob
Post by sjob »
I have the same problem.
Meteobridge stops working and needs restart. At least 2 times a week.
That is not normal behavior. Can you please allow me remote login as explained in the FAQ?
viewtopic.php?f=57&t=9885
I need URL and password. Please send to "info@meteobridge.com".
Colin
Post by Colin »
Tried that several times but get a message when I click the link 'this URL'
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
EDIT: when I input a password and save, I am asked if I want to update the Weather Underground site password in keychain. Why is this? And what will happen if I agree?
EDIT Again: Okay worked this time. email sent.
vade64
Post by vade64 »
I am having a similar problem with intermittent data capture on my DIR-505 connected to an Acurite Smarthub. Acurite supports uploading data to Weather Underground directly/natively. When I log in to my WU account online, all data is there with no gaps. Therefore, I know that the Smarthub device is not experiencing issues with connectivity between it and the weather station (Acu-Rite 5-in-1 station). My suspicion is that the meteobridge is losing connectivity to the service that it should be posting to. I have it set up to feed to both PWSWeather as well as CWOP. They both show successful posting once I reboot the Meteobridge but fail at some point after (minutes to hours). It has yet to successfully post for a solid day. I have my MB set to post every 5 minutes and retry indefinitely. Am I missing something?
Log data:
wnetd (31.07.2017 14:19:20): process started.
system (31.07.2017 14:19:20): start of logging process initiated.
logger (31.07.2017 14:19:21): Free trial period will end in 14 days. When you want to use this device beyond that period, you are welcome to use online licensing feature on "License" tab to purchase a license.
logger (31.07.2017 14:19:21): historical data loaded (16 records).
logger (31.07.2017 14:19:21): data logger (version 5.0v, build 11350) started.
logger (31.07.2017 14:19:21): connect station 0 (AcuLink via USB HID).
logger (31.07.2017 14:19:25): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (31.07.2017 14:19:25): services paused.
logger (31.07.2017 14:21:22): give up waiting for sensors after 120 secs.
logger (31.07.2017 14:21:22): services activated.
logger (31.07.2017 14:22:25): 5in1 sensor #00582 already registered (th0/rain0/wind0).
system (31.07.2017 14:22:43): stop of logging process initiated.
logger (31.07.2017 14:22:43): parent process received termination signal (15).
logger (31.07.2017 14:22:43): child process received termination signal (15).
system (31.07.2017 14:22:43): start of logging process initiated.
logger (31.07.2017 14:22:44): Free trial period will end in 14 days. When you want to use this device beyond that period, you are welcome to use online licensing feature on "License" tab to purchase a license.
logger (31.07.2017 14:22:44): historical data loaded (16 records).
logger (31.07.2017 14:22:44): data logger (version 5.0v, build 11350) started.
logger (31.07.2017 14:22:45): connect station 0 (AcuLink via USB HID).
logger (31.07.2017 14:22:48): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (31.07.2017 14:22:48): services paused.
logger (31.07.2017 14:23:19): 5in1 sensor #00582 already registered (th0/rain0/wind0).
logger (31.07.2017 14:23:37): sensors are now providing data.
logger (31.07.2017 14:23:37): services started.
logger (31.07.2017 15:28:08): error while waiting for data from weather stations
logger (31.07.2017 15:38:20): child process received timeout signal (14).
logger (31.07.2017 15:38:20): disconnect station 0 (AcuLink): exit
logger (31.07.2017 15:38:20): data logger stopped.
logger (31.07.2017 15:38:20): historical data loaded (16 records).
logger (31.07.2017 15:38:20): data logger (version 5.0v, build 11350) started.
logger (31.07.2017 15:38:21): connect station 0 (AcuLink via USB HID).
logger (31.07.2017 15:38:24): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (31.07.2017 15:38:24): services paused.
logger (31.07.2017 15:40:21): give up waiting for sensors after 120 secs.
logger (31.07.2017 15:40:21): services activated.
logger (31.07.2017 15:44:38): 5in1 sensor #00582 already registered (th0/rain0/wind0).
logger (31.07.2017 15:57:51): child process received timeout signal (14).
Colin
Post by Colin »
I gave Admin access to my meteobridge and he turned off 'retry indefinitely'. Been working okay since. Give that a try.
vade64
Post by vade64 »
What did he set it to?
"no retires"
Colin
Post by Colin »
And it is still working, so that seems to have fixed the problem.
