AllInOne graph display
Ag2000CO
Post by Ag2000CO »
newbe question. I can not find documentation anywhere to identify the bottom graph in the allinone chart type (the graph under Precipitation).
Otherwise, setup was a snap. Works fine. Range to my vantagePro2 seems short to avoid data drop-out. Unit does run warm, almost hot to the touch (101 F). I have the MB now setting in a south window and have added a cardboard "sun shade" which helps the running temp.
Lou
Ag2000CO
Re: AllInOne graph display
Post by Ag2000CO »
any pointers to documentation?
Lou
You find the chart definition file on the SMB share of your Meteobridge PRO: /data/templates/*.chart
You can edit this, if you would like to do changes. Format is explained by amcharts (which is the
chart engine used by MB PRO).
