connecting to an Apple network
baileyhines
- Fresh Boarder
How do I connect to an Apple network? The 192.168.1.77 does not work.
Re: connecting to an Apple network
The default network address setup for Meteohub is DHCP. Use a network scanner ( like fing ) to find out what address your router has assigned to your NSLU2 and use that address to login to your meteohub.
baileyhines
- Fresh Boarder
I tried using fing and it did not see my NSLU2. My router is set for DHCP and NAT and 10.0.1.1.
Can you bring up your router administration pages & see what address your router has assigned ?. Is your N lSU connected directly to your router or thru a range extender or repeater ?. If so, only the extender or repeater's administration pages may show the address.
Your other option is to see what address range your router is set up for and just start trying them sequentially until you bring up the meteohub login.
baileyhines
- Fresh Boarder
Tried that one by one and none connect.
Take a look at this thread regarding the NSLU2 being stuck at an IP and a fix
https://community.linksys.com/t5/Networ ... td-p/50534
