Power Outage / Landing Page
parsoli
Post by parsoli »
Hi Folks,
We had a lengthy power outage last night in the Chicagoland area. Nothing new. I've had my Meteobridge survive many a power cycle. However it's not coming up today. Below is the stack return.
I get into WRT and can ping meteobridge just fine. I'd rather not go thru setup again if I can avoid it. Because this can "talk" outbound and traffic shows it's flowing bi-directional just fine, what do you all think?
Thanks in advance for responses...
IFCONFIG:
br-lan Link encap:Ethernet HWaddr CC:B2:55:CA:73:78
inet addr:192.168.168.111 Bcast:192.168.168.255 Mask:255.255.255.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
eth0 Link encap:Ethernet HWaddr CC:B2:55:CA:73:78
collisions:0 txqueuelen:1000
Interrupt:4
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
wlan0 Link encap:Ethernet HWaddr CC:B2:55:CA:73:77
inet addr:192.168.1.20 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::ceb2:55ff:feca:7377/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:11938 errors:0 dropped:0 overruns:0 frame:0
TX packets:10768 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2883609 (2.7 MiB) TX bytes:3004116 (2.8 MiB)
RESOLV.CONF:
# Interface wlan
nameserver 192.168.1.8
nameserver 192.168.1.1
ROUTE:
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default firewall.parsol 0.0.0.0 UG 0 0 0 wlan0
192.168.1.0 * 255.255.255.0 U 0 0 0 wlan0
192.168.168.0 * 255.255.255.0 U 0 0 0 br-lan
NSLOOKUP:
Server: 192.168.1.8
Address 1: 192.168.1.8 dc02.xxx.net
Address 1: 2a01:4f8:10a:f98::4711 tau.meteobridge.com
Address 2: 88.99.105.253 tau.meteobridge.com
parsoli
Re: Power Outage / Landing Page
Post by parsoli »
Another question. I can SSH to the device as well. As I don't have a recent backup of the config, is there any configuration files that I could obtain from the file system to aid in re-constructing the config?
Did your router go down as well? Some times (well most times) the MB will start looking for the internet before the router has acquired. Have you powered the Router and MB off, start the router, wait until connected then start the MB
