Meteobridge Weather Cam **solved**
steviebaby59
Post by steviebaby59 »
For the past few days I have had no upload on my webcam. My Live Data tab says this:
Meteobridge Weather Cam: 2017-08-07 08:27:32 Error: convert: Not a JPEG file: starts with 0x3c 0x21 `/home/boris/meteobridge/htdocs/cam/9b6096469eba09a42bb6004e2f0d8941/cam.jpg' @ error/jpeg.c/JPEGErrorHandler/322. convert: no images defined `/home/boris/meteobridge/htdocs/cam/9b6096469eba09a42bb6004e2f0d8941/camplus.jpg' @ error/convert.c/ConvertImageCommand/3210. (no more tries)
Anyone know what's going on? :(
Re: Meteobridge Weather Cam
It seems that the camera link is answering with a html messdage, not with the expected jpg.
If it is a "Ubiquiti Cam, maybe the ip-address of the Cam changed?
If it is not a "Ubiquiti Cam" you have specified the link to the picture at tab Weatherstation => External Picture
Is there a green "correct mark"
If not: did you specify an ip-address which has changed?
Did you test that link manually and did it return a picture?
I can not attach a picture, ERROR: "Sorry, the board attachment quota has been reached. "
steviebaby59
The IP address and password are correct. I have the camera assigned to a Static IP.
Here is what the Weather Station tab looks like:
Found Ubiquiti Cams
(green check mark)Ubiquiti Cam IP:192.168.1.15
Version 1.2 Password: ••••
This is what I get when I try to reset it:
Error: Ubiquiti Cam initialization failed
1. I assume that all devices are still on the 192.168.1.xxx network?
2. What if you access the camera from your browser, does it respond on 192.168.1.15?
3. You could try to restart the camera (power off / on) and see if Meteobridge is able to find it.
Succes, Wim
steviebaby59
I can bring up the camera in my browser with the IP address. Tried rebooting the camera. Still no luck.
Camera works on my time lapse software.
steviebaby59
Got it fixed :D . Have some setting on the camera itself that got messed up.
Thanks for the advice.
