UV and Solar readings showing in red
paulm
Post by paulm »
See screenshot of the Live Data page (from an MBPRO getting data from a Vantage Vue over RF) at https://surfdrive.surf.nl/files/index.p ... Vp5Awq0afO
The UV and Solar readings are suddenly showing in red. There's also a battery sign next to the solar reading that I haven't noticed before. Is this indicating that there hasn't been enough solar power to charge the internal Vue battery?
I also wonder how to read the hours and db values. This unit was installed 19 days ago, with let's say 8 hours of sun per day, gives 152 hours. So that's in the right ballpark. The unit should be properly oriented, with the solar panel to the south.
Re: UV and Solar readings showing in red
They would be because the VUE does not have UV or Solar capabilities. You would need something like a VP2 plus for UV and Solar radiation.
Those look like false readings that have been picked from anywhere long time ago (hours indicate last reception of the signal).
