Writing realtime.txt to local storage
dexterdom
Post by dexterdom »
I have defined a recurring FTP service to upload a realtime.txt file to my FTP server (a NAS box) every minute. I have another application (on another PC) which then reads this file from the FTP server (NAS) and takes various actions based on the realtime data.
Ideally, I would like to cut out the intermediate FTP step and have the MB Pro write the realtime.txt file directly to local storage, which can then be shared over the network to my application. Is this possible? Any tips would be appreciated
Dom
Re: Writing realtime.txt to local storage
You could write your txt file to the SMB export folder and then access the file locally.
dexterdom
Post by dexterdom »
Hi Matt - I tried to create a Data Export service but the realtime template is not listed as an option in the dropdown (I only see standard-iso and standard-imp in the dropdown). Is there another service type that I need to use for this?
Those included standard type templates are basically examples, user definable.
Currently I can't see a way how you can directly channel the file to the SMB folder.
dexterdom
Post by dexterdom »
Too bad, but thanks for confirming this. Would you be able to add this functionality in a future update?
