I recently rebooted my device to clear out a loss of IP address problem (happens every few weeks or so) and now I am stuck in the fast blinking LED mode. I am able to access the device through the network (I get the Meteobridge Landing Page (FW 1.4) page), but the network config looks fine. It is almost as if it cannot access what it needs remotely to complete boot up. Eventually I get a solid "Reboot" message on the display with alternating blinking LED lights.
Could this be a licensing issue?
Warren
Stuck on fast blinking LED Mode during reboot
Re: Stuck on fast blinking LED Mode during reboot
Sounds like internet access issue?
I don't believe Internet access is the issue. I have tried both LAN port and WiFi on separate networks without any firewall in place. I also did a factory reset, to no avail.
I get to the same point: fast blinking LED and the device IP address where it just sits.
Continual fast blinking is definitely an indication an MB cannot find an internet connection and sits on the landing page unable to complete the boot up. With the mention of a display then I assume this is an MB Pro? If so how old is it as it could be a failed internal USB stick?
Yes, it is a PRO purchased last December. I am suspecting a problem with the internal USB stick.
No licensing issue and no USB issue. For some reason it cannot reach out to the Internet.
Are you running MB PRO on LAN as DHCP client?
